#1 |
but is there a way to set the LCD panel illumination to stay on until i press the button to turn it off, instead of being on the timer? 40D by the way...
Mercuryphoto.blogspot.com
| sponsored links |
#2 |
but is there a way to set the LCD panel illumination to stay on until i press the button to turn it off, instead of being on the timer? 430exII by the way...
#3 |
innocent bystander
hmm, checking, but i think not.
You don't take a photograph. You ask, quietly, to borrow it. ~Unknown Mitch Flickr |
| sponsored links |
#4 |
Ms Moderator and Grandma
I don't think so, as it doesn't have a setting.
Suzie - Still Speaking Canonese! 5D2 My children are the reason, but it's the passion that drives me to get the perfect image of everything. My Gear and Wishes |
#6 |
innocent bystander
I think it turns off rather fast, it can be annoying shooting at night or evening. Halfway through checking settings at it turns itself off. It only stays on for like 7sec's.
#7 |
Not that I know of, but you can use your 40D menu system to set all the options on the flash unit, can't you? It under the "flash control" menu, so you should not have to even use the LCD on the 430EX.
Canon 40D; Canon 70-200 mm f/2.8L IS, 17-55mm f/2.8 IS, 85 mm f/1.8; 580EX II; Sigma EF-530 DG Super; CyberSyncs |
#8 |
It is absolutely annoying. That's something I had to get used to and so, I keep my finder near the button until I'm done adjusting.
#9 | |
-Matt |
#10 |
i think he's talking about the top lcd panel.. in which pressing play would instantly disable it.
5D3 | 5D2 | Z21 | 35L | 50L | 85L | 135L |
#11 |
"God bless the new meds"
There may be a diagnostic "hack", which usually involves some combination of key presses in a certain order at a certain speed (if you've ever played Tekken, you know what I mean.) Don't know what it is though...........
This space for rent.
#12 |
innocent bystander
The obvious alternative is using the back LCD panel, just by pressing INFO twice. However, it will burn through power, and I much prefer the top panel.
| Thread Tools | |
| Display Modes | |
| 5DII Video sound or no sound? | Keithaba | Canon EOS Digital Cameras | 10 | 17th of September 2008 (Wed) 15:57 |
| I'm an idiot, so help me ID | alexclc | Birds | 2 | 26th of May 2008 (Mon) 10:23 |
| ok, can someone help an idiot out? | blonde | RAW, Post Processing and Printing | 5 | 12th of September 2007 (Wed) 08:17 |
| I AM AN IDIOT!!!!!!!!!!!! | BBrat | Canon EF and EF-S Lenses | 30 | 31st of January 2007 (Wed) 14:10 |
