Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 4th of February 2009 (Wed)   #1
drPheta
drPheta's Avatar
Default Compact Gitzo Tripod for M10 + 1D + ...?
I have a Marking M10 and have been using it on my G2220EX tripod, but I want something lighter and a bit more compact and will hold a 1D + 70-200/2.8IS or 1D + 100-400IS with no issue. I really don't anticipate acquiring any longer/bigger lenses, but you never know. For simplicity sake, let's say I add the 1.4x TC onto those combinations.
I'd like my setup to be under 5 lbs. if possible. I doubt throwing on the M10 on the Gitzo traveler would make sense, but do you guys have any idea on which Gitzo would fit what I'm looking for?
drPheta is offline   Reply With Quote
Old 4th of February 2009 (Wed)   #2
Wilt
Wilt's Avatar
Default Re: Compact Gitzo Tripod for M10 + 1D + ...?
You're going counter to the conventional recommendation in attempts to use 400mm lens with the combo you are looking for.
Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php
Wilt is offline   Reply With Quote
Old 4th of February 2009 (Wed)   #3
drPheta
drPheta's Avatar
That's what I though, which was why I wanted to see if anyone on this site has found something like what I'm looking for. I know it big lenses and portability don't usually go hand in hand, but I was hoping to keep additional weight down on my backpack for hikes and snowboarding.
*sigh* guess I'll have to go with the bigger tripods.
Old 4th of February 2009 (Wed)   #4
TheHoff
Don't Hassle....
TheHoff's Avatar
I don't think it is a matter of not finding the right model; you can't fight the basic laws of vibrations vs. focal lengths.
Since the EX model is aluminum, you'll obviously save weight by going CF. My Gitzo 3541LS (folds shorter than the 2541) and Markins M-10 is 5.7 pounds, for reference.
••Vancouver Wedding Photographer ••| [gear list] | Latest blog: 5 steps to stopping image loss
TheHoff is offline   Reply With Quote
Old 5th of February 2009 (Thu)   #5
René Damkot
Moderator
René Damkot's Avatar
2 series would (just) work for a 100-400 IMO. (with good technique and circumstances).
Forget about adding a 1.4 TC however.
Why Color Management.
Color Problems? Click here.
MySpace
Get Colormanaged
Twitter
René Damkot is offline   Reply With Quote
Old 5th of February 2009 (Thu)   #6
jhom
jhom's Avatar
I agree. I'm using a 2530 with the M10. I would not recommend going over 300mm on a regular bases. However with good long lens technique, I feel I am able to use the setup when I use my 300 + 1.4TC. If you use a 400+ focal length on a frequent basis, then I would recommend a 3 series Gitzo and an M20. If longer, then you would probably consider a gimbal on the 3 series.
Jim
jhom is offline   Reply With Quote
Old 5th of February 2009 (Thu)   #7
drPheta
drPheta's Avatar
Ok, considering I would probably use the tripod more like a monopod in those long focal length situations I may end up goin with the 2530 or 2540 (or whatever equiv Gitzo has out now). Might go with the 4 section legs for compactness. I wish we had a Gitzo dealer nearby where I could check out the legs. Eventually, I might upgrade to a two tripod system. Get the Gitzo travel and Q3T, and grab a 3 series with an M20. For now, I'll compromise.
Thanks, guys.
Old 5th of February 2009 (Thu)   #8
TheHoff
Don't Hassle....
TheHoff's Avatar
Look closely at the specs of the 3541LS and the 2541... you'll see very little where the 2-series is the better choice, I think. 3541LS has it beat in capacity AND folding length (it is smaller)... just a bit heavier. I was set on the 2541 until I compared them closely. Then you wouldn't have to re-sell in the future.
Old 6th of February 2009 (Fri)   #9
drPheta
drPheta's Avatar
With the 3 series tripod, will my M10 ballhead be enough? I'm thinking it's more than enough.
Old 6th of February 2009 (Fri)   #10
TheHoff
Don't Hassle....
TheHoff's Avatar
It is. It doesn't match at the base as the M20 is the intended head for 3-series but it works perfectly well. I have the 3540LS and the M10
I'd get the M-20 if you intend to go 500mm +
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
WTB: Markins M10 or Q3, Kirk BH3, Gitzo tripod, Elinchrom adamdewilde Classifieds: Buy 0 5th of October 2008 (Sun) 12:47
M10 Ballhead w/Gitzo 2540 marjnap Accessories & Storage 49 16th of April 2008 (Wed) 20:53
Gitzo 1158, M10, what QR clamp, l-bracket? marysia Accessories & Storage 0 10th of July 2007 (Tue) 15:32
Markins M10 vs Gitzo 1377M coorz Accessories & Storage 3 15th of March 2007 (Thu) 06:49
