Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Transportation Talk
Reply
Thread Tools Display Modes
Old 10th of February 2009 (Tue)   #1
cellg8
Default Can 3 Canon Speedlites light a car?
Hi all,
I'm new to this forum... I have some speedlights and don't want to spend money on Alien Bees right now (rough economy). So I wanted to make the best out of what I already have. I have 580EX & EXII's.
My questions are:
1) Are 3 speed lights enough to light a car?
2) What is your set up as far as hooking PW's to these speedlights? Velcro?
3) How high do you generally place your lights? Up high or on the ground?
Any other tips are great appreciated...thank you all in advacne!
cellg8 is offline   Reply With Quote
Old 10th of February 2009 (Tue)   #2
StreamlineGT
StreamlineGT's Avatar
Default Re: Can 3 Canon Speedlites light a car?
I have 3 flashes, and they do fine. I've heard that height is key, but depending on the subject, height and placement may vary to prevent reflections in the body. I'm not sure how to hook up all your flashes, but light stands are a must. What is a PW?
Brendon.
Gear list
StreamlineGT is offline   Reply With Quote
Old 10th of February 2009 (Tue)   #3
tkoutdoor
tkoutdoor's Avatar
Location: Feeding my camera somewhere in Western Washington
PW = Pocket Wizard (radio trigger for activating flash)
If it can be done, these guys will know how... they do everything and then some with hotshoe flash.
http://www.strobist.blogspot.com/
Canon ~ 7D, 1D MkIIn, 5D, 20D, 10D, 100-400L IS, 70-200 2.8L IS, 24-105 f4L IS, 17-40 f4L, 135mm f2L, 85mm 1.8, 50mm 1.4, 50mm 2.5 macro, Ext. tubes, TC's 1.4 & 2.0, Feisol 3441-S CF Tpod, Gitzo Traveler Mpod, Acratech ballhead, 550EX, 200EG bag, Epson Pro 3800 printer.
tkoutdoor is offline   Reply With Quote
Old 10th of February 2009 (Tue)   #4
cellg8
Thank you, Brandon. PW = Pocket Wizard..sorry...thanks!
Old 10th of February 2009 (Tue)   #5
StreamlineGT
I should have known that, I have some LOL.
Here's what my list would consist of....
3 - light stands at least 8' I would say.
3 - umbrella brackets
4 - PW's
3 - falsh zebra hot shoe adapters.
Are you asking how to attach the PW to the stand, or how to hook them up to the flash?
Brendon.
Gear list
Old 10th of February 2009 (Tue)   #6
cellg8
Thank you, Brendon... Looking for a secured way to hook PW to flash.. the core that comes with it seems flimsy...
Old 10th of February 2009 (Tue)   #7
cellg8
Btw, do you have any samples/set ups of how you light the car with 3 flashes?
Old 10th of February 2009 (Tue)   #8
StreamlineGT
what I normally do is just hang the PW, using the strap that comes with it, on one of the handles on the umbrella bracket. I don't have them rigidly mounted.
Brendon.
Gear list
Old 10th of February 2009 (Tue)   #9
StreamlineGT
http://photography-on-the.net/forum/...d.php?t=635579
These are a little dark, but not because it wasn't enough light, I had the flashes turned down too much. this is the first time I've done this, so not sure if this is the correct way, but they came out ok.
Brendon.
Gear list
Old 10th of February 2009 (Tue)   #10
cellg8
Thank you, Brandon for your input and examples! Awesome!
John
Old 10th of February 2009 (Tue)   #11
lambocars
lambocars's Avatar
Hello,
take a look at this one : http://photography-on-the.net/forum/...d.php?t=643210
I used two 580EX II at 1/4 power triggered with Elinchrom SkyPorts ... I will be adding two more 430EX II's to my setup soon, but as you can see, even with two you can reach some degree of lighting.
lambocars is offline   Reply With Quote
Old 10th of February 2009 (Tue)   #12
cellg8
Lambocars, these are awesome! Where and how high did you place them? Thanks... I tried using 2 but no way it would like the whole car for me...
Old 10th of February 2009 (Tue)   #13
SnlpeR
IMO...8ft stands for cars outdoors is sometimes just not high enough
SnlpeR is offline   Reply With Quote
Old 10th of February 2009 (Tue)   #14
lambocars
lambocars's Avatar
The front 3/4 shot actually had two 580EX II on stands (2 feet high, 1/4 power) pointed towards the car straight on the wheels (both front and rear), and a second exposure (because of two angles for the polar filter) I moved one flash to the front of the car (same stand, about 2 feet high again 1/4 power) and left the second on the front wheel. Combined exposures in photoshop.
The rear 3/4 shot I had one 580EX II on the floor pointing towards the corner of the rear bumper (you can see the light on the tire) and the second 580 EX on 1/2 power at the middle of the doors. In this shot I did remove some specs that showed the flashes, but that only took about a minute or so.
All shots were done with bare flash, no umbrella or other modifier.
Old 10th of February 2009 (Tue)   #15
cellg8
Thank you, Lambo!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Anyone using speedlites to light large softboxes? Hazey Small Flash and Studio Lighting 21 2nd of December 2008 (Tue) 15:50
Canon Speedlites paintman34 Small Flash and Studio Lighting 5 1st of October 2007 (Mon) 18:45
Modeling Light w/ ST-E2 and Canon SpeedLites themirage Small Flash and Studio Lighting 1 22nd of January 2006 (Sun) 05:46
Speedlites enough light? Burrellimages Small Flash and Studio Lighting 25 7th of November 2005 (Mon) 04:01
