#1 |
They dont work lol. I've just order a white background and support kit and was planning on using my flash off camera to light the background. I was intending on buying a flash slave for the flash and then firing it with my studio lights.
However just brough the slave home, put the slave into a lightstand and the the flash onto the slave and ..... NOTHING! The flash is the Metz 44-AF4. I don't know why I ever brought it, it hasn't got manual control or a slave! Any idea's on this would be very helpful! Background due here saturday. Hopefully try and get it working by then! The slave is made by a comany called 'Koods' int he UK Thanks. Ryan
Canon 400D (XTi), Sigma 24-70 2.8 (LOVE IT!), 18-55mm f/3.5-5.6 kit lens, 50mm f/1.8 Nifty 50, 90-300 mm cheapo! And a new Metz AF-4C Flashgun Woooo. And a passion for photography. www.rtwphotography.wordpress.com |
| sponsored links |
#2 |
Do I need a PC Cord?
There isn't an outlet thing on my flash?
#3 |
It sounds as if the 44AF4 will not function unless it has communication with an ETTL-capable camera through its contacts.
Canon dSLR system, Olympus OM 35mm system, Bronica ETRSi 645 system, Horseman LS 4x5 system, Metz flashes, Dynalite studio lighting, and too many accessories to mention Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php |
| sponsored links |
#4 |
Urgh! Stoopid Flash.
What's the best route for me to take then?
#5 |
Find a flash with a built in photosensor and/or Manual power capability. It seems that a number of ETTL-compatible flashes are absurdly limited in their ability to be used off camera.
#6 |
Okay. Thanks alot
Now, to sell my Metz....ANYONE?
#7 |
the 44 is a good TTL flash on camera, but yeah, its not meant to be used as an off camera flash. I had one and upgraded to a 54 mz4 after it wouldn't work with a ttl cable (which was really annoying) and gave the 44 to my x.
#8 |
#9 |
Metz flashes generally in the past have been sterling performers for Auto flash and for manual usage. The more recently introduced nnAF series were introduced to be direct competition with the camera manufacturer's own flash units, and are as defeatured as the camera brand particularly in the lower powered lines like the 44AF. Look for the non-AF Metz, too, like the nnMZ for great Auto flash capable units.
Canon dSLR system, Olympus OM 35mm system, Bronica ETRSi 645 system, Horseman LS 4x5 system, Metz flashes, Dynalite studio lighting, and too many accessories to mention Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php Last edited by Wilt : 1st of January 2009 (Thu) at 11:15. |
#10 |
Moderator
The Metz 58 AF-1C when first released had its hotfoot contacts disabled when it was used off camera so it was useless as a remote flash. Fortunately they either saw the light or got enough complaints from users that they re-enabled the hotfoot via a firmware update.
...Leo Last edited by PacAce : 1st of January 2009 (Thu) at 11:17. |
#11 |
Thanks guys. So the newer models have slaves in them?
#12 |
If you do a search on here for metz 58 af-1 you should have your answers,
and if you look on ebay i have one for sale regards bill. |
#13 |
Moderator
If by "slaves" you mean optical trigger sensors, not too many flashes have it built-in. The only flashes currently in production which I know of are the Sigma EF 530 DG Super and the Nikon SB-900. However, those that do not have a built-in optical triggers can be set up as optical slaves by connecting them to an optical trigger device.
...Leo |
#14 |
I mean like will flash when another flash flashes?
#15 |
Few speedlight flash units simply a slave capability built it, using an optical sensor to detect triggering.
The only time any 'slave' capability exists is in conjuntion with proprietary 'master-slave' capability such as with Canon ETTL wireless IR tranmitter-receiver relationships. Some flashes such as Metz have an optional add-on capability to add their own proprietary wireless master-slave relationship between two flash units. Aside from proprietary systems (such as Canon's or Metz's), there are generic optical slaves available on the aftermarket, and there are proprietary IR transmitter-receivers such as Wein, and there are proprietary radio slave transmistter-receivers such as Pocket Wizard, Quantum, Cybersync, and others.
| Thread Tools | |
| Display Modes | |
| Macro/Close-Up/Master Flash + Slave Flash | KarlosDaJackal | Critique Corner | 3 | 16th of October 2008 (Thu) 08:44 |
| Metz Flash (mecablitz 76 MZ-5 digital flash) | garypasz | Small Flash and Studio Lighting | 4 | 15th of January 2008 (Tue) 15:13 |
| Flash alternative for the HF-DC1 slave flash | paul gotiong | Small Compact Digitals by Canon | 5 | 27th of July 2006 (Thu) 22:32 |
| Metz 28 CS-2 Digital Slave Flash ??? | wilerty | Small Flash and Studio Lighting | 0 | 17th of May 2005 (Tue) 09:31 |
| Cheap Slave Flash triggered from 300D - Pre-flash Problems? | Ozyboykev | Canon EOS Digital Cameras | 9 | 3rd of October 2004 (Sun) 15:19 |
