Thread started 09 Mar 2009 (Monday) 11:45
Canon 50 f/1.4 sharp wideopen???
AlanU
Gallery: 54 photos
Mar 09, 2009 11:45 |  #1
Is there such a thing?
Reading the FM reviews a good 80% (speculation) says f/1.8 to f/2.2 is noticeably sharp.
My plastic nifty 50 was excellent at f/2 to f/2.2. I guess if your critical, the bokeh was not asounding by any means.
The Canon 50 f/1.4 has been well known for soft wideopen performance with CA. HOW do most owners use this lens?? f/1.8 to f/2.8????
My 50f/1.4 copy with 5D appears to have no front/back focus issues however at f/1.6 its "acceptably" sharp. At f/1.8 its what I would expect this lens should perform at f/1.4. (Sorry NO PICS)
I do find this lens to be sharper on the XTI so I'm assuming its the shallower DOF of the 5D (my part in handshake and moving subject) that is also contributing to the softness. Eyelash detail is my pixel peeping object.
My new copy has time for a swap at the local camera store. I've just heard people having several new copy swaps with identical peformance wideopen.
Is this just the way it is?? I still cant pull a trigger on a Sigma 50 f/1.4. Mind you in most cases f/2, f/2.2 (or higher) will probably give many a higher keeper rate on moving subjects.
Realistically is this nature of the product? By reading reviews its the way it is.
thanks!
5Dmkiv |5Dmkiii | 24LmkII | 35mm f/2 IS | 85 mkII L | 100L | 16-35L mkII | 24-70 f/2.8L mkii| 70-200 f/2.8 ISL mkII| 600EX-RT x2 | 580 EX II x2 | Einstein's
Fuji X-T2 w/battery booster | 16mm f/1.4 | 56 f/1.2 | 10-24 f/4.0 | 50-140 | EF-X500 | TT685
Sony A7iii w/ Sigma MC-11 adapter
Jim ­ G
I feel thoroughly satisfied
Joined Jun 2005
Mar 09, 2009 11:46 |  #2
I had a copy, 'twas soft at f/1.4. I've used a couple of other people's copies and found them to be equal. My 1.8 was sharper wide open, the 1.4 was equal to the 1.8 at 1.8 however.
Gear Listhttp://www.codastudios​.com.au (external link) Reviews & Hotlinks: Domke F-3x - Pelican 1510/1514 (external link) & 1610/1614 (external link) - DIY Variable Length OC-E3 - Crumpler 6 Million Dollar Home (external link) - FA-100 (external link)
TaDa
...as cool as Perry
Mar 09, 2009 11:47 |  #3
Yeah, it's not the best wide open. It's been over a year since I've owned one, but remember using it at 1.8 most of the time. I still think it's usable at 1.4, but much better stopped down.
Name is Peter and here is my gear:
Canon 5D II, Canon 7D, Canon 40D
Glass - Zeiss 21 f/2.8 ZE, Canon 35 f/1.4L, Canon 40 f/2.8 STM, Canon 24-70 f/2.8
L, Canon 85 f/1.2L II, Canon 70-200 f/2.8L IS II, Canon 500 f/4L IS
Speedlite 580ex II, 430ex - Gitzo GT-3541XLS w/ Arca B1
Goos
Mar 09, 2009 11:57 |  #4
The sigma 50 f/1.4 is pretty much the same in that regard, right?
TaDa
...as cool as Perry
Mar 09, 2009 12:01 |  #5
The Sigma 50 that I tried at B&H was sharp wide open. Thing with Sigma is finding a copy that focuses correctly.
ed ­ rader
"I am not the final word"
Mar 09, 2009 12:03 |  #6
AlanU wrote in post #7486886 (external link)
thanks!
i almost always stop down any lens when possible except for my 70-200L f4 IS. i try to use the 50 1.4 @ f2 but will use it wide open if left with no choice.
it shouldn't come as any shock that canon's least expensive f1.4 lens is soft wide open, should it :D?
that said, i've owned four different 50 1.4s and two were better wide open than my 35L 1.4 or the 35L 1.4 that i rented. okay i do know that copy variation could play into this :D.
here's a sample with my FF 1ds mark III shot wide open.....
HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by FOTOTIME
ed rader
5D4, 80d, 16-35L III, 24-70L II, 70-200L F4 IS, 100-400L II, sigma 15mm FE, 35mm ef-s macro, 430exII, gitzo 3542, gitzo GM4562, markins Q10, markins Q3, kirk, really right stuff
AlanU
Gallery: 54 photos
Mar 09, 2009 12:04 |  #7
so monkey nuts they are?? :) Thanks for reasuring that I am not an obsessive Pixel peeper. My copy shows no front/back focus at least. So I guess I have the "typical" Canon 50 f/1.4. On print I guess its definitely useable at widopen.
Putting on my 85 f/1.8 (wideopen) on my 5D makes me think the Canon 50f/1.4 is a shame at wideopen.
I am praying Canon will make a long awaited 50 f/1.4 mkII.
If I had micro adjust I'd buy the Sigma version. Just wont pull the trigger just yet. The 50L scares me aswell.
[Hyuni]
Mar 09, 2009 12:07 |  #8
So you really are paying 3x more for the build quality.
I guess you have the option to shoot at 1.4 but if the photos come out soft, what's the point?
Am I asking for too much if I expect a lens with 1.4 maximum aperture to actually produce reasonably sharp photos at 1.4???
yeah yeah, more blades, better bokeh, and micro USM, but the MAIN advantage of the 1.4 vs the 1.8 should be the f/1.4 not build quality!
If the 1.8 had a metal mount and $20 more, I bet the 1.4 would be quite unpopular... at least until they fix the softness issue at 1.4 - 2.0.
The 50mm 1.4 should be called the 50mm 1.8 mkIII, because most say that it doesn't even become useful until stopped down to at least 1.8
The reason the 1.4 is so popular is because Canon is running a bait and switch scheme!
6D Rokinon 14 f/2.8 l EF 35 ƒ1.4L l EF 135 ƒ2.0L l EF 70-200 ƒ2.8L IS II l YN460 l 580EX II l Flick'd (external link)
AlanU
Gallery: 54 photos
Mar 09, 2009 12:11 |  #9
Ed,
The Canon 50f/1.4 is $400 CDN new. I find my copy sharp when I take photos of books, cell phone, pens etc etc. When I start taking photos of my daughter I find at f/1.4 and f/1.6 acceptably useable. When she's not moving so much I can get excellent eyelash detail at f/1.8.
So I'm assuming f/2.0 , 2.2+ is what I should be using. Certainly a shame for a fast prime. My brick gives me almost the same separation bokeh but with versatility.
I guess it is what it is.
ed ­ rader
Mar 09, 2009 12:17 |  #10
AlanU wrote in post #7487076 (external link)
Ed,
yep. the only canon non-L prime that i think is "sharp" wide open is the 100 f2 but it is an exceptional lens and it does noticeably improve when stopped down.
i couldn't get this guy to stop moving either and it was very dark (50 1.4 @ 1.4) :D.
IMAGE: http://erader.zenfolio.com/img/v1/p241967785-5.jpg
ed rader
AlanU
Gallery: 54 photos
Mar 09, 2009 12:20 |  #11
Ed,
Looks like he's scared of the guy behind the camera :)
excellent capture by the way!!!
I guess I have a mediocre typical 50 f/1.4. I'm debating if I should even try another copy. I'll do more testing I guess.
ed ­ rader
Mar 09, 2009 12:22 as a reply to  @ ed rader's post |  #12
BTW, i do agree that canon needs a moderately priced 50mm prime with ring USM. this fact hasn't been lost on sigma either :D.
of all the shorter primes i've used i'd say they are f2 lenses if you are concerned about sharpness. the 28 1.8 is an f2.2 lens and is horrible wide open.
ed rader
ed ­ rader
Mar 09, 2009 12:26 |  #13
AlanU wrote in post #7487142 (external link)
Ed,
Alan -- i've owned four copies. the one i have now is the best or at least tied with the best. one was unusable wide open.
what i would do is buy used copies when you see excellent deals and keep the one that's the best.
i use the 50 1.4 rarely and the price and performance are about right for me :D.
ed rader
AlanU
Gallery: 54 photos
Mar 09, 2009 12:27 |  #14
My "normal" crop Sigma 30mm is unbelievably sharp wideopen. Its 98% of the time spot on focus with my XTI. That lens was a flukey find for "good" accuracy. That lens definitely puts that Canon 50 f/1.4 to severe shame on my 5d.
ed ­ rader
Mar 09, 2009 12:30 |  #15
AlanU wrote in post #7487197 (external link)
the 30 1.4 doesn't work on either of my cameras so that ain't computing for me :D.
ed rader
2,643 views & 0 likes for this thread
version 2.0 /
Latest registered member is pno6854x
703 guests, 427 members online
