Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Critique Corner
Reply
Thread Tools Display Modes
Old 5th of February 2009 (Thu)   #1
slm95
Red face 1st try at water shot
My 1st try to running water, I really needed some type of density filter but I do not have one yet. I had to shoot at F36... 1/4th shutter. How is my picture for a noob?
Canon Rebel Xsi - UWA: Sigma 10-20, Regular: Sigma 30 1.4 Macro: Sigma 50 2.8 Telephono: Canon EF-S 55-250 IS
slm95 is offline   Reply With Quote
Old 5th of February 2009 (Thu)   #2
Bobinpeterboro
Default Re: 1st try at water shot
It's a very nice shot and 1/4 sec seems to have worked. Perhaps you could try a lower viewpoint, almost at stream level, which would include more of the upper part of the stream and might make a more dramatic shot?
Bobinpeterboro is offline   Reply With Quote
Old 5th of February 2009 (Thu)   #3
howaboutnow
howaboutnow's Avatar
I quite like it! The water looks very sleek like that
-- Suzanne
Believe in yourself.
Canon EOS Digital Rebel XTi -Canon EF-S Zoom lens - 17 mm - 85 mm - F/4.0-5.6 - Canon EF Lens - 50 mm - F/1.8
Canon EW-78B II Lens hood - Manfrotto tripod (728B)
howaboutnow is offline   Reply With Quote
Old 5th of February 2009 (Thu)   #4
Candor
Candor's Avatar
I would agree with the above post that the composition would work better with a lower vantage point but not bad at all for your first water shot.
Mike
MikesWildLife
flickr
Candor is offline   Reply With Quote
Old 6th of February 2009 (Fri)   #5
Bobinpeterboro
It's a good idea to pack a plastic sheet in your camera bag because then you are much more likely to kneel or lay down when taking the shot, even if the ground is wet or muddy. Just make sure you refold it with the wet side in or it makes an awful mess.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Water drops. 1st try. RX350 Macro 2 28th of July 2007 (Sat) 17:04
1st post and 1st attempt at water drops agentgreen Macro 9 22nd of December 2006 (Fri) 00:35
1st. try at smooth water beachgirl Critique Corner 8 11th of March 2006 (Sat) 12:45
1st go at water drips LordV Macro 10 17th of January 2006 (Tue) 00:33
1st Shot, 1st Post caryj Sports 5 21st of November 2005 (Mon) 09:54
