Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Still Life, B/W & Experimental Talk
Reply
Thread Tools Display Modes
Old 3rd of April 2009 (Fri)   #1
amironsi
amironsi's Avatar
Default Paintings photography????!!! any tips???
A friend of mine that has an art exhibition asked me to shoot her paintings.
i thought of it as a product photography normaly, i will need a lightbox and lighting...
Do i need anything more, any special tips for the photography it self
she wants the high res pictures for later on mass production of the same artwork if required....
Would appreciate any info
thanks a lot
It's all about WHITE BALANCE.
http://www.amirwilliam.com
40D, 350D,BG-E3,EF-S 17-55 f/2.8,EF 70-200 f/4 L,EF-S 18-55mm f/3.5-5.6,580EX Speedlite,190XPROB,681B,322RC2,804RC2,234RC,5 batteries and 12GB of memory,Lowepro Stealth Reporter 650AW.
amironsi is offline   Reply With Quote
Old 3rd of April 2009 (Fri)   #2
john-in-japan
Default Re: Paintings photography????!!! any tips???
I think that with good lighting from above downward, like you see in galleries should be fine as long as no glare when looking straight on at the painting. On tripod with photo plane parallel to the painting, and a relatively low number f/stop like f/2.8, and lens centered in the painting. Center point or evaluative should work - experiment. Manual focus can work as well. I would not use flash. If you have borders outside the painting, straighten and crop, but try to fill as much of the frame as possible to keep clarity if enlarged. To get true color might be most difficult, so watch white balance and custom function settings. Fortunately, your subject is still and you can try many things to get it right. I shot this, available light spur of the moment, hand held. I think these are not so difficult. Good luck.
JohnW
5D Mark II Dual Battery Grip, 100-400f/4-5.6L, 200 f/2.8L, 70-200 f/2.8L II IS, 24-70 f/2.8L 180Macro f/3.5L, 85 II f/1.2L, 17-40 f/4L, 50 f/1.4, 50 f/2.5 Compact Macro, MPE-65, 550EX, 580EXII, Canon RingFlash, RRS Perfect Portrait Pkg., Velbon with PH275 and Slider, bunch of filters, Canon 1.4X & Having Fun! http://kamogawa.smugmug.com/
john-in-japan is offline   Reply With Quote
Old 14th of April 2009 (Tue)   #3
BrianN324
If I might suggest: this sounds pretty much like copy work. Two lights, 45 degrees from the subject the same as you would for any flat copy work. You can work vertically or horizontally depending on your preference and equipment setup, (also dictated by the sizes of the originals) use a prime lens probably in a longer focal length rather than shorter if it's not an actual flat field lens. If you are going for quality image captures for reproduction, you need to light the subject evenly (meter around four corners and the center to match exposure) and eliminate shadows. You didn't actually say you were going to shoot this at the exhibition, but it would of course give you better results in a studio type environment with controlled lighting. Hope this is of some help.
BrianN324 is offline   Reply With Quote
Old 14th of April 2009 (Tue)   #4
BrianN324
Also: align your camera to the center of the artwork, keeping the sensor (film) plane in alignment with the subject as close as possible. Once you have the camera leveled its usually easier to have someone move the artwork to frame the image. For this, vertical might be easier working from a tall tripod with a ladder if necessary as you can use a bubble level to help align the camera to the floor or table top. Gravity is your friend in this case, as long as you are careful on the ladder.
Old 16th of April 2009 (Thu)   #5
amironsi
amironsi's Avatar
WOW that's really gr8 information. Thanks a lot
After all this info i am thinking this way, please correct me if i am wrong.
i can level... and i am thinking of using a light box of course and i will have even light from both sides.
I think with the light box i won't have to worry a lot about the direction of light as it will be diffused anyway.
I will be using the 17-55, at 55mm and F around 8 with iso as low as i can go.
I thought of attaching the flash to my camera and have it direct to the painting to have no shadows but i thought that will make me loose the details of the pattern of the painting.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
G9 tips for car photography Crissy7682 Canon G-series Digital Cameras 3 6th of January 2009 (Tue) 18:58
Bird photography tips oassayag Birds 2 4th of June 2008 (Wed) 11:15
Taking pics of paintings - any tips? mikeanywhere General Photography Talk 5 15th of October 2007 (Mon) 08:29
New to photography need some tips panther21 General Photography Talk 2 3rd of February 2007 (Sat) 09:45
nude photography tips TwoTone Canon G-series Digital Cameras 1 5th of September 2002 (Thu) 19:41
