Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Macro
Reply
Thread Tools Display Modes
Old 18th of February 2009 (Wed)   #1
jc_casper
jc_casper's Avatar
Default Salt Water
I found it difficult to get a sharp shot. I'm really new at macro, DOF and everything else. I guess I should expect these to get better overtime.
1.
-f/9.0, Shutter 1, ISO 200, NO FLASH
2.
-F/5.6, SHUTTER 1/125, ISO 400, NO FLASH
3.
-F/32.0, 0.8, ISO 200, NF
4.
-F/4.0, 1/60, ISO 400, FLASH ON
5.
-F/2.8, 1/40, ISO 200, FO
6.
-F/10.0, .6, ISO 200, NF
7.
-F/2.8, 1/40, ISO 400, NF
C&C WELCOME
"Carpe Diem"
Canon Rebel XT, 28-200mm f/3.5-5.6 USM, 100mm f/2.8 Macro USM
jc_casper is offline   Reply With Quote
Old 18th of February 2009 (Wed)   #2
LordV
LordV's Avatar
Default Re: Salt Water
These are pretty good for tank shots. Apart from obvious lighting/aperture/DOF problems you also get significant distortion from the glass. Ideally you need the lens at right angles to the tank glass and the subject as close as possible to the glass to minimise these distortion effects.
Brian V.
http://www.flickr.com/photos/lordv/
http://www.lordv.smugmug.com/
Macro Hints and tips http://photography-on-the.net/forum/...d.php?t=807056
Canon 20D, Canon 40D, Canon 5D mk2, Sigma 105mm EX macro, Tamron 90mm macro, Canon MPE-65,18-55 kit lens X2, canon 200mm F2.8 L, Tamron 28-70mm xrdi, Other assorted bits
LordV is online now   Reply With Quote
Old 18th of February 2009 (Wed)   #3
Nuke812
Try using a tripod to steady your camera. I took some at Coney Island aquarium which was pretty dark and used the glass of the tank to hold my camera steady. Also shot at 1600 iso to get fast enough shutter speeds though they were only about 1/20 to 1/40. Shot with XTi, F/5.6
Nuke812 is offline   Reply With Quote
Old 18th of February 2009 (Wed)   #4
nemo man
As Brian said, these are pretty good considering the limitations of glass etc. Have you tried it with a polarizing filter on the lens? It will often reduce some of the through-glass problems, and may also boost colours.
nemo man is offline   Reply With Quote
Old 18th of February 2009 (Wed)   #5
jc_casper
jc_casper's Avatar
Thanks for the tech tips. I haven't tried it with a polarized filter... I need to get one.
"Carpe Diem"
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Lens for Salt water Aquarium Photography Natclanwy Canon EF and EF-S Lenses 18 19th of March 2011 (Sat) 14:08
a kid taking a salt water shower phocalphobe People 24 15th of March 2007 (Thu) 20:59
Salt water air and beach - care PaCiFiSt Canon EOS Digital Cameras 10 29th of January 2006 (Sun) 10:31
Salt water residue on lens JasonMX General Photography Talk 1 14th of December 2004 (Tue) 15:06
Salt water on MkII? Cleaning? CyberDyneSystems The Business of Photography 12 1st of September 2004 (Wed) 15:22
