#1 |
Hi,
Tomorrow some friend will play at a small local club and I would like to have some shots of the nigth. I would like to see your recommendations for tomorrow. Bounce flash?, no flash?, take my nifty?, take my sigma? high ISO? open wide? problem with stage light? etc... Thanks in advance. |
| sponsored links |
#2 |
Take both your lenses and the flash. Generally, if you have stage lighting, you don't want to use the flash. The 50 1.8 should get you by if you have any sort of stage lighting. If you're lucky, you may have enough light for the 24-60.
Use a high enough ISO and open your lens up enough to keep your shutter speeds up in the 1/60+ range if possible. A good rule of thumb is that ISO noise is preferable to motion blur. If there is no light at all, pull out the 430ex. If you have white walls/ceiling, you can bounce it. Otherwise, you pretty much have to use direct flash. The key to using flash is to understand that you have an ambient exposure and a flash exposure. There are many variables that may determine what you want to do, but generally you want the flash to be powerful enough to stop motion. Typically, you wouldn't want the ambient so bright that it starts blurring your subject, but you generally don't want the flash in a cave look either. When using flash, you can stop down a little and increase the amount of exposure time. For example 1/15 f/4 ISO800 might be a reasonable exposure with TTL flash, but the actual exposure of course will depend on the amount of ambient light. |
#3 |
Thanx bacchanal... I will consider it
| sponsored links |
#4 |
Moderator
High ISO.
Wide open. Tungsten WB Shoot Raw If you use the flash, gel it to match the ambient (CTO filter. Ask the light tech
"I think the idea of art kills creativity" - Douglas Adams Why Color Management. Color Problems? Click here. MySpace Get Colormanaged PERSONAL MESSAGING REGARDING SELLING OR BUYING ITEMS WITH MEMBERS WHO HAVE NO POSTS IN FORUMS AND/OR WHO YOU DO NOT KNOW FROM FORUMS IS HEREBY DECLARED STRICTLY STUPID AND YOU WILL GET BURNED.
| Thread Tools | |
| Display Modes | |
| small camera bag recommendation | pianomatrix | Accessories & Storage | 6 | 5th of June 2008 (Thu) 19:13 |
| Small bag recommendation please | Mystwalker | Accessories & Storage | 9 | 9th of May 2008 (Fri) 01:31 |
| Small support recommendation? | jemann | Accessories & Storage | 3 | 7th of November 2007 (Wed) 18:50 |
| Recommendation for a small backpack | AiGTs | Accessories & Storage | 2 | 13th of October 2006 (Fri) 13:03 |
| small blues club | barP | Performing Arts | 6 | 7th of September 2006 (Thu) 16:01 |
