Reply
Thread Tools Display Modes
Old 12th of December 2002 (Thu)   #1
caldgrp
Default White Balance and Flash
Using the 420EX with tungsten lighting, what white balance setting should I use, flash, tungsten or auto? The scene on the G2 LCD will vary from orange to blue none of which look "natural"
I shoot in RAW and do not see much difference, as compared to the G2 LCD display, when I experiment with different white balance settings in Breezebrowser
caldgrp is offline   Reply With Quote
Old 12th of December 2002 (Thu)   #2
ega1
Default Re: White Balance and Flash
I don't think you can have a hard rule for this. It all depends on the ratio of flash to tunsten light. If the flash is the main light, the flash setting would probably be best.
If you're not satisfied, perhaps you can try custom white balance, either at shooting time or when you convert from raw.
ega1 is offline   Reply With Quote
Old 17th of December 2002 (Tue)   #3
Harv
You will always be best off using the flash as your primary light source when in a mixed light situation. Adjusting white balance later is a possible solution but will most likely just give you a photograph where none of the colors are correct.
Using a bounce like a Lumiquest will give you a good amount of spillover flash and will work to lessen color "pollution" of ambient lights.
Also keep in mind that flash is not dependent upon shutter speed (up to sync speed), so use the fastest shutter possible to minimize ambient light. This again is where a bounced flash will make a big difference in lighting up the background.
As an experiment, shoot a scene with normal household table lamps in the background and a subject, such as a person, in the foreground. Shoot at F4 with a shutter of 1/60 (and using your 420ex in bounce position, since this is just an experiment, a Lumiquest or similar bounce card is not necessary).
You will need to use the camera in Manual mode to do this, and adjust the flash output via the control button on the camera (same button as the white balance button). Then shoot the same scene again at f4 at 1/250.
With the 1/250 shutter, the background could be a bit darker, but not necessarily so. The big difference should be a significant reduction in the intensity of the incandescent lamps. The shutter speed has a large effect of continous light sources such as lamps, but has no effect on flash. Remember that the flash must be bounced for this to work.
Harv is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Do you custom white balance with flash? Tshoe RAW, Post Processing and Printing 2 11th of April 2006 (Tue) 19:11
G6, Flash, White Balance........ Bosman Canon G-series Digital Cameras 1 16th of September 2005 (Fri) 09:58
Flash White Balance--NOT Auto! RajaBhat Canon G-series Digital Cameras 8 12th of September 2003 (Fri) 02:28
s50 white balance + flash Prakash Small Compact Digitals by Canon 3 8th of July 2003 (Tue) 00:16
Flash White Balance Correction ccaroe Canon G-series Digital Cameras 3 12th of March 2003 (Wed) 04:35
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
