Reply
Thread Tools Display Modes
Old 13th of December 2002 (Fri)   #1
TibbySF
Default G3 ICC Profile
Where could I get an ICC Profile for the G3?
Thanks,
TibbySF
TibbySF is offline   Reply With Quote
Old 14th of December 2002 (Sat)   #2
Cray
Default Re: G3 ICC Profile
G3 uses sRGB profile ?!?
Cray is offline   Reply With Quote
Old 14th of December 2002 (Sat)   #3
TibbySF
I don't think it does.
And it does not embedd the profile in the picture...
Old 17th of December 2002 (Tue)   #4
gandini
POTN's April Fool!
gandini's Avatar
Default Re: Re: G3 ICC Profile
I'm new to profiles, but I tried a 16-bit linear TIFF from the G3, and used Timo's G2 profile: absolutely useless, just as dark, but redder.
I also tried a D-30 and D-60 profile, but both came out about the same as the G-2.
I'd say the G3 is usually a unique to itself profile. If anyone figures it out (apparently one needs special equipment and software) I'd really appreciate a look at it so I can see what all this linear-TIFF fuss is about.
I had a G1 before that does not offer linear option.
cheers,
gandini is offline   Reply With Quote
Old 29th of December 2002 (Sun)   #5
colin walker
Hi Gandini.
Firstly are you using Canon's software to produce 16-bit Linear files? as you probably know there is a fault in that Canon's software thinks that G3/S45 CRW files are 10bit when in fact they are 12bit so you get over saturated psychedelic colours and not a true Linear file.
If you compile & use the code here:-
http://www2.primushost.com/~dcoffin/powershot/crw.c
You will get a good Linear file to work with.
I have a profile for the S45 Non-Linear & soon will have a Linear one available I will post links in a couple of hours.
Colin
colin walker is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
icc profile anybody? blue_max RAW, Post Processing and Printing 3 20th of September 2005 (Tue) 18:37
G5 ICC profile? phil1 Canon G-series Digital Cameras 0 30th of September 2003 (Tue) 12:47
G3 ICC profile? pukkita Canon G-series Digital Cameras 2 8th of June 2003 (Sun) 17:15
ICC Profile for G2 ljhrusovsky Canon G-series Digital Cameras 1 3rd of May 2002 (Fri) 10:52
ICC profile Reinhard Canon G-series Digital Cameras 6 12th of February 2002 (Tue) 04:28
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
