Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Glamour & Nude Talk
Reply
Thread Tools Display Modes
Old 24th of December 2008 (Wed)   #1
carguy
Default ima do my first g&n shoot i need help ima noob
hey whats up guys ima be doing a g&n shoot im new to this my freinds want me to do it for her so she said i could practise on her which is cool, i have a can rebel xsi with the kit lense can you plz tell me any setting that would be great to start off with, plz anyhting will help
carguy is offline   Reply With Quote
Old 24th of December 2008 (Wed)   #2
computerguru3190
computerguru3190's Avatar
Default Re: ima do my first g&n shoot i need help ima noob
1. Learn to type your post in english. Most people will turn press back immediately upon starting that post.
2. Look through the boards for help first.
3. Ask questions on things you don't understand.
computerguru3190 is offline   Reply With Quote
Old 25th of December 2008 (Thu)   #3
Mark_Cohran
Moderator
Mark_Cohran's Avatar
You need to be more specific and clear with your question and provide some information about your knowledge and experience. Do you need help understanding exposure settings, or poses, or lighting, or how to use backdrops, etc.?
Your post above gives us no point at which we can start to help you.
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Thirty-five years of shooting and still learning.
My G&N Blog (NSFW)- My Complete Gear List - Mac-Photo Website - My Tumblr Site (NSFW)
G&N FORUM EARLY ACCESS & IMAGE POSTING RULES
Mark_Cohran is offline   Reply With Quote
Old 26th of December 2008 (Fri)   #4
Karl Johnston
Rare exception that I didn't say anything stupid"
Karl Johnston's Avatar
I think you need to learn a bit more about how to operate the functions of your camera in manual mode, do some reading on the site and google "basic photography techniques"
And it's irrelevent but it would help to not write like that, not only is it annoying as hell not many are going to take you seriously and offer any advice but "Type better"
Karl Johnston is offline   Reply With Quote
Old 26th of December 2008 (Fri)   #5
carguy
sorry guys i was half asleep when i posted, i have owned my rebel xsi for 3 months and been playing with it but i want to know the best shutter speed to start at and what fstop to use to start at as well and i should use the m mode right??
Old 26th of December 2008 (Fri)   #6
rooftopsuicideclub
rooftopsuicideclub's Avatar
ok, this is the first place i started upon arriving here; you should read this from front to back, and then read it again.
http://photography-on-the.net/forum/...d.php?t=249006
next, go to amazon and buy this. it's the best 12 bucks you'll ever spend:
http://www.amazon.com/Digital-Photog.../dp/032147404X
after you're done reading that, pick up volume 2.
also +1 on the talking/typing thing. this is definitely not an AIM chat room.
good luck.
-CH
www.chrishaskellphotography.com
rooftopsuicideclub is offline   Reply With Quote
Old 26th of December 2008 (Fri)   #7
carguy
hey thanks for the help, i deff read that and helped me somewhat but what are the basic shutter speed and f-stops to use in glam photography
Old 26th of December 2008 (Fri)   #8
Astheros
Astheros's Avatar
i would assume you would use wide apertures to have dof and make use of available light without hopefully having to use the flash. as far as shutter speeds i am no pro but i dont think it really matters as long as your sharp and can get good exposure readings.
that book that was recommended was great..unfortunately i paid 25 bucks at b&h and not 12 as its listed on amazon.
Canon 7D / Tamron 17-50mm f/2.8 / Canon 430EX II
Astheros is offline   Reply With Quote
Old 26th of December 2008 (Fri)   #9
carguy
hey astheros i see you have the same camera maybe you could help me??
Old 28th of December 2008 (Sun)   #10
InsaneSkippy
The camera will have little impact on what makes a good shot. You need to take some time and practice getting your exposure right in your shots. Once you can manually set a shot by adjusting the aperture, shutter speed, and ISO, you'll have a decent understanding. Then you can move on to adjusting the white balance, setting a custom white balance.
Here are some random tips that may help out some. Sorry if it seems basic but you haven't given us any real insight to your current understanding.
1.) Make sure you're not shoot at too low of a shutter speed. Anything under 1/60th or so and you should be using a tripod or have the camera on a solid object. The reason for this is it will cause motion blur, this will ruin a shot. If you don't have enough light, bump the ISO up. This will add "noise" which is a grainy effect to the picture, this can be removed later during editing.
2.) As far as "basic settings for glamour shots" there's no such thing really. You need adjust your exposure settings (f/stop, shutter speed, ISO) to get the image properly exposed (not too dark or too bright).
3.) If you want the model to stick out from the background use a lower F/ number. If you want the background to be in focus as well, use a higher number.
XTi, 50D| 18-55, 50, 55-255 | 430EX II, Genesis 200 |
InsaneSkippy is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Best Lens to shoot for Close? noob sti jaguar Canon EF and EF-S Lenses 5 27th of September 2008 (Sat) 20:39
Ima Jun-Ke nigelnobody People 15 8th of July 2008 (Tue) 16:17
ok ima give this a try. 1ruffryder Nature & Landscapes 9 1st of July 2008 (Tue) 23:47
Light Staff - Ima KoKoDe stasber Critique Corner 5 22nd of February 2008 (Fri) 12:45
