Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Digital Video
Reply
Thread Tools Display Modes
Old 31st of January 2009 (Sat)   #1
Travis F
Travis F's Avatar
Default Joining DVD files?
Hey all,
Let me start by saying I have no experience with dvd editing. With that in mind, I have been requested to join two dvd files from a "handy cam" that burnt directly to mini-dvd. I have no idea how to do this. I have successfully ripped the discs to my HD.
I am totally lost, so any help or links down the right path are greatly appreciated!
BTW - This is a wedding video that had to be split due to the mini-dvd capacity. The Videographer was a friend of the Bride and has given all permission to edit the video as they wish. Unfortunatey I was given the task of doing this.
Any and all help is appreciated!
Travis
_____________________________________________
Travis F is offline   Reply With Quote
Old 4th of February 2009 (Wed)   #2
Stealthy Ninja
User is banned from forums
Location: Mythical Tasmania (the one with lots of tall buildings in the semi-tropics, A.K.A. Hong Kong)
Default Re: Joining DVD files?
You need a video editing program.
If you have a PC you can use windows movie maker
If you have a Mac you can use imovie
Both will let you join files together pretty easy.
What format did you rip the DVDs to?
Stealthy Ninja is offline   Reply With Quote
Old 5th of February 2009 (Thu)   #3
osv
the best way is to join the files on the disks together without re-encoding to another format, because you'll take a hit on picture quality.
http://womble.com/
mpeg video wizard is what i use, there is a 30-day trial to check it out, the editor is kinda clumsy, but you can't beat the quality.
Canon Vixia HF11 Review
osv is offline   Reply With Quote
Old 5th of February 2009 (Thu)   #4
Stealthy Ninja
Which is why DVD video cams suck badly. They record to a compressed format. Dumb.
There are ways you can rip a DVD without much loss in quality (none you can see anyway).
http://www.autogk.me.uk/ <-- this program is very good at ripping DVDs (on PC).
Old 5th of February 2009 (Thu)   #5
Travis F
Travis F's Avatar
I think they came off as VTS and VOB files. I deleted them since I didn't have any luck joining them. I'll rip them again tomorrow and find out the file types.
Thanks for the info,
Travis
Old 6th of February 2009 (Fri)   #6
Stealthy Ninja
You'll need to rip them to AVI or MOV files (AVI for PC and MOV for mac).
Old 6th of February 2009 (Fri)   #7
overclock
http://www.videohelp.com/guides
overclock is offline   Reply With Quote
Old 6th of February 2009 (Fri)   #8
osv
dvd video cams record in the same mpeg2 format that all dvds use... which does make it tough to edit without losing quality, i see your point there.
the key is to rip the video files losslessly, and womble does just that... it's an exact copy of what is on the dvd disc, and it will join those dvd video files together without any quality loss at all, because it does not re-encode the footage.
Old 6th of February 2009 (Fri)   #9
osv
Travis
look at the file sizes, the vobs are the video files.
vob is an mpeg2 file type.
Old 7th of February 2009 (Sat)   #10
Stealthy Ninja
Sounds cool. I've done a LOT of DVD ripping in my work (clients like to give me trouble I think ). I found AGK (Auto Gordian Knot) is the best on PC for retaining quality (never tried womble though). On the mac, I use Handbrake or 4Media DVD ripper. Depending on what I need to do.
Old 7th of February 2009 (Sat)   #11
Zepher
Zepher's Avatar
Link to a digital camcorder that shoots and records uncompressed video.
Manny Desantos
Intel C2Q Q6600 3.06Ghz, 8GB Ram, 8.1TB, XFX HD5850, Windows 7 Ultimate 64bit, PS CS4 EXT
Canon 40D, EF 28-70L, 2x Canon XH-A1 HDV, Canon HV30 HDV
❶______________________________________
Zepher is offline   Reply With Quote
Old 8th of February 2009 (Sun)   #12
Stealthy Ninja
Granted they compress. But DVD compression is much worse.
This one records at 21 Mbit/s (1920x1080)
http://catalog2.panasonic.com/webapp...odel=AG-HMC150
HDV 1080i uses a recording data rate of 25 Mbit/s.
DVD is 10.5Mbits/s (fastest it can write/record) and is SD anyway.
So I see your point. But it's all about the AMOUNT of compression.
Old 17th of February 2009 (Tue)   #13
gsenthil
try DVDShrink 3.2 Free download from mrbass.org Very easy to use and it wont re-encode unless you ask it to
Canon 6D / Canon T4i / 50 1.4 / 24-70 2.8L / 10-22 3.5-4.5 USM / 580 EX II / Yongnuo YN-568 / 7MDH
gsenthil is offline   Reply With Quote
Old 25th of February 2009 (Wed)   #14
seohadczy
Affordable Hosting for small business.
seohadczy is offline   Reply With Quote
Old 26th of February 2009 (Thu)   #15
Stealthy Ninja
Dude, that sounded pretty familiar...
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
BACKUP FILES ONTO DVD Graybeard Computers 19 7th of October 2008 (Tue) 22:20
access to RAW files on DVD PixelChick78 RAW, Post Processing and Printing 2 22nd of August 2007 (Wed) 20:55
Burn RAW files to DVD EricL RAW, Post Processing and Printing 9 18th of May 2007 (Fri) 12:01
AVI files to DVD mafixit Canon G-series Digital Cameras 4 26th of April 2003 (Sat) 00:42
Joining MVI files nurturer RAW, Post Processing and Printing 0 28th of October 2002 (Mon) 10:30
