Reply
Thread Tools Display Modes
Old 20th of December 2002 (Fri)   #1
slowboy
Default Does the average g3 owner use a gray card?
And if so why? and what are some good examples of times to use one?
slowboy is offline   Reply With Quote
Old 20th of December 2002 (Fri)   #2
TD27
Default Re: Does the average g3 owner use a gray card?
Slowboy, it took me a moment to understand what you were asking about using "a gray card". I think that the answer to your question about whether "average" users use one is a most resounding "no". I further suspect that a majority of users don't even know what a gray card is.
Now, what I think you're talking about is the old 18% gray card that was often used for determining correct exposure in tricky lighting conditions. The card would be held up near the subject and a spot meter used to read the light values from it.
I don't even own a gray card these days. In most cases I'm very pleased with the center-weighted exposure the G3 gives, and on very rare occasions I have used the spot meter to get my exposures. The beauty of the G3 (or any digital for that matter) is the ability to instantly see your result and to make corrections if necessary for the next shot(s).
What I do use often however, is a white sheet of paper in order to set custom color balance when in mixed lighting (tungsten, fluourescent, daylight, etc.) conditions. I find that very handy.
Are YOU using a gray card to help with exposures? What conditions prompt you to do so?
TD27 is offline   Reply With Quote
Old 31st of December 2002 (Tue)   #3
jscher2000
You've got to read Tony Spadaro's stuff on this:
http://home.nc.rr.com/tspadaro/Acces....html#greycard
Follow the link to Grey Card Walk. Wild article.
jscher2000 is offline   Reply With Quote
Old 8th of March 2003 (Sat)   #4
dagoch
I *have* been using a gray card with the G3 because I am trying to gauge how the images on the G3 LCD translate to my computer monitor. My images definitely appear brighter on the camera's LCD than they do on my monitor. It seems that in order to get an image that is accurately exposed on my computer, it needs to appear slightly overexposed (roughly 1 stop) on the camera's screen.
My monitor is calibrated (using Adobe Gamma) and works great with images from my scanner. Is there any way to adjust the camera's display (I'm already using the lower brightness setting) ? Or is there some way to get a calibrated color profile for this camera?
I'd rather not have to use raw images if I don't need to -- I am perfectly happy with the superfine JPEGs (except for the exposure issue), and don't need the extra conversion step.\
Any suggestions?
dagoch is offline   Reply With Quote
Old 8th of March 2003 (Sat)   #5
PacAce
Moderator
PacAce's Avatar
Default Re: Re: Does the average g3 owner use a gray card?
I've also experienced the same effect on my computer CRT monitor when working with my digital camcorder. It seems like the CRT does not have the same contrast and brightness range as the camera LCD does. This might be something that's inherent with most, if not all, CRT monitors. I've been contemplating switching to, or adding, an LCD monitor to get an image that more closely matches the view on the LCD monitor of the camera.
..Leo
PacAce is offline   Reply With Quote
Old 8th of March 2003 (Sat)   #6
dagoch
Default Re: Re: Re: Does the average g3 owner use a gray card?
That seems to be a backwards way to do things: it is difficult to maintain a fully color-calibrated workflow with an LCD monitor. I've got a calibrated color profile for my monitor, as well as my scanner and printer, so I can reliably predict what colors will look like all the way through the process. Right now, the camera is a wildcard. Is there any way to calibrate the camera to fit into my workflow?
thanks.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Gray card Debkmoff General Photography Talk 6 1st of August 2007 (Wed) 19:26
Gray Card? nicshow Accessories & Storage 11 22nd of February 2007 (Thu) 23:41
White card/gray card WHAT??? Transportithere General Photography Talk 7 20th of July 2006 (Thu) 11:13
Gray Card vs White Card mkies General Photography Talk 10 21st of April 2006 (Fri) 06:46
Gray card aam1234 The POTN Lounge 15 23rd of December 2004 (Thu) 20:54
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
