Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > People Talk
Reply
Thread Tools Display Modes
Old 8th of February 2009 (Sun)   #1
palaima
palaima's Avatar
Default advice, please
hello to all!
Well i am an amateur photographer, i mostly took shots of wildlife (birds, frogs, bugs and so on) and now i have to take some shots for an advertisement of closes, i will be working with a very good model, so that is not the problem, but i don't have any external flash! My only flash is the one installed in my 400D, so i thought maybe i could get away with it by using some other lightsources or is a proper flash needed?
(sr for my english!)
palaima is offline   Reply With Quote
Old 9th of February 2009 (Mon)   #2
Scott-JL
Scott-JL's Avatar
Default Re: advice, please
Ooooh... this is a very open ended question, and a very extensive one. Let's start with your current flash....
The standard flash you have on your camera is very limited. You get very direct light, which is very 'hard' - basically, because you are firing the flash directly at the subject using a bare bulb. This causes hard shadows behind the subject you are shooting if they are close to a wall or background, and also gives you a very flat light on the subject.
Now... you could get away without needed a flash, and just by using the light around you. I've seen many pictures of people which are light by street lights, lamps, light bulbs, etc. The problem here is what you are shooting. If your client wants something a bit edgy, then you could position your model next to a window and use daylight to act as the light source. Or, you could position your model under a house light. If your client wants something more studio-based and cleaner, then you would need proper light sources. The thing you need to do here is get a clear understanding of what the shots should look like.
If you need to go for a 'proper' studio look, then it becomes a lot more complex - you need to get a backdrop, lights to light the backdrop, light sources to light the subject, reflectors, etc. None of this kit is cheap, and you need to know how to use it, both in terms of positioning lights to get the right effect, and more importantly to be able to use them safely.
Fire off some shots of someone you know already using the onboard flash, and get used to what it does. If you know someone with a hotshoe flash, or can rent one, then try it out to see what you can do differently. I'd strongly recommend getting a book about lighting and read up on different terms and what does what, as this will help you alot to both understand light, and understand how it affects your photos.
Good luck with your shoot, I hope this helps.
Scott
Scott-JL is offline   Reply With Quote
Old 9th of February 2009 (Mon)   #3
seaside
Slapped with a ridiculous title
seaside's Avatar
Scott has good advice here. Also, you can use reflectors to bounce natural light sources. You may need help from an assistant to position the reflector.
Chris
Creative Tools / ZENFOLIO
Someone stole all of my photography equipment and replaced it with exact duplicates.
seaside is offline   Reply With Quote
Old 9th of February 2009 (Mon)   #4
palaima
palaima's Avatar
thanks a million! It really helped! This week will be spent solving the problems of lighting in the library
Take care you all!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Need some advice.... BaseballPhotographer Canon EOS Digital Cameras 9 27th of January 2008 (Sun) 19:12
Looking for advice superstes Sports 2 22nd of July 2007 (Sun) 19:05
need advice aladyforty Canon EF and EF-S Lenses 0 5th of October 2006 (Thu) 01:00
any advice? dencirullo Nature & Landscapes 3 4th of October 2006 (Wed) 16:31
Please advice on choosing camera and other advice anh.nguyen@aanntt.com Canon EOS Digital Cameras 11 11th of April 2003 (Fri) 20:23
