Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Glamour & Nude Talk
Reply
Thread Tools Display Modes
Old 23rd of February 2009 (Mon)   #1
trailblazer
trailblazer's Avatar
Default Lighting setups when using models
Hi guys,
Let's say you have a model and you have just setup your lighting using speedlights. You are using 3 lights: hairlight/kicker, background light and key light.
Your model poses for you and you take pictures accordingly but then they change poses such that the your setup no longer complements the pose.
What do you do?
Break the flow and reposition the lighting?
Continue shooting and see what comes of it?
If you stop to reposition the lighting, how quickly do you do this?
Do you then have to do some more chimping and then reposition to suit?
Then finally, the situation is a rinse-and-repeat where you finally got things back into place and then the model does another interesting pose that once again brings you back to this dilemma.
How do you people who shoot models all the time handle this?
trailblazer is offline   Reply With Quote
Old 23rd of February 2009 (Mon)   #2
TooManyHobbies
TooManyHobbies's Avatar
Default Re: Lighting setups when using models
Break the flow or have a lighting setup that allows you to do whatever without affecting lighting. Strobes work best for this since you'll need a very large source of light. Buy expensive softboxes or make a U-bank reflector and get a 16'x8' light source for $75, you'll still need to buy the lights and WB card, and light meter. You can also use wall if light enough.
As for hair light, if you can mount it above the background aimed above you, you'll have a large area to work with. just move the model back and forth depending on her pose height to get her hair lit right.
~ Jeff
Canon EOS-1DX & 1Ds MkIII, 20D(IR), G12, G9, G5, ... Gear List
JMM Photography ~ Discovering Art in Everyday Life | Model Mayhem #675060
TooManyHobbies is offline   Reply With Quote
Old 24th of February 2009 (Tue)   #3
trailblazer
Thanks Jeff
Old 24th of February 2009 (Tue)   #4
TooManyHobbies
Forgot, this doesn't work very well dark backgrounds due to light spill, but still can with some creative thinking and enough room to seperate background from subject.
~ Jeff
Old 25th of February 2009 (Wed)   #5
Coastwatch203
Coastwatch203's Avatar
Youve got to, got to, got to, keep control in a shoot.....!!!
Your wasting your time if a model moves to where you know your lights arnt doing what you want them to...Even if she looks great with her poses etc...
Call a "Time out"
- I explain where i need her to be and why -Point to the lights and explain simply what their job is.... - where hair lights are aimed and why, I get her to work around a marked spot on the floor (with some leway on either side)
-It might be a bit of tape, etc, or whatever.
But Ive always found that with a simple explanation on the lighting setup - (most) models learn quick, and even suggest to me a light position change for a different angle pose.!
Mark
1DMK4, 5Dmk2, Nikon D3s & some glass to fit.
My Website
Model Mayhem
Coastwatch203 is offline   Reply With Quote
Old 26th of February 2009 (Thu)   #6
trailblazer
Useful information Mark.
Buying more equipment is not really in the budget for the rest of this year or even next year so it is the little things like this that are really appreciated.
Old 3rd of March 2009 (Tue)   #7
nrellas
nrellas's Avatar
Originally Posted by trailblazer View Post
Hi guys,
What do you do?
I run with it for a little while, see what I can get from the new pose and the light. If I really like the new pose and the light isnt working then Ill stop and reposition the light. I know a lot of people like to let models pose, but if you have some of your own direction in mind, its an easy way to minimize this situation. Also, with those 3 lights, most poses will work, the lighting setup is rather generic.
When I was just starting to shoot, I had an established advertising photographer tell me that 90% of photography is problem solving. You need to find how your working style fits into these situations. Maybe you need an assistant to help you, so you can just say "Hey could you please move the key light ___" or "Could you lower the hair light", "Turn down the power of ___".....
Nick
Gear Fetishist<---------------------{--}--->Photographer
nrellas is offline   Reply With Quote
Old 8th of April 2009 (Wed)   #8
DerekW
DerekW's Avatar
What's a U-bank reflector?
DerekW is offline   Reply With Quote
Old 8th of April 2009 (Wed)   #9
TooManyHobbies
Go to an art supply store and buy four 4'x8' white foam cores. Tape a pair together with white duct tape and you have "bookend" reflectors. Paint one side black (optional).
Now you have two bookend reflectors for fill or subtraction. They stand upright when you stand them as a V or L. You can shoot a strobe into the V as a bounced light source. You can shoot the one side of the V with a strobe so half is a bounced light source and the other half can act as a flag (barndoor) to control spill.
If you take 2 bookends and stand as "L"s to make a "U" you have a 4x8x8 U-bank reflector. Put it behind or to the side and bounce a stobe off as a big light source. Now you have a light source so large you can move around in front of it side to side, back and forth, without worry. It's a lot of fill and it's a big light source. You can always add more strobes pointed at your model if you need more contrast or key light.
If you have light grey walls in your studio, you could just use the walls but the bookends are more versatile and can do many things.
Cheap and easy light modifier that is very versatile.
Easy Kicker:
If you wall, ceiling, or clamp mount a strip box above your back wall in the center aimed straight at the camera but parrallel to the ceiling the light will spread down. Just move your model back and forth to get the right kicker. You also get some reflection off a white ceiling for fill. You need some space to make this work in a studio.
~ Jeff
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
lighting setups and help aragonwhite Glamour & Nude Talk 5 22nd of October 2008 (Wed) 15:20
2 questions about lighting setups! towersinthesky General Photography Talk 1 14th of July 2008 (Mon) 18:31
Some questions about studio lighting setups... Walczak Photo Small Flash and Studio Lighting 5 4th of May 2008 (Sun) 22:47
UK lighting stand setups - massively confused Orchid Small Flash and Studio Lighting 4 7th of March 2007 (Wed) 11:27
Studio lighting setups/tutorials? shakin360 Small Flash and Studio Lighting 5 22nd of December 2006 (Fri) 08:03
