Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 3rd of April 2005 (Sun)   #1
KJGradwell
KJGradwell's Avatar
Default Down Sizing for printing
Guys
I'm using 300D in RAW mode.
I'm printing at 6X4 inches (150X100mm) in photoshop.
To reduce print size I am not resampling which results in a pixel resoultion circa 520 ppi. I realize that this does not reduce file size, nor can my printer Epson R800 deal with the extra info, file handling takes longer as does printing etc.
Do I miss something ths way? Is there an quality advantage in resampling to say 300 ppi?.
I am aware that access to this forum can make us lazy. I have raed around a bit but most articles concern themselves with up sizing.
Kevan Gradwell
Manchester UK
KJGradwell is offline   Reply With Quote
Old 3rd of April 2005 (Sun)   #2
Jesper
Jesper's Avatar
Default Re: Down Sizing for printing
Why don't you try it for yourself - first print a photo the way you normally do (at 520 dpi), then resize it to 4 x 6 inch at 300 dpi (which means 1800 x 1200 pixels, or 2.2 megapixels) and print it. Look at the prints and see if you see any quality difference - I guess you probably will not see any significant difference. You can also measure if printing the larger photo takes more time than the smaller photo.
And please let us know your results......
Please visit my gallery!
Canon EOS 5D
EF 24-105 f/4 L IS, EF 70-200 f/4 L IS, EF 35 f/2, EF 50 f/1.8 II, EF 100 f/2.8 Macro USM
Extender EF 1.4x II, Speedlite 550EX
Jesper is offline   Reply With Quote
Old 4th of April 2005 (Mon)   #3
KJGradwell
KJGradwell's Avatar
Here is the result.
Original image size 2832X2128.
Cropped to 2757X 1838
Printed 150X100mm @ 467ppi
Time from pressing "print" 4 minutes 3 seconds
Time from first audible printer response 3 minutes 33 seconds.
Re-sampled to 300 ppi
Image size 1181x 1772
Equivalent times 2 minutes 57 seconds and 2 minutes 43 seconds.
No difference in print quality.
Printerer Epson R800 set to best quality (RPM) Epson glossy paper.
Kevan
Kevan Gradwell
Manchester UK
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Sizing Photos for Printing Using CS2 JuSlaughter RAW, Post Processing and Printing 2 4th of July 2007 (Wed) 05:19
4x6 Printing and Photoshop sizing Sydor25 RAW, Post Processing and Printing 7 5th of March 2005 (Sat) 13:40
Sizing? R.T. RAW, Post Processing and Printing 0 2nd of December 2004 (Thu) 02:44
sizing photos for printing at online photo services janieg General Photography Talk 1 15th of March 2003 (Sat) 07:32
sizing images for printing IainB Canon G-series Digital Cameras 3 8th of July 2002 (Mon) 02:59
