#1 |
"I'm a little slow"
Surrounded by Corn and Rednecks in Indiana
I wanted to give this a shot in CS3 and here is my first attempt at a HDR image...
Before... ![]() After... ![]() |
| sponsored links |
#2 |
It's a bit soft; it needs some unsharp mask. I'm glad to see you didn't overdo the HDR as most people do their first time.
#3 |
The "before" shot is not an image with too much dynamic range - it's simply over-exposed - that's all.
The HDR processing (the "after" picture) has increased the contrast, changed the black point setting and also lowered the values of the highlights without recovering any detail in the burned out highlights. In that sense, I would say that as an HDR process it was a failure. The same thing could have been done with simpler tools. Shooting RAW would have allowed you to be more effective with simpler processing in a RAW processor.
Bob Quality of Light, Photo Tool ver 2.0 Canon Rebel XTi; EF-S 10-22mm f/3.5-f/5.6 USM; EF-S 18-55 mm f/3.5-f/5.6; EF 28-135mm f/3.5-5.6 IS USM; EF 50mm f/1.4 USM; Canon Powershot G5; Canon AE1(2); Leica R4s; Battery Grip BG-E3; Pentax Digital Spotmeter with Zone VI Mod & Calibration. |
| sponsored links |
#4 | |
"I'm a little slow"
#5 |
OK, I will take you at your word. So, in the "before" image one would expect that the black point and white point would be set properly. In fact, the image is severely overexposed (22646 pixels are at value 255 - pure white). Furthermore, there are no pixels lying in the range 0 - 26.
In other words, none of the major exposure defects have been corrected. The image is still overexposed in the highlights, and the shadows do not incorporate any values less than 26 (dark grey). These are the very points that should be addressed and resolved in the HDR processing - to get the black point and the white point set as closely as possible to where you want them. To try to correct those in Photoshop instead of during HDR processing is exactly backwards. The only processing that should be left until after the HDR processing is completed is the final choices of bit depth and format (e.g., 8 bit jpeg).
Bob Quality of Light, Photo Tool ver 2.0 Canon Rebel XTi; EF-S 10-22mm f/3.5-f/5.6 USM; EF-S 18-55 mm f/3.5-f/5.6; EF 28-135mm f/3.5-5.6 IS USM; EF 50mm f/1.4 USM; Canon Powershot G5; Canon AE1(2); Leica R4s; Battery Grip BG-E3; Pentax Digital Spotmeter with Zone VI Mod & Calibration. Last edited by Robert_Lay : 1st of January 2009 (Thu) at 10:32. |
#6 |
"I'm a little slow"
Thanks Bob. I'll give it another shot...
#7 |
I think it's a good HDR image. You got everything to look realistic and didn't give it the classic nuclear waste over saturated look. The clouds are going to look soft because I am sure they moved between exposures.
As for the overall composition -- I am not sure what you are trying to accomplish with this photo. Is this a golf course? You backyard? Or just a HRD practice shot?
#8 |
*************HDR***************
Step-by-step Tutorial on "Merge to HDR" Now available at the following Web site: http://www.zaffora.com/W9DMK/UsingHDR.htm or as a downloadable PDF: http://www.zaffora.com/W9DMK/UsingHDR.pdf Here's a link to an example of how a Merge to HDR should work: http://photography-on-the.net/forum/...&highlight=HDR
#9 | |
"I'm a little slow"
#10 | |
"I'm a little slow"
| Thread Tools | |
| Display Modes | |
| Anyone using Dynamic-Photo HDR..??? | Avi | General Photography Talk | 11 | 5th of September 2008 (Fri) 12:41 |
| My First HDR photo | rattymouse | RAW, Post Processing and Printing | 5 | 30th of December 2007 (Sun) 21:04 |
| Hdr photo | Mforn79 | Urban Life & Travel | 4 | 25th of December 2007 (Tue) 02:29 |
| I want to do an HDR photo... | ClickClick | General Photography Talk | 10 | 24th of October 2007 (Wed) 06:59 |
| Car : HDR Photo | StealthLude | Transportation | 1 | 20th of November 2006 (Mon) 08:15 |
