Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > General Photography Talk
Reply
Thread Tools Display Modes
Old 11th of March 2009 (Wed)   #1
tmoore99
tmoore99's Avatar
Default Photographing a protrait with a computer monitor in the background
I've got to shoot a businessman at his desk with his monitor in the background. I assume he'll have his company website on screen, or maybe he just wants to look like he's working hard on a spreadsheet. Regardless, "with a computer screen in the background" is one of the requirements on the assignment form.
Can I get a good shot using...
a) shutter speed matching refresh rate
b) slow shutter in the 1/4 - 1/2 second range
c) it's more complicated than that
Your experience would be appreciated.
Thanks!
Tom
5D, 135L, 24-105L, 430EX
tmoore99 is offline   Reply With Quote
Old 11th of March 2009 (Wed)   #2
gjl711
human (barely) and bribable
gjl711's Avatar
Default Re: Photographing a protrait with a computer monitor in the background
What kind of monitor? The old tube ones if shot slower than refresh you'll get a good pic. The LCD ones are a bit more forgiving as latency is much longer. Experiment a little and see what works.
Not sure why, but call me JJ.
Today is only yesterday's tomorrow
::Flickr::
::Gear::
gjl711 is offline   Reply With Quote
Old 11th of March 2009 (Wed)   #3
tmoore99
tmoore99's Avatar
I won't know till I get there, but the event is celebrating a new office opening and there's an emphasis on being tech savvy, so I'm betting on a flat panel LCD.
Tom
Old 11th of March 2009 (Wed)   #4
gjl711
gjl711's Avatar
I'm guessing that if you shoot at 1/60 you'll be safe.
::Flickr::
::Gear::
Old 11th of March 2009 (Wed)   #5
Hermes
If you need to, set up the shot on a tripod to keep the framing consistent - that way you can take separate exposures to get the screen just right and comp it into the final portrait.
Hermes is offline   Reply With Quote
Old 11th of March 2009 (Wed)   #6
Cromfel
Shut down the monitor and photoshop screencapture of the desired content into it. If you want reflections of surrounding just use layer of the original screen with like 10% opacity and none will see the difference, and it will give natural feeling for the photoshopped content on the display.
Cromfel is offline   Reply With Quote
Old 11th of March 2009 (Wed)   #7
gjl711
gjl711's Avatar
I really don't think you have to get so complicated as to photoshop in a screen. Flat screens photograph very nicely as is unless they have a a glossy surface or if they are turned at quite an angle the the plane of the sensor. Shoot 1/60 and make sure that the monitor is relatively pointed at the camera and things should be fine.
::Flickr::
::Gear::
Old 11th of March 2009 (Wed)   #8
PhotosGuy
Moderator
PhotosGuy's Avatar
Won't that only get one field of scan lines? Try 1/30 too, & see what you get. Film is cheap.
www.FrankCizek.com
PhotosGuy is online now   Reply With Quote
Old 11th of March 2009 (Wed)   #9
Tomi Hawk
Tomi Hawk's Avatar
Yep .. I'd even go to 1/30th on a tri-pod ..
If you can bounce your lights and match any ambient light there might be ..
that would look cool too ..
Tomi Hawk is offline   Reply With Quote
Old 11th of March 2009 (Wed)   #10
mattograph
"God bless the new meds"
mattograph's Avatar
Piece of cake!
http://strobist.blogspot.com/2006/04...h-tvs-and.html
This space for rent.
mattograph is offline   Reply With Quote
Old 11th of March 2009 (Wed)   #11
TheHoff
Don't Hassle....
TheHoff's Avatar
bingo.
••Vancouver Wedding Photographer ••| [gear list] | Latest blog: 5 steps to stopping image loss
TheHoff is offline   Reply With Quote
Old 11th of March 2009 (Wed)   #12
gjl711
gjl711's Avatar
Computer monitors do not interlace, and plat screens have very high latency, even the fancy new ones.
::Flickr::
::Gear::
Old 11th of March 2009 (Wed)   #13
rdenney
Rick "who is not suited for any one title" Denney
Standard television refreshes alternating lines on the screen 30 times a second. You need a shutter speed at least as slow at 1/15 not to show scan artifacts. Computer monitors usually refresh the entire screen 60-72 times a second. 1/30 should be fine there. LCD's are not a problem at any useful shutter speed, by my experience, because they stay lit between refreshes pretty well. I had my 10D here at the office, and enough battery for one shot and a quick chimp. 1/125 of my laptop screen showed no issue at all.
Rick "and you can meter the screen normally" Denney
The List
rdenney is offline   Reply With Quote
Old 11th of March 2009 (Wed)   #14
mattograph
mattograph's Avatar
This strobist post is titled "dealing with tvs and crts."
ON TOPIC?
Yes, I am repeating myself.
Old 11th of March 2009 (Wed)   #15
tmoore99
tmoore99's Avatar
ON TOPIC?
Excellent. Thanks Matt. Although I'll likely be seeing a flat panel LCD, the tips there were dead on for exposure consideration. Low ambient light proved to be very important.
I just did some test shots with my home LCD monitor. At SS 1/125 and slower the screen didn't show any indication of flicker. However, I had to get much slower for it to be sufficiently bright; essentially exposing for the monitor alone as a self illuminating subject (which doesn't benefit from flash) and letting the bounce flash compensate nicely for everything else.
Spinning the wheels of exposure, my test led me to 1/15 (as slow as I want to get with a human subject that needs to be sharp), f5.6 (biggest I can get and still have some DOF), and ISO 200 to fine tune the monitor exposure. How does that sound?
Tom
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
New computer background Attic Macro 3 21st of July 2007 (Sat) 10:23
Karmann Ghia (good for computer background) Bill Crittenden Transportation 0 16th of June 2007 (Sat) 16:09
Computer Monitor help on new purchase mudbug46 The Business of Photography 8 13th of February 2007 (Tue) 09:00
Use a Computer Monitor as Viewfinder? erlunn Canon EOS Digital Cameras 11 26th of September 2006 (Tue) 07:55
Computer Monitor Bob F The POTN Lounge 2 7th of September 2006 (Thu) 17:59
