Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Digital Video
Reply
Thread Tools Display Modes
Old 11th of February 2009 (Wed)   #1
Fire-n-Gin
Fire-n-Gin's Avatar
Default Photo Frame Pic Size HELP?
Hi Gang!
Santa brought us a new photo frame this year and I've been watching the skewed photos flash on it for over a month now and I've had enough. I called the "help center" for the manufacture and were no help so I bring it to you...
I have a Nextar N7-202 photo frame and wondering what size photos that I can load into it and make them not distort. And then what settings the frame needs to be on...
Thanks in advance for the help, you guys are the best.
Rodd
Canon EOS Rebel XSi
EF-S 18-55mm f/3.5-5.6 IS
EF-S 55-250mm f4-5.6 IS
Battery Grip BG-E5
http://s495.photobucket.com/albums/rr313/Fire-n-Gin/
Fire-n-Gin is offline   Reply With Quote
Old 14th of February 2009 (Sat)   #2
Zepher
Zepher's Avatar
Default Re: Photo Frame Pic Size HELP?
Image resolution up to 480 x 234, so use that size and you should be fine.
Manny Desantos
Intel C2Q Q6600 3.06Ghz, 8GB Ram, 8.1TB, XFX HD5850, Windows 7 Ultimate 64bit, PS CS4 EXT
Canon 40D, EF 28-70L, 2x Canon XH-A1 HDV, Canon HV30 HDV
❶______________________________________
Zepher is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Frame Size kbreit RAW, Post Processing and Printing 7 16th of September 2008 (Tue) 08:56
What size frame? greatshot RAW, Post Processing and Printing 3 13th of May 2008 (Tue) 09:43
Digital Photo Frame Image Size smokingolf Accessories & Storage 2 17th of December 2007 (Mon) 18:41
Size choices missing when there is no photo frame (NOT A BUG) calvorn EE 2 Bugs 4 30th of October 2006 (Mon) 12:36
Vewfinder image size vs actual pic size? muscleflex Canon EOS Digital Cameras 10 20th of June 2005 (Mon) 05:34
