#1 |
With the 300D there are two choices , : 1 camera does what it wants ie auto , : 2 single focus point . Ideally i would prefer choices of focus points in between the two options . I know the 20D
has 9 points but is it the same as 300 in choice ? |
| sponsored links |
#2 |
what do you mean?
you want to select 2 points yourself?
Forgive me for my sucky English, but it's probable better than your dutch 1DmkIII / 500D / 20D / 2 x POTN strap / speedlite 580EX EF-S 10-22 / EF 17-40 L / EF 100-400 L / EF 24-105 L / EF 50 F1.8 II / sigma 150mm F2.8 macro manfrotto monopod and tripod and some heads / photoshop CS4 / lightroom 2.4 / WACOM Intuos3 A5 / Canon MP600R my gallery |
#3 |
Light Bringer
In single focus point mode you get to choose which focus point you want to use. The 20d has 9 points, the 300D has 5 or 7, I forget which, but you can choose which you want to use. I usually use the centre point, though when i'm using a small aperture I use a different focus point rather than focus-recompose, as focus/recompose can stuff the focus up.
NZIPP Qualified Professional wedding photographer.
Camera and Lens Reviews ~ Wellington Wedding Photographer Wellington Wedding Photographer (site2) ~ Wellington Wedding Photographer (site3) Read all my FAQs (wedding, printing, lighting, books, etc) |
| sponsored links |
#4 |
What exactly do you mean - do you want to be able to choose multiple focus points manually? That can't be done with the 300D, 350D, 10D and 20D.
The 10D (and probably the other cameras also) has an A-DEP mode (Automatic Depth of Field). When you set the camera to this mode, it chooses an aperture so that everything covered by the AF points will be sharp. Look it up in the manual. My EOS 30 (Elan 7E in the USA) doesn't have A-DEP, but DEP mode. In that mode you first focus on one subject, then on the other, and the camera chooses an aperture so that both subjects are sharp (inside the depth of field). I've never used it a lot, but DEP mode is probably more useful than A-DEP, since you can choose two points to focus on yourself.
Please visit my gallery! Canon EOS 5D EF 24-105 f/4 L IS, EF 70-200 f/4 L IS, EF 35 f/2, EF 50 f/1.8 II, EF 100 f/2.8 Macro USM Extender EF 1.4x II, Speedlite 550EX |
#5 | |
#6 |
User is banned from forums
Please post the image.
#7 | |
#8 |
If you want 2 objects in focus which are not on the same plane, you need to increase your DOF by selecting a higher aperture depending on how far apart those 2 objects are.
If you're using A-DEP mode, you need to check whether the focus points have latched onto whatever you want to be in focus. I never use this mode since it's more trouble than it's worth and sometimes a hit or miss if you're not careful. IMO, better to use Av mode and select the right aperture setting for the amount of DOF you want.
tyr Canon 20D, Fujifilm F10, Canon 28-70/2.8L, Canon 70-200/4L, Canon 50/1.4, Canon 580EX, Canon 420EX, Canon i9900, Canon iP6700D, Lexar 80X & Sandisk Ultra II CF Cards |
#9 | |
Moderator
...Leo |
#10 |
Must be a stuttering finger, cause it looks more like f2 at 10 feet for a 50mm. That gives you a little over a foot of DOF, which would be enough to keep the one girl mostly in focus, and everything else out of focus.
Canon 20D with battery grip, EF-S 18-55mm, EF 50mm f/1.8 II, EF 70-200mm f/4L, EF 24-70mm f/2.8L, EF 70-200mm f/2.8L IS, 580EX, 420EX's, Epson P-2000, some umbrellas and other stuff... |
#11 | |
Moderator
Location: The Left Coast in the Land of Fruits and Nuts
Canon Pro1 and Colt .380 are always with me. If you don't have it when you need it, you can't shoot it. That which does not kill me ~~ Should Run. كافر 5DMkII, 7D, 70-300L IS, 24-105L, 100-400L "PERSONAL MESSAGING REGARDING SELLING OR BUYING ITEMS WITH MEMBERS WHO HAVE NO POSTS IN FORUMS AND/OR WHO YOU DO NOT KNOW FROM FORUMS IS HEREBY DECLARED STRICTLY STUPID AND YOU WILL GET BURNED." For Sale: ASUS Netbook |
| Thread Tools | |
| Display Modes | |
| 1D MK II N - focus points? | dawnrogers | Canon EOS Digital Cameras | 4 | 19th of March 2007 (Mon) 08:31 |
| focus points | britt777 | Canon EOS Digital Cameras | 4 | 14th of August 2006 (Mon) 11:54 |
| What focus points do you use | Keiffer | Canon EOS Digital Cameras | 44 | 13th of April 2006 (Thu) 08:46 |
| Focus Points | jtmorales | The Business of Photography | 4 | 12th of April 2006 (Wed) 17:54 |
| Focus Points ! | Marshy | Canon EOS Digital Cameras | 5 | 4th of April 2005 (Mon) 16:38 |
