Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Still Life, B/W & Experimental Talk
Reply
Thread Tools Display Modes
Old 17th of March 2009 (Tue)   #1
Esoteric Vision
Question Silhouettes
Need some advice on how to take silhouette shots of people mourning at a grave site. What settings should I use?
Esoteric Vision is offline   Reply With Quote
Old 17th of March 2009 (Tue)   #2
birdman59
birdman59's Avatar
Default Re: Silhouettes
What seems to work best for me is to shoot facing light source with subject in between and expose for lightest part. The subject will be way under exposed and just a shadow.
Bracket your shots to get the results you want.
birdman59 is offline   Reply With Quote
Old 23rd of March 2009 (Mon)   #3
deci
deci's Avatar
When I try and do a silhouette of our cats, I
1) Shoot RAW (tweak PP in ACR)
2) As birdman said - expose for the lightest part (which I presume in this case will be sky)
3) Again - as birdman said bracket your shots.
In PP (if your software allows it), once you've converted to B+W open 'levels', click on the lightest part of what you want to appear black with the black eyedropper and click on the darkest part of the pic you want to appear white with the white eyedropper. Clean up 'stray' lights and darks with burning and dodging or paint over the bits of what should be black, with black and sample the lightest areas to paint over what 'should' be included in them.
HTH
Canon 1D MkIIn, Canon 30D (Gripped) + Canon A1
Canon 35 f2, 50 1.2L, 50 f1.8, 60 f2.8 Macro, 85 f1.8, 70-300 IS
Sigma 10-20, 24-70 f2.8, 105 f2.8Macro
http://www.black-cat-gfx.co.uk
deci is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Silhouettes Bigbitt8706 Critique Corner 14 5th of September 2008 (Fri) 22:48
two silhouettes lawry People 1 11th of December 2007 (Tue) 06:53
Silhouettes luannf1980 Weddings and Other Family Events 15 12th of October 2007 (Fri) 22:36
Silhouettes thekid24 People 25 24th of March 2007 (Sat) 14:01
silhouettes matador01 General Photography Talk 3 19th of March 2007 (Mon) 14:43
