Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Nature & Landscapes Talk
Reply
Thread Tools Display Modes
Old 25th of March 2009 (Wed)   #1
anirudhlohia
Default Big Depth of Field with CanonSX200
Hi,
I want to shoot images with big depth of field
Its highest fstop is f-8. At 28mm I have to focus approx. 3.3m to get max. depth of field.
How do I do this with Canon SX200 (or Canon SX110 or any point and shoot with manual focus option)., it focuses only on center.
I have not been able to fully understand how to use manual focus in this case.
Thanks in Advance
Anirudh
anirudhlohia is offline   Reply With Quote
Old 26th of March 2009 (Thu)   #2
Karl Johnston
Rare exception that I didn't say anything stupid"
Karl Johnston's Avatar
Default Re: Big Depth of Field with CanonSX200
Read up in the manual about how to activate Manual focus on the camera. In the sx100 i recall it was to push the set button twice, and then rotate the little dial to the MF square. Then you can roll the dial (on the back of the camera) any which way to decrease the focus distance in mm.
To get the maximum DOF, I advise using Infinity Focus and F8. Also make sure you're zoomed out to the widest focal length ( 28mm )
Karl Johnston is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Depth of field, what causes it? ben4633 General Photography Talk 14 26th of November 2008 (Wed) 15:21
Scheimpflug: Depth of field VS Depth of focus alteschule101 General Photography Talk 12 22nd of September 2007 (Sat) 09:40
Field of Focus/Depth of Field (Sandpiper) EdV Birds 4 25th of March 2007 (Sun) 20:11
Depth of Field Desert Dweller General Photography Talk 1 14th of May 2006 (Sun) 15:00
Depth of Field SezzySue General Photography Talk 2 15th of January 2006 (Sun) 08:57
