Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Critique Corner
Reply
Thread Tools Display Modes
Old 12th of March 2009 (Thu)   #1
scrapin_frame
scrapin_frame's Avatar
Default 1st post to be critiqued, be gentle yet firm
Took this photo on the architectural boat tour on the Chicago River in November. What could I have done differently? I was kind of limited on shots due to the bars overhead on the tour boat for the canopy.
Remember, first post, be gentle
forgot to post the link http://www.flickr.com/photos/scrapin_frame/3349729355/
scrapin_frame is offline   Reply With Quote
Old 12th of March 2009 (Thu)   #2
scrapin_frame
Default Re: 1st post to be critiqued, be gentle yet firm
I wish there had been some clouds in the sky. I took pictures of my wife and I at the Cloudgate, but there were zero clouds
Old 12th of March 2009 (Thu)   #3
mikewheatie
Scrapin,
This is a really neat shot. I really like the gradation in the sky. The color and saturation and really good. It looks like you picked a good time of day to take this shot when the sun was low in the sky as well.
The screen on my laptop isn't calibrated, so I might be a bit off, but the picture looks a tad too warm. The boat closest to the camera looks like it's a little too yellow. Also, the building on the far right closet to the camera looks a bit too yellow as well. Like I said, my screen may be a bit off though.
Also, the buildings look they are leaning every so slightly to the left. A quick crop and straighten in PS or LR would do the trick.
I like how the channel leads the eye into the frame, but the tallest buildings are smack dead in the center. It may be a bit more visually interesting if the two buildings are a bit off-center. You might also crop a bit off the top to bring more focus to those buildings.
Mike
mikewheatie is offline   Reply With Quote
Old 12th of March 2009 (Thu)   #4
Calindy
Calindy's Avatar
Beautiful shot of Chicago! I see the former Sear's Tower in this shot...
Calindy
Photography is my Prozac!
Canon Digital EOS 7 D, Lenses: EF IS 100-400mm L USM, Canon EF 70-200mm f/2.8 L IS USM , Tamron 18-270 mm, Canon EF 50 mm F/1:4 USM, Tokina 11-16MM F/2.8 ATX 116 Lens, 430EX Canon Flash, Canon G 10 , Blackrapid R-7 Strap
Calindy is offline   Reply With Quote
Old 13th of March 2009 (Fri)   #5
scrapin_frame
Originally Posted by mikewheatie View Post
Scrapin,
Mike
Mike
You are correct about the lean of the buildings. The buildings on the left were pretty much straight, but the Sears Tower and others had a lean to them. Since the Sears Tower was the main point of focus in the picture, I dropped a few guides in photoshop and used transform to straighten it up. The tradeoff is that not every building is straight. I wasn't really sure how to go about fixing it.
The boat you mentioned actually was yellow, but I did warm the picture a little too. I was trying to bring out the color in the leaves. I will try a couple more different versions.
Also, i agree with you about the crop. I may try to crop it in the way you mentioned with the Sears Tower off-center.
Thanks for the input.
John
Old 13th of March 2009 (Fri)   #6
scrapin_frame
Sad, isn't it?
Now we get the Willis Tower, which there has been talk of them repainting it silver too at a cost of $50,000,000. It will always be the Sears Tower to me though. As far as them repainting it, how can they do that to something so iconic? They should just give me that money
Old 13th of March 2009 (Fri)   #7
1shot4u
1shot4u's Avatar
I like it..Check the tilt though.
Stephen Shell
Canon G12.
1shot4u is offline   Reply With Quote
Old 14th of March 2009 (Sat)   #8
scrapin_frame
I have tried straightening the photo several times, but it seems that no matter which building i choose to drop my guide on, the other buildings end up tilted. Is it my 18-55 kit lense?
I tried cropping it down some and cooling it slightly
Here is another photo I took a few minutes before the other. I was shooting more toward the sun than away from.
Old 14th of March 2009 (Sat)   #9
LeuceDeuce
LeuceDeuce's Avatar
It's not your lens. It's converging verticals due to pointing your camera up in order to get the entire building in the shot. You can correct it using the lens distortion filter in photoshop.
In order to keep your verticals vertical you must keep your camera level when you take your shot.
my website: Light & Shadow
my flickr
LeuceDeuce is offline   Reply With Quote
Old 15th of March 2009 (Sun)   #10
scrapin_frame
Wow, I am almost ashamed that I did not know about that. My major in college is Graphic Design and I have taken all the advanced classes offered in Adobe, and that is the one thing we never had to use in any of the classes. I am sure that we touched on it, but it wasn't explored in depth. It's hard to remember all that stuff.
Thank you so much! I can tell already that I will learn much from this site.
John
Old 15th of March 2009 (Sun)   #11
Michael Vermont
Beautiful shot, I would have done a tighter crop of the center buildings to illustrate their height against the gradient sky, the leaning building as others have mentioned, aside trying to straighten them, go to PS and choose distort and freetransform and enlarge the top just a pinch, and perspectively speaking it'd be accurate
Michael Vermont is offline   Reply With Quote
Old 16th of March 2009 (Mon)   #12
scrapin_frame
I tried using the lens correction in photoshop.
Is this better?
Old 16th of March 2009 (Mon)   #13
LeuceDeuce
LeuceDeuce's Avatar
Is this better?
I only looked closely at the first shot, and your converging verticals look good. You'll see a big improvement if you rotate clockwise by 0.82 degrees. Use the Image->Rotate Canvas->Arbitrary to enter the degrees of rotation.
I got the angle using the ruler tool on a long vertical as close to the center of the image as possible.
Edit: You can always turn on the grid from View->Show->Grid in order to check your verticals.
my flickr
Old 17th of March 2009 (Tue)   #14
jbreiman
Take it from a native here. The SEARS tower will always be the SEARS tower. Just like marshall fields and Comiskey Park
jbreiman is offline   Reply With Quote
Old 17th of March 2009 (Tue)   #15
scrapin_frame
True! I am a couple hours south of Chicago, but for me as well, they will always be as they were when we grew up.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Nikon User Here. See my 1st Shot. Be gentle ... please. Pianist718 Critique Corner 11 8th of January 2009 (Thu) 09:47
I was approached to allow a Law Firm / Marketing Firm use of my photos GMACK24 The Business of Photography 49 29th of February 2008 (Fri) 10:47
1st submission, don't be gentle Focus Critique Corner 14 8th of January 2006 (Sun) 01:16
Basketball 1st attempt - be gentle..please! spud159 Sports 9 27th of November 2005 (Sun) 20:37
My 1st pic - please go gentle Ade Critique Corner 4 1st of January 2005 (Sat) 15:59
