Reply
Thread Tools Display Modes
Old 29th of July 2001 (Sun)   #1
delboy
Default 22 hot pixel
I recieve my G1 for a few days and following hot pixel test on the camera.
I want to ask someone with experience in G1, should I reject this camera or just keep it since not every camera is perfect. Does 22 hot pixel create a big problem?
I test the camera with ISO100 for 1 sec and the hot pixel appear on the low right hand side 1500, 993.
And in shutter speed 1/30 only 1 hot pixel.
Many thanks
Delboy
delboy is offline   Reply With Quote
Old 30th of July 2001 (Mon)   #2
Koponen
Default Re: 22 hot pixel
Check this out. It's done with CP990 instead of the G1, but the basic information and the points of view are very good. Cheers.
http://webpages.charter.net/bbiggers...ot_pixels.html
Koponen is offline   Reply With Quote
Old 6th of August 2001 (Mon)   #3
dbookbinder
For comparative purposes, I just tested my G1. Using the eyeball test, I can see no hot pixels at a 1-second exposure using ASA 50, though the DeadPixelTest.exe program tells me there are several hot pixels there.
If you can actually see 22 hot pixels (or even one hot pixel) on shots you are likely to take, that seems like a lot and Canon will fix the camera. If they are merely indicated by the DeadPixelTest program and you can't see them, then in my opinion you don't have a problem. I gather, from other people's experiences, that Canon is good about fixing this problem either by mapping out the hot pixels, replacing the CCD, or replacing the camera.
- David
dbookbinder is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
hot pixel lonecc Canon EOS Digital Cameras 10 25th of October 2005 (Tue) 10:09
Dead Pixel, Hot Pixel, or Just a JPEG Anomaly???? ruettgers Canon EOS Digital Cameras 11 12th of June 2005 (Sun) 21:02
HOT pixel ? Daya Canon G-series Digital Cameras 1 27th of October 2003 (Mon) 11:29
hot pixel stephano Canon G-series Digital Cameras 10 1st of April 2003 (Tue) 15:25
Looks like i have a hot pixel :((( yikes Canon G-series Digital Cameras 5 22nd of February 2003 (Sat) 21:35
