Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 13th of July 2009 (Mon)   #286
Cathpah
Cathpah's Avatar
Default Re: Elinchrom Quadra or Ranger?
Originally Posted by roanjohn View Post
I tried using the adaptor with the deep throat softbox and I couldn't get it to stay put (it kept creeping down) - I had to overtighten the darn thing and was afraid it will break!!
wow, that's not good at all. That alone would be a deal breaker for me...
Eyeball Imaging or my Mayhem
too much gear to deny the addiction
oh, and my name is Jeff
Cathpah is offline   Reply With Quote
Old 13th of July 2009 (Mon)   #287
TMR Design
TMR Design's Avatar
It looks as if they've taken the swivel mount from the D-Lite or BXRi and used it on the Quadra heads. I don't know why they don't know or realize it's an inferior mount that has design flaws.
Lover of manual focus Zeiss glass.
Gear List & Feedback
Please call me Robert or Rob, not TMR
My Online Portfolio
TMR Design is online now   Reply With Quote
Old 13th of July 2009 (Mon)   #288
MR do little
MR do little's Avatar
Cathpath Its unfortunate but im quite sure its redeemed by replacing two washers, ill pick up some tomorrow.
Robert
Yes im not sure why ? I mean they could have made it smaller and lighter then the sturdier mounts on RX/BX/FX but still maintain the friction if they used "locking" washers (dont know the term in english, sorry)
Kindest
Regards
Paul L.
MR do little is online now   Reply With Quote
Old 13th of July 2009 (Mon)   #289
MR do little
Im actually thinking of taking one of my Manfrotto swivel umbrella adapters and modify the Elinchrom adapter to it, i just take of the top of the manfrotto and have my dad machine "distances" larger metal washers that is the same shape as the manfrotto (bottom) insert and be done with it.
It will requrire some cutting at the base of the adapter though, will explore the "locking" washers first, and will speak with the dealer tomorrow to let him now what POS that swivel mount is....
Kindest
Regards
Paul L.
Old 14th of July 2009 (Tue)   #290
roanjohn
roanjohn's Avatar
Paul - would be interested to see what you come up with. The locking mechanism for my quadra (not adapter) came off when I was attaching the deep throat on the adapter, I saw a rubber washer and a small metal washer. I wonder if I can buy a skinnier rubber washer and use that on both sides of the lever.......
www.pbase.com/roanjohn
roanjohn is offline   Reply With Quote
Old 14th of July 2009 (Tue)   #291
MR do little
Hi Roan!
Just done modifying my adapter to fit the Manfrotto swivel adapter, works like charm!
However getting rid of the rubber washer and the thin metal washer and replace them with a "locking" washer and a thicker metal washer will solve your problem. No creep at all.
I havent noticed any problems with the mount on the actual head since i dont have to tighten it that hard considering i only use the 13,5cm and 18 cm reflectors on it.
Ill post some images later today.
Kindest
Regards
Paul L.
Old 14th of July 2009 (Tue)   #292
Rai33
Rai33's Avatar
Paul - please do. Just picked up my Quadra and adapter today... very interested to see your modifications to it.
mondo photo
Model Mayhem
Flickr
Rai33 is offline   Reply With Quote
Old 14th of July 2009 (Tue)   #293
fi20100
fi20100's Avatar
Also, would be great to see a pic of the Quadra with an Elinchrom beautydish.
fi20100 is offline   Reply With Quote
Old 14th of July 2009 (Tue)   #294
MR do little
OK here's some images.
Original
I replaced the red outlined washers (the big rubber washer and the thin metal washer) with a flat washer and a "locking" washer (rugged)
Replaced two washers
Put together with new washers.
Manfrotto mod.
Iv just took apart the Manfrotto 026 Swivel umbrella adapter
Put together
Elinchrom Beauty dish mounted on the adapter.
Forgive the poor snap
Quadra with the 18cm+Grid mounted.
By just replacing the washer (mentioned) the original adapter works as it should, no creep whatsoever, if anything brakes it will be the plastic part at the base of the swivel mount.
For those that want an all metal swivel mount like the Manfrotto, just a slight cutting at the base of the Elinchrom adapter is needed (the manfrotto isnt deep enough) and add a few washers.
Hope this helps.
Kindest
Regards
Paul L.
Old 14th of July 2009 (Tue)   #295
TMR Design
TMR Design's Avatar
Very nice job Paul. Can you show an image to illustrate what you had to cut on the Manfrotto adapter?
My Online Portfolio
Old 14th of July 2009 (Tue)   #296
fi20100
fi20100's Avatar
Great seeing those pictures! Tusen tack Paul!
Old 14th of July 2009 (Tue)   #297
Rudi
Rudi's Avatar
This is just sloppy engineering on Elinchrom's part! I mean, seriously, how hard would it have been to do properly in the first place?
(And now I have a post to show people when they accuse me of only bashing Paul C. Buff products. ).
Regards,
Rudi
www.rudiphoto.net
If you limit your choices only to what seems possible or reasonable, you disconnect yourself from what you truly want, and all that is left is a compromise
- Robert Fritz
Rudi is offline   Reply With Quote
Old 14th of July 2009 (Tue)   #298
TMR Design
TMR Design's Avatar
Oh Rudi, you're just a hater and you know it.. LOLOLOL
The reality is that if something isn't right we modify and/or post about it regardless of brand, even if it's a brand we own and love.
My Online Portfolio
Old 14th of July 2009 (Tue)   #299
roanjohn
roanjohn's Avatar
WOW!! THANKS!! I will work on this later.
Old 14th of July 2009 (Tue)   #300
tetrode
tetrode's Avatar
Nice going, Paul. Two good alternatives presented here. One thing, though, it would appear from your photo of the Quadra head with the beauty dish that the ability to tilt the assembly downward is severely restricted. That is to say, it looks as if the back of the dish will hit the stand if it's angled downward even slightly. Maybe it's just an optical illusion and it really isn't as close to the riser as it seems to be. Is motion in the tilt axis adequate for most usual placements of a BD?
Thanks much,
Dave F.
tetrode is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Elinchrom Ranger RX and Canon Speedlites NewattheGame Small Flash and Studio Lighting 2 3rd of February 2009 (Tue) 16:22
First Impression Elinchrom Ranger RX snedigity Small Flash and Studio Lighting 15 29th of December 2008 (Mon) 23:32
I did it! Elinchrom Ranger RX/AS Speed rajat Small Flash and Studio Lighting 6 22nd of November 2008 (Sat) 23:15
Elinchrom Ranger wcl4 Small Flash and Studio Lighting 1 11th of May 2007 (Fri) 11:17
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
