Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EF and EF-S Lenses > Lens Sample Photo Archive
Reply
Thread Tools Display Modes
Old 20th of February 2009 (Fri)   #1
Tony-S
Tony-S's Avatar
Default Sigma 24-70 f/2.8 EX HSM
The new HSM model is now available, and I'm still learning how to use it...
Here's a shot at 70mm, f/2.8, 1/80", ISO 200 on the 5Dii with the 580EX II and Stofen attached. The lens is capable of very creamy bokeh, is a little warm, but easily managed. In this shot, I bumped up the blue channel +15, did a curves adjustment with just the tiniest 'S' curve, then did a 100/2/3 unsharp mask. EXIF data should be intact.
Gear list
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
Beginner's guide to printing.
The PoTN film thread. 
Tony-S is offline   Reply With Quote
Old 24th of February 2009 (Tue)   #2
joruiz
joruiz's Avatar
Default Re: Sigma 24-70 f/2.8 EX HSM
wow.. almost $500 more for HSM?? that's insane!!
is there any other advantage over the non HSM version?
joruiz is offline   Reply With Quote
Old 24th of February 2009 (Tue)   #3
Tony-S
Tony-S's Avatar
I think they're principally aiming it at the Noink crowd (almost $1,700 for their 24-70 f/2.8 ), but keeping it in range of the brick ($1,200) for us Canon folk. I suspect it'll be down to $800 or $750 in a year from now. But it's tough to know for sure.
It is more compact (it's tiny compared to the brick) and supposedly has better optics. I've not seen the non-HSM model so I cannot provide a direct comparison. The zoom is also in the opposite direction from the non-HSM (and now the same as Canon's). It sure feels beefy. I'm hoping to get out for more shots, but work has me rather swamped ATM.
Gear list
Old 25th of February 2009 (Wed)   #4
4g63photo
4g63photo's Avatar
How is the weight on this lens? How about the build and quality?
I was looking at it on the BH site. It looks small.
-Fernando-
Flickr
4g63photo is offline   Reply With Quote
Old 26th of February 2009 (Thu)   #5
Tony-S
Tony-S's Avatar
It is very nice and compact - a lot smaller than the brick and Noink's 28-70. It has the typical Sigma EX build and feels quite solid.
Gear list
Old 26th of February 2009 (Thu)   #6
bReed
User is banned from forums
post more pictures i want to get lens!
bReed is offline   Reply With Quote
Old 26th of February 2009 (Thu)   #7
engrmariano
engrmariano's Avatar
can you post unprocessed image at 100% crop?
tanks in advance...
The Filipino is worth dying for -> Ninoy (Nov. 27, '32 - Aug. 21, '83)
I'm ready to defend the 3 stars & the sun -> Francis M. (Oct 4, '64 – Mar 6, '09)
fLickr
geavity
engrmariano is offline   Reply With Quote
Old 26th of February 2009 (Thu)   #8
Tony-S
Tony-S's Avatar
Here's a full-frame (5Dii) and 100% crop unprocessed at f/2.8 and 70mm. I don't have too many others yet. It is warm, which is typical of Sigma lenses, but otherwise I'm very, very pleased with it.
Gear list
Old 26th of February 2009 (Thu)   #9
Tony-S
Tony-S's Avatar
This 70mm series is from f/2.8 to f/8, shot from a bit further away than the previous images (around 8 feet to subject) on the 5Dii. Other than levels adjustment, no pp applied. As you can see, contrast and sharpness improve as the aperture gets smaller.
f/2.8:
Gear list
Old 26th of February 2009 (Thu)   #10
Tony-S
Tony-S's Avatar
f/4:
Gear list
Old 26th of February 2009 (Thu)   #11
Tony-S
Tony-S's Avatar
f/5.6:
Gear list
Old 26th of February 2009 (Thu)   #12
Tony-S
Tony-S's Avatar
And f/8:
Gear list
Old 28th of February 2009 (Sat)   #13
Tony-S
Tony-S's Avatar
I've spent some time with the lens today and here are a few observations:
1. The lens has excellent control of chromatic aberration - there is virtually none.
2. It has excellent flare control (better than my 17-40L) and the hood does a very good job of mitigating flare.
3. It vignettes at 70mm until f/8, and 50mm until f/4.
A couple from today.
Gear list
Old 28th of February 2009 (Sat)   #14
Tony-S
Tony-S's Avatar
And a couple more.
Gear list
Old 28th of February 2009 (Sat)   #15
jcp2000
jcp2000's Avatar
i wish i had enough for the hsm one aha i had to settle for the macro its so noisey!! but ehh it works. im liking the samples in here already, might have to upgrade to this one in the future
Canon 400Dx2, Sigma 24-70 f2.8 EX DG, Vivitar 285HV, AlienBees B800, Vagabond II, Cactus V2s, SLIK Able 300 DX
jcp2000 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
SIGMA 18-50/2.8 HSM & 17-70 HSM northernlight Canon EF and EF-S Lenses 15 27th of July 2007 (Fri) 00:14
New Sigma 18-50 HSM and 55-200 HSM goatee Canon EF and EF-S Lenses 17 10th of July 2007 (Tue) 09:10
Sigma 70-200mm F2.8 HSM + 1.4 tcon vs. Sigma 100-300mm f/4 HSM priority #1 =mosport rbush83 Canon EF and EF-S Lenses 4 31st of October 2006 (Tue) 12:49
First pic taken w/ 120-300mm Sigma F2.8 EX/HSM/HSM Canuck Canon EF and EF-S Lenses 28 25th of November 2003 (Tue) 12:21
