#1 |
Hello everyone, I just wondering why there's a few photographers who actually use Speedlite (580EX/430EX) on daily basis, even in outdoor. Doesn't the speedlites is properly use only in studio shots (portraits). In my theory, using flash just make the photo unnatural and it just make certain parts to be highlighted as a result of changes in the histogram. Since the rule of thumb of histogram is "the fuller the better", I care more of the shadows instead of highlighted areas. Let alone the natural light gives all the details I need.
Is it THAT perfect to shoot flash in low light conditions? How about the foreground? Will it be dark in indoors? Sports and Wildlife photography doesn't use flashes at all. Even in outdoor shots, many experienced photograper tend to ignore the speedlite to be use but only a few does that and I was wondering why. Where's my manners.. Hi, my name is Azri, I'm working with Canon for the past 3 years as a retail asistant. I know what speedlite are use for, I just wanted to see some of experienced user's example while shooting outdoors. Im a natural light shooter and I've been using my Canon 350D since it first came out and wanted to try some new tricks with speedlites, please gives example images of the benefits using speedlites on your subjects. Thanks. Azri @ Canon Malaysia. |
| sponsored links |
#2 |
Don't get pissy with me
Flash can be used to not look like flash.
Most people leave the flash off for sports because it slows down shooting and can distract athletes. Oh and this belongs in Small Flash and Studio Lighting: http://photography-on-the.net/forum/...splay.php?f=35
Did you lose Digital Photo Professional (DPP)? Get it here. Cursing at your worse-than-a-map reflector? Check out this vid! Last edited by cdifoto : 13th of January 2009 (Tue) at 10:39. |
#3 |
Wow, I must be a bad, inexperienced photographer since I use my flash a lot (almost every single day). I'm not a pro, but it's sad for me to find out that my photos must be awful because I use a flash...too bad.
Seriously, the right tool for the right job. Birder/wildlife/sport photographers DO use flash, but probably a smaller percentage. Some mount them in the ceiling/rafters, some use beamers, etc. Does that make them bad photographers or inexperienced? I don't think so. If you don't like flash, fantastic, don't use it. But to have your first post basically say flash users are inexperienced and their photos are unnatural, is just rude.
Hello, my name is BEN Family Photos :: My Maya-A-Day :: One Owen-A-Day Canon 40D :: Canon 24-105f/4L IS :: Canon 50f/1.4 :: Sigma 30f/1.4 :: Canon 580EXII w/Big FlipIt! :: Like a dozen different bags...Go Crumpler! |
| sponsored links |
#4 |
not few ..not really proud
Hello Azri, when used properly, a speedlight can be used outdoors in a way where you couldn't tell a flash unit was being utilized.
It's especially useful for using a strong backlight, while adding fill flash to illuminate the subject. ![]()
Canon5DMkII - Canon 70-200 f/2.8L IS - Canon 24-70 f/2.8L - 580 EXII - |
#5 |
Flash is also good for creating effects that you normally wouldn't be able to get on camera.
I do a lot of work in the music industry, mainly doing band promotional photo's and having flash really sets your pics apart from the ones just shooting with ambient light. To me, photography is all about light so, I like to have some additonal light and I prefer to have shadows in some places in order to create a certain feeling within the photo. I also to prefer to shoot outdoors as opposed to having a studio. Here's a shot done a buddy of mine - Aaron Van Dike. ![]() ![]() Here's the light set up for it: ![]() Here's the same shot, MINUS the strobes: ![]() See the difference. You can get more out of a photo using strobes, especcially on location, IMHO. Same idea with this one: ![]() This one was done another buddy, Keaton Andrew - ![]() This shot was taken at 10am with full morning sun to the band's left shoulders. No clouds in the sky whatsoever. Adding strobes/flashes just adds another dimension to a photo and allows for more possibilities than what ambient light can provide.
flickr | 40/60 Photo | Petey Photography| Canon 5D + 17-40mm f/4L + 50mm f/1.4 | 3x Alien Bee B800 | shuttrr.com - are you in?
#6 | |
You need to research more thoroughly. Your first theory is dead wrong, flash is another tool, if used properly can enhance your image. If your shots look unnatural with flash, you are doing it incorrectly. Your second assumption is also wrong. A lot of sports & wildlife shooters I know use flash with the better beamer. That said, I don't have any handy shots to show, maybe when I can get my hands on my work flow computer. |
#7 |
Using a flash unit outdoors is required if you must shoot at a loction that doesn't have any good natural lighting like in those images above.
