#1 |
Which one should I get? Looks like the 3021pro will hold an additional 2.2lbs over the 3001pro. Is that the only advantage?
| sponsored links |
#2 |
hi,the 3001 is not as tall,but a bit lighter.
#3 |
ishka bibble
Location: Andover, CT...................... Go Red Sox!
The 3021 has a reversible center column - a plus for macro photography.
| sponsored links |
#4 | |
#5 | |
ishka bibble
#6 |
I have the 190 Pro which I believe is the same as the 3021 pro. IT has a columb than can be removed and re-inserted either horizontally or reversed. A very versitile pod and I have recently started uing it for macro with pretty good results
(shame my macro photography stinks though
If in doubt, I shut up... Gear: 40D, 12-24mm AT-X Pro, 17-85mm, Sigma 150mm Macro Sigma 100-300 F4, 550EX, other stuff that probably helps me on my way. |
#7 | |
ishka bibble
#8 | |
Manfrotto 055 Pro is the same as Bogen 3021 Pro |
#9 |
My mistake
At least that leaves the question answered
#10 | |
I had a 055 DB (= 3021 DB?) first, because the shop gave me the wrong tripod (I ordered a 055 Pro B). The DB did not have a removeable center column. I sold the DB and bought the 055 Pro B (at another shop ofcourse...). Edit: Oh wait, now I remember better what my 055 DB looked like. Yes, you could reverse the center column. The idea was that you would hang the camera upside down between the legs. Not very practical at all! The 055 Pro B is MUCH better, because you can take off the long part of the center column and fold the legs almost all the way to the ground, or you can even place the center column horizontally. Much more practical for close to the ground macro photography. I think the 3001 (190) is just a smaller, lighter version of the 3021 (055). The 3001 Pro should have the same features as the 3021 Pro, but you'd better check it out on Manfrotto's website. The 3021 (055) is more than sturdy enough for my 10D. The 3001 will surely be good enough for the 300D.
Please visit my gallery! Canon EOS 5D EF 24-105 f/4 L IS, EF 70-200 f/4 L IS, EF 35 f/2, EF 50 f/1.8 II, EF 100 f/2.8 Macro USM Extender EF 1.4x II, Speedlite 550EX Last edited by Jesper : 29th of March 2005 (Tue) at 11:17. |
#11 |
Thanks for the responses.
I checked out the maximum extended heights for both tripods and looks like the 3001pro will be a tad short for my height. The 3021pro will be perfect (I'm 5'11''). |
#12 |
Canon Fanosapien
I went for the 3021 solely for the height advantage. If i'm not mistaken, it also has a bit more weight capacity.
Tom 5D III, 7D, & various lenses |
| Thread Tools | |
| Display Modes | |
| Manfrotto 190Pro+141RC (Bogen 3001Pro+3030) combo | Olegis | Canon EOS Digital Cameras | 13 | 2nd of December 2010 (Thu) 21:22 |
| Manfrotto 190Pro Bogen 3021Pro? | Ephemeral | Accessories & Storage | 6 | 20th of September 2006 (Wed) 04:09 |
| help with Bogen 3021Pro | vjack | Accessories & Storage | 13 | 11th of July 2006 (Tue) 05:51 |
| 3001Pro vs 3021Pro ????? | mtndew | Accessories & Storage | 13 | 2nd of April 2005 (Sat) 14:24 |
| Manfrotto 190Pro+141RC (Bogen 3001Pro+3030) combo | Olegis | Canon EOS Digital Cameras | 0 | 17th of August 2004 (Tue) 08:24 |
