Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 1st of January 2009 (Thu)   #1
jvolkman
Default 580EX II - discoloration on LCD display
Hey all,
I received a 580EX II for Christmas (yay!). Today I was outdoors shooting a parade and I noticed an area of discoloration on the LCD along the bottom towards the left side. The area is irregular in shape and appears either lighter or darker than the rest of the display depending on the viewing angle. At first I was worried that I had damaged the display, but I later realized that the spot is practically invisible under normal indoor lighting. However, once outside, it is plainly visible, and I assume this is why I haven't noticed it until today.
I contacted Amazon about exchanging it for a new one, but unfortunately they're now out of stock for 1-3 months. So, before I go through the hassle of returning the item to Amazon for a full refund and getting a new one elsewhere, I figured I'd post here and see if anyone else had similar issues with their displays.
I tried to take a picture of the spot, but since it's dark outside and I can't see the thing inside, I've thus far failed to do so.
Thanks.
jvolkman is offline   Reply With Quote
Old 1st of January 2009 (Thu)   #2
Sancho
Sancho's Avatar
Default Re: 580EX II - discoloration on LCD display
ok, really dumb question but were you wearing polarised glasses when your saw it?
Camera accessories? www.camera-shop.co.nz | Studio Lighting? www.studio-lighting.co.nz | Photos? www.markbennett.co.nz
Sancho is offline   Reply With Quote
Old 1st of January 2009 (Thu)   #3
jvolkman
Hah. Nope, unless my contact lenses are polarized!
Old 1st of January 2009 (Thu)   #4
GSansoucie
GSansoucie's Avatar
Is this a temperature thing? How cold was it outside today for you?
GSansoucie is offline   Reply With Quote
Old 1st of January 2009 (Thu)   #5
jvolkman
It was quite cold today. Around freezing. I did think about that, however the spot was still there after the flash had been sitting indoors for about a half hour (I took it outside real quick to check). I'll check again tomorrow after it's had a full night to sit in the warmth.
Old 1st of January 2009 (Thu)   #6
chestercopperpot
Sancho - I was going to ask the same thing!! I freaked out one afternoon cause I thought I broke the LCD on the flash only to realize my sunglasses were playing a trick on me!
Michael
5D Mark II
16-35mm 2.8L II; 35mm 1.4L; 85 1.2L II; 70-200 2.8L IS II
chestercopperpot is offline   Reply With Quote
Old 2nd of January 2009 (Fri)   #7
freebird
Yep both my flashes have the same thing. Freaked me out first time too with sunglasses.
freebird is offline   Reply With Quote
Old 2nd of January 2009 (Fri)   #8
trailblazer
trailblazer's Avatar
Same here.
I thought I damaged the lcd or the batteries leaked or something.
I can only see it when wearing sunglasses that are polarized though.
trailblazer is offline   Reply With Quote
Old 2nd of January 2009 (Fri)   #9
jvolkman
I've seen the effects that polarized glasses have on LCD displays before -- I don't think this mark was the same thing (and I wasn't wearing glasses when I saw it). Anyway, I shipped it back to Amazon today for a refund. I wanted to just request a replacement but at the time that I setup the return they out of stock for 1 to 3 months (!!). Anyway, I have a new one coming from B&H this time. I'll post back with how I make out.
5D Mk II | EF 16-35mm f/2.8L II | EF 24-70mm f/2.8L | EF 70-200mm f/2.8L IS | EF 50mm f/1.4 | EF 70-300 f/4.5-5.6 DO IS| 580EX II | 580EX I
Old 2nd of January 2009 (Fri)   #10
freebird
I happened to see the burn out mark once without glasses also. Some kind of wierd type lighting reflected off the display.
Good Luck
Old 2nd of January 2009 (Fri)   #11
F4 Cyborg
User is banned from forums
crystal refraction
F4 Cyborg is offline   Reply With Quote
Old 2nd of January 2009 (Fri)   #12
Blackey Cole
Was the sun hitting the LCD directly. I have had several LCD go dark or discolor from direct sunlight and it took a while before it corrected itself. But it did correct itself. What happened was the sun or heat warmed the LCD up so that wasn't functioning correctly. Also, as it wasn't out there in direct sun light all day it will repair itself. I did have one LCD item that was out oin the sun or in the truck during a day or two in the New Mexico summer that never did work again. That is when I began to watch for this.
Blackey Cole is offline   Reply With Quote
Old 3rd of January 2009 (Sat)   #13
garycoleman
yes I have the same slight discoloration if I look at an angle. It still works fine so I ignored it.
Canon 60D | 17-55mm f/2.8 IS | 70-200mm f/2.8L IS | 580EX II
garycoleman is offline   Reply With Quote
Old 3rd of January 2009 (Sat)   #14
FlyingPhotog
Cream of the "Prop"
FlyingPhotog's Avatar
Mine has the exact same discoloration...
Probably from the backlighting in some way. Isn't a big deal IMO.
FlyingPhotog is offline   Reply With Quote
Old 3rd of January 2009 (Sat)   #15
GSansoucie
GSansoucie's Avatar
I get that discoloration on my 40D (the top LCD) in the cold. I'd forgotten about it until this afternoon when I was outside shooting my kids sledding. At first I started grabbing for my sunglasses until I realized they were not on.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
atifacting and pixel discoloration Medic1 RAW, Post Processing and Printing 7 19th of April 2008 (Sat) 06:55
5D LCD display EYE KNO Canon EOS Digital Cameras 15 8th of November 2006 (Wed) 14:31
LCD display racketman Macro 3 31st of March 2006 (Fri) 19:17
LCD Display Protection jimmyd Canon EOS Digital Cameras 3 17th of September 2003 (Wed) 14:27
Help!! My G1 display "E24" on the LCD display. Dennis Canon G-series Digital Cameras 0 14th of October 2001 (Sun) 23:30
