Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Compact Digitals by Canon
Reply
Thread Tools Display Modes
Old 20th of January 2009 (Tue)   #1
manicmunky
manicmunky's Avatar
Default NB-4L Battery for IXUS 80 IS
Hi All,
Just wondering if its ok to use other battery brands instead of Canon NB-4L battery. Will it cause any damage to the Ixus?
If so, does it have to be 760mAh (li-ion) or it can be 740mAh or 780mAh?
Cheers and God Bless!!
"everyday is an optic adventure"
manicmunky is offline   Reply With Quote
Old 21st of January 2009 (Wed)   #2
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Default Re: NB-4L Battery for IXUS 80 IS
Sure. I use Sterlingtek batteries in my EOS cameras and my wife's SD600 all the time. All the mAh rating means is the one with the biggest number ought to last longer per charge.
Jon
EOS, Powershot and Domke - it doesn't get any better than this!
T90 and stuff | F-1n, New F-1, FTb and more stuff out on loan
Cocker Spaniels
DC Cherry Blossoms
Jon is online now   Reply With Quote
Old 21st of January 2009 (Wed)   #3
manicmunky
manicmunky's Avatar
hey Jon,
Thanks for the reply. So any brand is actually ok rite? or is there a recommended one beside the one you are using? Canon batt pack is expensive. So i am just trying to get a cheaper one which has 900mAh to it so it will last longer.
Does that sounds ok?
Cheers!
Old 22nd of January 2009 (Thu)   #4
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Sterlingtek are good. I wouldn't buy, say, off eBay though. Check the Sterlingtek prices, even with shipping. Other brands, I don't generally know about. My old Rayovacs are dying a bit faster than the same age Canon ones.
Jon
Cocker Spaniels
DC Cherry Blossoms
Old 22nd of January 2009 (Thu)   #5
manicmunky
manicmunky's Avatar
Hey Jon,
Ok i will definitely chk out sterlingtek. The ones i see are from ebay and are very cheap. Altogether about AUS$15 and lesser. I saw those 900-1000mAh. Do you think its advisable? i just want a longer lasting battery.
All those cheap ones usually they die faster right? using them do not have any effect or whatsoever on the camera rite?
Cheers!
Old 22nd of January 2009 (Thu)   #6
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Cheap ones may not have all the protective circuitry built in to prevent overheating or overcharging problems, which could damage your camera. That's a primary danger with them.
Jon
Cocker Spaniels
DC Cherry Blossoms
Old 23rd of January 2009 (Fri)   #7
manicmunky
manicmunky's Avatar
ahhh okie..i read sumwhere that there are some which comes with chips or circuits that prevent overcharging. But how do we know that they are built-in?
hey sorry for the many questions. Just a newbie. hehe
Old 23rd of January 2009 (Fri)   #8
Jon
Moderator
Cocker Spaniel Mod
Jon's Avatar
Stick with recommended brands, is about it. Can't help you with brands in Singapore, I'm afraid.
Jon
Cocker Spaniels
DC Cherry Blossoms
Old 27th of January 2009 (Tue)   #9
manicmunky
manicmunky's Avatar
its ok jon..will look out for sterlingtek..already on the lookout actually! hehe.. thanks for your great help and tips, really appreciate it, cheers!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
battery for ixus 80 ellenp Small Compact Digitals by Canon 1 15th of November 2008 (Sat) 20:41
Canon IXUS 40 Battery eakb Small Compact Digitals by Canon 1 27th of December 2004 (Mon) 19:30
Off camera battery for Powershot and IXUS gardenstate Small Compact Digitals by Canon 0 28th of November 2004 (Sun) 07:34
Ixus 400 battery life Saudidave Small Compact Digitals by Canon 1 22nd of June 2004 (Tue) 15:45
Ixus NB-1L battery from HAMA EoSD30fReAk Small Compact Digitals by Canon 0 4th of February 2004 (Wed) 10:29
