Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Macro
Reply
Thread Tools Display Modes
Old 10th of April 2005 (Sun)   #1
Aethyr
Aethyr's Avatar
Default Couple macro flowers.
I was playing around with my kit lens earlier today out of boredom. I hadn't really been using it as often as the 50/1.8 so I thought I'd see what it is capable of. I definitely like how I can get the actual physical lens closer to the object, rather than having to be farther away and cropping it. Anyway, my manager bought these flowers for the lobby of the hotel I work in, and I thought the roses were a pretty color.
Canon Digital Rebel XT w/ kit lens (18-55mm f/3.5-5.6)
Canon 50mm f/1.8
Canon 75-300mm f/4-5.6 III EF USM
Visit my gallery!
Aethyr is offline   Reply With Quote
Old 10th of April 2005 (Sun)   #2
eosster
Default Re: Couple macro flowers.
Little soft, of course JMO.
Canon EOS 60D | EF 50mm f/1.4 USM | Canon 430EX II
eosster is offline   Reply With Quote
Old 10th of April 2005 (Sun)   #3
Aethyr
Aethyr's Avatar
What would you suggest to get a sharper image?
Canon 50mm f/1.8
Visit my gallery!
Old 11th of April 2005 (Mon)   #4
jfrancho
jfrancho's Avatar
Assuming you were shooting in the lower ISO range (100-200): Higher aperture setting. Try somewhere around f/5 to f/8, in AV mode. Once you get the sharpness you like, go to M and dial in that aperture, and adjust the shutter speed to properly expose to the right.
jfrancho is offline   Reply With Quote
Old 12th of April 2005 (Tue)   #5
markubig
markubig's Avatar
if you're using an aperture of f/1.8, your DOF is going to be razor thin at a close shooting distance. like jfrancho said, stop it down to f/8 to try to get more of the flower in focus. Also, remember that there is a minimum focusing distance for a lens (i believe it is approx 11 inches for the kit lens?). that distance is from the sensor to the subject, so the length of your lens is part of that distance. Anything closer than that distance, then your camera will not focus.
Also, do you use Photoshop? there is a feature called USM (Unsharp Mask) that will sharpen your photos even further.
~Mark
Canon 7D |40D
Canon EF-S 17-55 f/2.8 IS USM | Tamron SP 70-200 f/2.8 Di VC USD
Canon Speedlites 580exII, 5800ex
. . . and a bunch of other stuff
markubig is offline   Reply With Quote
Old 13th of April 2005 (Wed)   #6
Aethyr
Aethyr's Avatar
The largest aperature the kit lens has is 3.5 so I can't even get down to 1.8, but that's usually what I use with the 50mm because I like the effect.
It seems like I need to try using M mode more often. Most of the time I rely on P or Av mode. I don't have my time to practice because I work 65 hours a week, but I will try stopping it down to get more sharpness.
Canon 50mm f/1.8
Visit my gallery!
Old 13th of April 2005 (Wed)   #7
jfrancho
jfrancho's Avatar
I like to use P/Av/Tv to get close to what I want, then M to "fine tune" it. Eventually, you can use the exposure meter and histogram. I can appreciate the time constraints though....
Old 13th of April 2005 (Wed)   #8
markubig
markubig's Avatar
sorry about the brain fart on the 1.8 . . . forgot the kit lens wide open is 3.5. even so, you should still try a higher f-stop for a deeper DOF. However, you are going to need a tripod for the slower shutter speeds.
~Mark
Canon 7D |40D
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
A couple flowers gary88 Wildlife 1 2nd of July 2007 (Mon) 20:10
Couple of Flowers col4bin Wildlife 3 12th of June 2007 (Tue) 09:00
Just a couple of flowers stoneylonesome Macro 5 11th of June 2007 (Mon) 08:13
A couple of flowers gbpro1 Wildlife 3 10th of April 2007 (Tue) 20:24
A couple flowers... grosos102 Macro 3 6th of April 2007 (Fri) 09:09