I usually try and select areas that have good natural lighting so I don't have to use flash (see image # 1 below.) But sometimes the lighting needs a little help from an off camera flash (image # 2.) Benji |
#8 |
I use flash almost everytime and everywhere! It's the best tool I have (next to my 135mm f/2 :P). Take a look at this website.
http://www.planetneil.com/tangents/f...looking-flash/ This guy really knows how to work with light! On his website, you will find a ton of really really helpful tricks!
Canon 350d, 18-55mm is, 50mm f/1.8II, bower flash, Lowepro stealth reporter AW 400, |
#9 |
Moderator
Use of flash as fill or for cross-lighting in outdoor portraiture or glamour is very common. Fill flash help soften shadow, reduce constrast and balance the light so you can get good exposure for both your subject and the background.
I'd say you have it just opposite. The most experienced and knowledgeable photographers are the ones that use flash and use it well.
Mark ----- Some primes, some zooms, some Ls, some bodies and they all play nice together. Thirty-five years of shooting and still learning. My G&N Blog (NSFW)- My Complete Gear List - Mac-Photo Website - My Tumblr Site (NSFW) G&N FORUM EARLY ACCESS & IMAGE POSTING RULES |
#10 | |
Master Flasher
Azri, welcome to POTN!
There are many reasons a photographer might want to add light to the scene. But first, let me address this statement: Quote:
In my mind, there are two kinds of photography. You can capture an image, recording whatever light exists, or you can create an image by using your own light, or simply adding light to the scene. There is room in this world for both kinds of photography. Very often, flash is used because photographic equipment simply can't record the entire contrast range in a scene. Our eyes have a much greater dynamic range than any camera. Because of this, using flash to reduce the dymanic range in an image (by filling the shadows) can help us create an image that appears more "natural" than an image captured with ambient light only. Take a look at the first image in this thread: http://photography-on-the.net/forum/...d.php?t=628343 It was taken without flash. The dog's white hair on his sunlit side is exposed about as bright as possible without clipping detail. The black hair on the shaded side of the dog has no visible detail at all. If we saw that dog with our own eyes, we could see the detail on both sides. But the camera can't record the entire range.
"If you're not having fun, your pictures will reflect that." - Joe McNally Chicago area POTN events Flash Photography 101 | The EOS Flash Bible | Techniques for Better On-Camera Flash | How to Use Flash Outdoors | Excel-based DOF Calculator |
#11 |
I agree with what has been said, so far.
Indoors, my flash lives on my camera and I more often than not use use it for fill or for effect outdoors. If I don't have an external flash with me or it's not available, I won't hesitate using the pop up on the 40D. It's more usefull than it is given credit.
Bohdan - I may be, and probably am, completely wrong. Gear List Montreal Concert, Event and Portrait Photographer Flickr |
#12 |
I love natural light photography - but I always pack a flash. I just shot a couple of casual portraits that were heavily backlit by large windows and the flash enabled me to get the subject properly exposed without blowing out the windows. Just a nice added touch.
And I've been looking hard at the better beamer for some bird shots I want to try. Wildlife shooter use flash a lot. Welcome to the forums. |
#13 |
I shoot with a speedlite all the time, it makes a great supplimental flash. I also have a small soft box for it also, but I usually shoot it bareback because it creates a nice asthetic hard light.
Canon 5D Mark III | EF 24-70 f/ 2.8 L II http://www.keslertran.com http://keslertran.tumblr.com |
| Thread Tools | |
| Display Modes | |
| Butterflies - Natural light and Flash | alliec | Macro | 7 | 19th of July 2008 (Sat) 22:46 |
| Light. Natural vs natural vs flash | LordV | Macro | 8 | 17th of June 2007 (Sun) 13:43 |
| Dragonflies natural light and flash | lcpete | Macro | 5 | 14th of October 2006 (Sat) 16:58 |
| Use Flash or Natural Light | themirage | Weddings and Other Family Events | 27 | 5th of March 2006 (Sun) 09:36 |
| Help? Low-light, natural light, high-speed, fill flash | juneappal | Canon EOS Digital Cameras | 14 | 23rd of June 2005 (Thu) 05:23 |
