Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 3rd of January 2009 (Sat)   #1
2Shiny
2Shiny's Avatar
Default SX10 problem
Whenever I hold the shutter button down halfway on my SX10 and recompose the shot, the camera makes a tapping noise, presumably from the autofocus system. It will keep making this sound once or twice per second for as long as I'm holding the shutter button down halfway.
Does anyone else's SX10 make this noise? I didn't notice the ones at Best Buy or Walmart making this noise.
Paul - author of Aquatic Plants of the Upper Midwest
300HS, D10 underwater, SX40 - UV, PL, ND8, Hoya macro filters, Raynox DCR250 macro, Gorillapod
2Shiny is offline   Reply With Quote
Old 3rd of January 2009 (Sat)   #2
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Default Re: SX10 problem
Mine doesn't appear to. What have you set AF and IS to? If AF is at "Continuous" and there's much variation in distance between where you prefocused and where the AF box ends up, you might be hearing the lens AF. Or, you might be hearing IS depending on your settings there.
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is offline   Reply With Quote
Old 3rd of January 2009 (Sat)   #3
2Shiny
2Shiny's Avatar
Before I read your post, I had the AF set to "single" and the IS set to "shoot only". I tried adjusting the AF to continuous, which had no effect on the noise problem. I switched the IS setting to "continuous" and to "off", both of which had no effect either. I even selected "save settings" after each of these changes.
The noise was still present every time. I focused on something about 3 feet away, held the shutter button down halfway, and slowly lifted the camera to focus on objects further and further away. Everytime I lifted the camera, it made the noise.
Old 3rd of January 2009 (Sat)   #4
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Does this sound like the "chuk-chuk" you get when the camera's hunting for focus, racking the lens back and forth, especially at longer focal lengths or with low contrast?
Jon
Cocker Spaniels
DC Cherry Blossoms
Old 4th of January 2009 (Sun)   #5
PhotoFranz
PhotoFranz's Avatar
I just tried mine. No noise.
http://www.flickr.com/photos/photofranz/
Camera: Fujifilm HS 50 EXR 42X zoom, Sigma Electronic Flash EF 500 DG ST, Vegas Movie Studio 9.0, Noiseware Standard Edition, Photoshop Elements-11, Photomatix Essentials. I am here to learn from the experts.
PhotoFranz is offline   Reply With Quote
Old 6th of January 2009 (Tue)   #6
2Shiny
2Shiny's Avatar
Sorry for the late response...I didn't get an email showing any other replies to this thread.
It is sort of a "chuck chuck" type sound, yes. If I zoom into an object a bit, hold the shutter button down halfway, and slowly pan around the room, it keeps making the sound. If I stop moving the camera, it stops. But if I'm outside with the camera at full zoom (capturing a bird or other distant object), the camera shake alone at a long focal length will cause the noise to happen. It's obviously adjusting something, but I don't know what or if it should be making this noise.
Old 7th of January 2009 (Wed)   #7
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
The only time I got any sound like that was when my SX-10 was adjusting focus. I hear similar sounds though, when the IS on several of my DSLR lenses kicks in.
Jon
Cocker Spaniels
DC Cherry Blossoms
Old 8th of February 2009 (Sun)   #8
jaffersultan
Hello
I bought Canon Sx10 in Nov 08. Initially i did not observe any problem. But since last two weeks i am observing "Chak Chak" (or what ever you call it) noise while i make a slow zoom (+ or -). What's furstrating is that this noise is very prominant in my video recordings, which is not the case in initial video recordings. Also, now during the video recordings, camera seems to have a tough time while maintaining its focus on the subject... Also yes, the same chak chak noise, when I press the shutter button half way as the camera continously focuses and defocuses espacially in digital zoom region.
I couldnot find the solution so I have given the camera to Canon service centre... see if they can find the solution. If it works i will let you know..
jaffersultan is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Show Us Your Best With The SX10 IS PhotoFranz Small Compact Digitals by Canon 984 26th of November 2012 (Mon) 17:22
SX10 Accessories? subnet_rx Small Compact Digitals by Canon 1 27th of December 2008 (Sat) 15:39
SX10 kac1 Small Compact Digitals by Canon 9 30th of November 2008 (Sun) 11:47
PS SX10 ShaunT Macro Talk 1 25th of November 2008 (Tue) 22:51
Just got my sx10 10megapixel Small Compact Digitals by Canon 7 31st of October 2008 (Fri) 13:35
