| sponsored links |
Thread Tools | Display Modes |
#1 |
My question is really, are the noise reduction inside a camera such as a XSI software only and in post-processing? If so, since I'm going to use noise ninja anyway for high iso picture, should I just leave all the job to the software?
Also, I always shoot in raw. Last edited by [shingo] : 10th of February 2009 (Tue) at 09:14. |
| sponsored links |
#2 |
I believe the in camera noise reduction is in post-processing, so yes, you are probably better off doing it with more control in your own software. I don't have that software, so I find the in camera modes handy.
#3 |
Much like sharpening an image, it is best to take many small steps and not one large one.
Leave the NR on in the camera and run the NN later (sometimes twice) Better yet, shoot RAW and then play around to see what works best for you. In Digital Photo Pro (should have come with your cam) you can emulate everything the "in camera" software would do to a file and see the results at your leisure. You can then undo it and try another set of settings on the original RAW file. Great way to learn. |
| sponsored links |
#4 | |
I always shoot in raw, much more flexibility, who care about disk space, storage cost 1$ per 10 gig, not much of a problem. |
#5 |
Anyone else has some experience with this?
#6 |
I think the in camera NR is not that good...I've tried this on 5D Mark II anyway. I basically turn it off and use Dfine to selectively remove noise.
#7 |
Shoot in RAW. I see no reason to limit yourself by shooting in JPEG. I mean, some of the pro's do it all the time because they get a perfect exposure/framing every time they click the shutter. For the rest of us there's Lightroom/Photoshop/GIMP.
#8 |
Does the noise reduction also work in Raw? I don't understand why everyone assume that I don't shoot in RAW?
#9 |
Fatal attraction.
No, the NR does not get done to a RAW, it's part of the conversion to jpg. Like all the other in-camera settings DPP reads the metadata flag to set its default NR (if you have it set in Preferences to do so). Other converters can't see the flag but have their own defaults. So it makes no sense setting NR in the camera if you shoot RAW unless you use DPP and can't spare a couple seconds to find the best NR setting.
Elie / אלי "If you presume to love something, you must love the process of it much more than you love the finished product." John Irving, 5/2012. "In theory there is no difference between practice and theory, but in practice there is." Yogi Berra Site |
#10 | |
During the processing of a RAW to a viewable picture file, things like sharpening, NR etc can be applied. But the RAW itself is never changed. As tzalman's reply states. I don't get all the RAW shooters who insist on shooting in it, but don't really understand what it is. But I suppose you don't need to, so long as you understand what it can do for you. Last edited by mrkgoo : 10th of February 2009 (Tue) at 12:13. |
#11 |
I have three bodies, 1Ds II, 40D and XTi. I have the noise reduction off on all of them and I shoot at ISO 800 and above all the time, also setting your contrast and sharpening in the camera to a low or negative number will save a lot of detail, you can sharpen and add contrast post production but there is less of a chance of loosing important highlight and shadow detail. Also the internal noise reduction will remover detail, image quality and sharpness
#12 | |
Ewan (has spent far too much time measurbating Noise Ninja this week...)
Never attribute to malice that which can be adequately explained by stupidity — Hanlon's Razor site smugmug gear |
#13 |
i have to disagree that multiple repeated noise reductions can beat one good one. this might be possible if the many steps work in different ways but there is no way repeated use of the same process can give better results than one correct usage. the math cannot support that, too much info is lost at each step that cannot be recovered.
#14 |
With the flexNR it does a two step process on the higher ISO's for NR for my 1dmkIII.
Using Neat image with my other bodies it works extremely well. I shoot mainly jpeg and have had excellent results. Put it in print and you wouldn't see a huge difference from a raw shooter IMO. I'll shoot raw when I feel its imperative but I seldom ever have issues recovering any jpg exposure files. All I say is dont over expose the heck out of jpgs and you'll be just fine. I would try both NR on/off in camera and see for yourself what gets you the best results. I keep it on but I seldom shoot over ISO 3200.
5DmkII x 2 | 5Dc | XTI | 24LmkII | 35L |50mm f/1.4 | 85mm f/1.8 | 85 mkII L | 100L | 16-35L mkII | 24-70 f/2.8L | 70-200 f/2.8 ISL mkII| 100-400L | 600EX-RT x2 |580 EX II x2 | 430EX II | AB cybersycns | PW FlexTT5x4 | AC3 | Einstein's | Cybercommander | Vml's | PW Power MC2 Last edited by AlanU : 7th of April 2010 (Wed) at 11:37. |
| Thread Tools | |
| Display Modes | |
| Noise Ninja vs. CS3's noise removal filter | GM_of_OLC | RAW, Post Processing and Printing | 12 | 22nd of July 2008 (Tue) 23:48 |
| Noise Ninja plasticy reduction help! | big_apple_ken | RAW, Post Processing and Printing | 23 | 14th of July 2008 (Mon) 11:42 |
| Noise Reduction Noise Ninja v Neat Image | Chris Nicola | RAW, Post Processing and Printing | 9 | 18th of July 2007 (Wed) 20:05 |
| Noise Ninja vs CS2 noise reduction | **luvmygirlz** | RAW, Post Processing and Printing | 4 | 31st of July 2006 (Mon) 10:30 |
| Noise Reduction set to off. Por Que? | learjet035 | Canon EOS Digital Cameras | 10 | 13th of May 2005 (Fri) 20:11 |
