Thread started 05 Apr 2005 (Tuesday) 08:11
Prev/next
Single umbrella set-up
PhotosGuy
Moderator
PhotosGuy's Avatar
Joined Feb 2004
Middle of Michigan
Apr 05, 2005 08:11 |  #1
This is a simple set-up – just one umbrella. You could get similar results by bouncing the light off a 30” X 40” card, or even a wall. You could also point a light through diffusion material, such as a large piece of translucent paper, parachute silk, or plastic. The type of instrument (light source) doesn’t matter as long as you have a broad source directed at the subject.
(Don't forget to Custom WB!)
New Image Size Limits: Image must not exceed 1280 pixels on any side.
DaveG
Joined Aug 2003
Dartmouth, Nova Scotia
Apr 05, 2005 09:57 |  #2
That's a good shot but if you had another umbrella on the other side of your setup that was one stop hotter than the first, you'd get a 3:1 lighting ratio and I think more "sparkle" to the image. This is one of those situations where your solution is perfectly OK, right up until you see one with a lighting ratio. Then you add another little rim light and that help even more.
If you look at a Playboy centrefold (gee that's a tough assignment!) you'll see the model lit with a basic portrait lighting setup. Probably 3:1. Of course there's going to be hair lights and often more than one. But this "portrait" is almost a still life because the background is lit so carefully and with any number of lights. Now I say lights but they may be using mirrors to light that little tiny object that you really never notice over there, or to accentuate part of her body that you DO notice.
Those centerfolds are incredibly well crafted. They use an 8x10 camera to shoot them on with a something like a 480mm lens - roughly the same as a 50mm lens on a 20D!!! - and have inches of depth of field. That explains why the model in the centerfold is always on one plane. Covering her "endowment" is probably the limit of that lens's depth of field, never mind having her feet in the foreground.
My point is that your shot is very nice, but don't leave it there. Experiment a bit more and see if you can make it better. And after you nail the basics it's always the lighting.
"There's never time to do it right. But there's always time to do it over."
Canon 5D, 50D; 16-35 f2.8L, 24-105 f4L IS, 50 f1.4, 100 f2.8 Macro, 70-200 f2.8L, 300mm f2.8L IS.
PhotosGuy
Moderator
PhotosGuy's Avatar
Joined Feb 2004
Middle of Michigan
Apr 05, 2005 10:20 |  #3
You're right, Dave. Feel free to post your lighting set-up here: ;)
Lighting Set-Up Links –illustrations of real world examples.
:D:D (I may have sucked another contributor in.)
I reposted this to replace the original post from last year. The idea is to show people with no lights what can be done simply with one. But that doesn't mean that we couldn't use your two light set-up here. Or anyone else's! So, bring 'em on! ;)
DaveG
Joined Aug 2003
Apr 05, 2005 10:30 as a reply to PhotosGuy's post |  #4
If I could figure out HOW to post a shot I would.
PhotosGuy
Moderator
PhotosGuy's Avatar
Joined Feb 2004
Middle of Michigan
Apr 05, 2005 12:47 |  #5
Yeah, I looked for specific info & it seems pretty well hidden!
Several ways to do it for a Post: one of these will put the pic or link in the text anywhere you choose.
1. If the image is online, Rt-click on it & choose “Copy image location”
In the post, goto “Go Advanced” at the replies area.
Above the replies box, click on the little yellow “Insert Image” icon. Paste in your link.
2. If the image is online, Rt-click on it & choose “Copy image location”
Type
[IMG]
pasteyourimagelinkhere then type so it looks like this with no spaces:
IMAGE NOT FOUND IMAGE IS A REDIRECT OR MISSING!
Content warning: NOT AN IMAGE
4. This will put the pic at the end of the post.
At the bottom you’ll see “Attach Files”. Click on “Manage Attachments”, and navigate (Browse) to where the pic is on your hard drive. Find it & click “Upload”, & you’re done. Remember, you get only 2 pics this way, max size 100KB each.
Then to put a link to your post in my links post, or in a sticky links post, just type the title for the link, format the text (Verdana 3, blue), highlite it, & click on the little blue world “insert link” icon, & paste in the link from your original post on the “Threads in Forum: Lighting” page. Add a brief description & you’re done. ;)
Pertty intuitive, isn't it! :D;):D
DaveG
Joined Aug 2003
Apr 05, 2005 13:15 as a reply to PhotosGuy's post |  #6
Type
AHHHH!
How about I email YOU a picture and YOU post it?
PhotosGuy
Moderator
PhotosGuy's Avatar
Joined Feb 2004
Middle of Michigan
Apr 05, 2005 17:41 |  #7
:D:D:D Not that steep a learning curve! ;) Give it a try.
mbze430
mbze430's Avatar
Chino Hills
Apr 05, 2005 23:43 |  #8
Have you try shooting through the umbrella instead of bouncing on it?
My Hub to my personal workexternal link (just click on the banners)
PhotosGuy
Moderator
PhotosGuy's Avatar
Joined Feb 2004
Middle of Michigan
Post has been edited over 2 years ago by PhotosGuy.
Apr 06, 2005 05:39 |  #9
shooting through
That works well, too. Probably better if it's reflecting in something (like an eye.)
Edit: Just keywords to make it easier to find the thread: Cherry cherries
hopkins
Sep 15, 2005 09:27 as a reply to PhotosGuy's post |  #10
how do I make my pictures smaller so they are less than 100KB each?
5D. Digital Rebel, 24-70L, EF 18-55mm kit lens, EF 35-80mm, EF 70-300mm, Nifty-fifty, Sigma DG Super, Excaliber 3200 lights
robertwgross
robertwgross's Avatar
Joined Nov 2002
California
Sep 15, 2005 13:28 as a reply to hopkins's post |  #11
Either:
1. Reduce the number of pixels
--or--
2. Increase the compression of the JPEG (decrease the quality level).
---Bob Gross---
21,925 views & 0 likes for this thread
made in Finland
by Pekka Saarinen
Spent 0.00197 for 4 database queries.
PAGE COMPLETED IN 0.03s
841 guests, 381 members online
