#1 |
Shooting a wedding in about 3 hours (My first wedding, and im doing it for veeeeeeeeeeeery cheap). Im confident on my ability to get good shots but I have some questions about a couple of technicalities.
The ceremony itself will be indoors in a church so: - Should I switch to AV (I shoot M). will that give better speed in getting moments? - What are the Flash rules during the ceremony, no flash? or flash away?? should be interesting!, this one is actually more like practice for a bigger one I have next weekend... appreciate the help!
1DMKII:: Canon 85mm 1.8:: Canon 50mm 1.8:: Canon 28-105mm:: Canon 430EX:: Zuiko 50mm 1.8:: Zuiko 35-105mm:: |
| sponsored links |
#2 |
I've shot 5 weddings (1 primary, rest second) so I'm not really qualified, but seem as your in a rush ....!
If I think you need AV, then shoot in AV. It's about your ability, if you think you can shot manual then do it ... AFAIC it's more reliable if you can use it properly. Flash is generally not permitted during the ceremony, but it's dependant on venue. I went to a civil ceremny and flash was allowed. Ask someoone before hand. Have you 50 1.8 on standbye just in case
Canon 400D (XTi), Sigma 24-70 2.8 (LOVE IT!), 18-55mm f/3.5-5.6 kit lens, 50mm f/1.8 Nifty 50, 90-300 mm cheapo! And a new Metz AF-4C Flashgun Woooo. And a passion for photography. www.rtwphotography.wordpress.com |
#3 |
With respect mate if you have to ask those questions 3 hrs before a wedding then i have to say that it is not really your place to be there!
Jon. S. LRPS ------------ Canon 5D Mark II Canon 30D (for quick snaps) Loads of L's |
| sponsored links |
#4 |
since it's well past three hours, all i can say is i hope everything worked out well for you. i'm crossing my fingers and hoping you at least decided on renting some equipment because the gear in your signature will be very hard to work with in an indoor wedding ceremony environment.
5D3 | 5D2 | Z21 | 35L | 50L | 85L | 135L |
#5 | |
BTW: the groom called and cancelled about an hour before i was supposed to get there...
#6 | |
cancelled you photographing it or cancelled the wedding?
for future use, don't do a wedding for free, look at the stress it puts you under not to mention the hours you'll put in, putting up with that for free is totally nuts, doesn't matter if it's your first or last. I look at it like this, if you think you're good enough to shoot a wedding in the first place then you must be worth $. If you were a wood chopper would you chop wood for four days for free? Quote:
| Thread Tools | |
| Display Modes | |
| Quick flash tips | orisky | Small Flash and Studio Lighting | 6 | 18th of January 2009 (Sun) 19:03 |
| Help! Quick Tips on Sharpening in Bridge | heathermarie | RAW, Post Processing and Printing | 10 | 11th of June 2008 (Wed) 01:57 |
| Need some quick tips on child portraits!!! | Photolistic | General Photography Talk | 5 | 3rd of November 2006 (Fri) 22:44 |
| quick question & tips | kaitanium | Small Flash and Studio Lighting | 8 | 5th of November 2005 (Sat) 18:48 |
