Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Transportation Talk
Reply
Thread Tools Display Modes
Old 16th of February 2009 (Mon)   #1
gdusek84
Default Shooting from a fixed wing aircraft
OK I did a search and found a few helpful things but I'm seeking more advice. I have a friend who will be taking me up in a smaller twin engine fixed wing aircraft here in a few days to get some aerial shots. The kicker is we're not going up till 7:30-8:00pm at night when it's dark. The good thing is I'll be getting shots of downtown Dallas all lit up, as long as our weather holds. I'm shooting with a 30D and will more then likely be taking my 85mm 1.8 and my 28-135mm 3.5-5.6. Now with that being said any recommendations on camera settings to help me out? Since it'll be dark I'm going to attempt to start off shooting at 400 ISO and go from there. I figure if needed I'll dial in some exposure compensation first before bumping up the ISO. Any input as to what metering I should use?
Any other comments or tips would be greatly appreciated.
gdusek84 is offline   Reply With Quote
Old 17th of February 2009 (Tue)   #2
PhotosGuy
Moderator
PhotosGuy's Avatar
Default Re: Shooting from a fixed wing aircraft
The kicker is we're not going up till 7:30-8:00pm at night when it's dark.... The good thing is I'll be getting shots of downtown Dallas all lit up,
Some of the best "night shots" I've seen were taken before it's totally dark while there's still some light left in the sky. You don't need much, but you need some. So try to shoot as early as you can.
Manual, only. Go out on a night before & see what works at 1/200 sec, f/4-5.6, ISO?
f/4-5.6 because you will be shooting at infinity & don't have to worry about depth. Depending on altitude, even f/2 might be OK.
Depth-of-field
But if you want to see more than just lights, you'll have to find a setting that will give you both well exposed lights & maybe still see some of the buildings at the other end of the exposure. The histogram will help there. Just chimp the lights up to the right side, no more. There are some links in Need an exposure crutch? on page 2 I think.
Safety in the Skies: Flight Plan for a Successful Aerial Photography Career
Aerial Photography
www.FrankCizek.com
PhotosGuy is offline   Reply With Quote
Old 17th of February 2009 (Tue)   #3
gdusek84
Frank I really appreciate the input. This is a big help and I'm really looking forward to going up... as long as our weather holds.
Old 19th of February 2009 (Thu)   #4
gdusek84
I learned sooo much last night and had a good experience overall. After reviewing the photos there were only a couple that I considered keepers, but I'm very very critical on my photos. I definitely have a better understanding of how I need to shoot for better photos next time. Here's a pic I took last night with a little pp to fix it up, exif should be in there.
Old 20th of February 2009 (Fri)   #5
PhotosGuy
Moderator
PhotosGuy's Avatar
It looks pretty good on my laptop.
# Exposure Time (1 / Shutter Speed) = 1/60 second = 0.01667 second
# Lens F-Number/F-Stop = 35/10 = F3.5
# Exposure Program = shutter priority (4)
# ISO Speed Ratings = 3200
Looks as if you were right on the ragged edge, there! What's going on at the top of the image?
www.FrankCizek.com
Old 21st of February 2009 (Sat)   #6
gdusek84
That's the reflection off the wing. Some said it's too distracting and I have a shot with it cropped out, but I kinda liked it being in there. If I lighten the image the wing really stands out more but the rest of the picture looks bad.
Old 22nd of February 2009 (Sun)   #7
PhotosGuy
Moderator
PhotosGuy's Avatar
Got it! If you like it, then keep it, but I'd crop it out.
www.FrankCizek.com
Old 23rd of February 2009 (Mon)   #8
gdusek84
My theory on keeping it in there was because the pictures looks funny with the wing cropped out. You see the city lights from the background going almost to the top of the building which makes it look like there's no sky. Maybe a more shallow crop where you see more of the wing would fix it?
Old 23rd of February 2009 (Mon)   #9
FlyingPhotog
Cream of the "Prop"
FlyingPhotog's Avatar
@ OP: Great image.
A sneaky little trick you might consider (if you have the processing chops): Put the reflection off the underside of the wing on it's own layer and rotate only the reflection so that the lines of green neon are paralell to the ones on the actual building.
FlyingPhotog is offline   Reply With Quote
Old 23rd of February 2009 (Mon)   #10
gdusek84
Originally Posted by FlyingPhotog View Post
@ OP: Great image.
Thanks for the tip. I'll give that a try tonight.
Old 23rd of February 2009 (Mon)   #11
gdusek84
Oh and another thing I learned... WAKE TURBULENCE.... definitely not something you want to run into from a 737 from two miles out when you're up in a single engine Cessna. My pilot told me we were in a 20 degree bank when the wake turbulence hit us, we caught a down draft and dropped about 30-40 ft in altitude in a matter of seconds. Needless to say I wasn't expecting that and just about had to change me drawers.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Need help shooting a small aircraft interior kingdaddy General Photography Talk 13 7th of March 2009 (Sat) 11:09
shooting from aircraft garyo Canon EF and EF-S Lenses 25 6th of December 2008 (Sat) 05:26
Wing Shooting with Evening light hTr Birds 37 13th of October 2007 (Sat) 06:23
Shooting Aircraft Faelan General Photography Talk 9 18th of March 2007 (Sun) 17:27
Shooting sport with fixed focal length Apemaster Sports Talk 3 11th of December 2006 (Mon) 12:45
