Reply
Thread Tools Display Modes
Old 17th of December 2002 (Tue)   #1
SeanG
Default HELP!!! My battery won't charge...
Hi everyone,
I've just joined the forum. I love the internet. There is a forum for just about everything.
I have a problem with my charger or battery. I went to take a photo of my dogs last night and I couldn't turn on the camera. I couldn't turn it on in shoot mode or play mode. There was no power whatsoever.
I plugged the AC adapter in and was able to take a few photos and review what was on the card. BUT, I couldn't get the battery to charge. Usually I will see an amber light that blinks at different speeds to tell you how full the charge is and it will turn green when it's done. Well, no light ever came on.
I opened and closed the battery door and took the battery out to make sure it was seated properly but no luck.
Does anyone know what might be the problem and how to fix it?
Thanks,
Sean
SeanG is offline   Reply With Quote
Old 17th of December 2002 (Tue)   #2
trammd
Default Re: HELP!!! My battery won't charge...
Be sure and turn the power switch to OFF when charging the battery. The battery won't charge if the camera is in "shoot" or "playback" modes.
trammd is offline   Reply With Quote
Old 17th of December 2002 (Tue)   #3
topher
you probably charged it too often. all batteries lose there charging capability if you dont drain them enough.
topher is offline   Reply With Quote
Old 18th of December 2002 (Wed)   #4
SeanG
I have only charged it, maybe, 10 times.
And when I charge I always make sure that the camera is set to the "OFF" position.
Any other thoughts?
Could I have blown a fuse that controls the charging?
Sean
Old 18th of December 2002 (Wed)   #5
valyau
Have you got the latest version of firmware loaded into your G2? If not then it maybe worthwhile to load it on. It can be found here:
http://www.canon.co.jp/Imaging/PSG2/...irmware-e.html
Also make sure the CF door is properly closed as well as it will stop any charging process if it is open.
valyau is offline   Reply With Quote
Old 19th of December 2002 (Thu)   #6
datawatch99
Probably the CF door not closed.... that little door has caused me all sorts of grief thinking something was wrong with my camera. I dont know why Canon couldn't put a CF card detector instead of a door open/closed detector on the camera. Guess they didn't want you to take a picture and pull the card out during mid-write.
datawatch99 is offline   Reply With Quote
Old 19th of December 2002 (Thu)   #7
datawatch99
Old 19th of December 2002 (Thu)   #8
SeanG
Thanks everyone. I'll test the CF door again and try the firmware update. I'll let y'all know tonight.
I may also try a different battery. Can anyone suggest one that is better than any other? I guess I could search for one too hugh?
Sean
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
First battery charge Shoehorn O' Plenty Accessories & Storage 4 21st of June 2006 (Wed) 16:19
battery doesn't seem to charge IIIMik3 Accessories & Storage 3 27th of June 2003 (Fri) 12:19
G2 first battery charge wilson_jm Canon G-series Digital Cameras 6 18th of April 2003 (Fri) 15:57
Battery charge 2a2b Canon G-series Digital Cameras 2 12th of April 2003 (Sat) 10:32
first charge of battery 717driver Canon G-series Digital Cameras 2 25th of February 2003 (Tue) 17:31
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
