Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > RAW, Post Processing and Printing
Reply
Thread Tools Display Modes
Old 5th of August 2001 (Sun)   #1
John Vito
Default Pekka or ? Setting White Point
Pekka-
I notice that one of the things that characterizes your photos is the vivid, natural colors. I know you use RAW format and frequently set the white point. I have been having some problems setting the white point, especially in cases where there is no white to use as a reference or in the case where there are several white objects in the photo but the objects are in different lighting conditions. Have you posted anything in the way of a tutorial on how you go about setting the white point? If not, can you give a brief explanation. I would like to know what software you use when converting. Also, I would like to know if there is a batch method. For example, I take three shots in the same lighting conditions and the second one happens to have a white object in it that I can use to set the white point-how can I use that same setting to process the other two.
Thanks for any info you or others can give.
JOHN
John Vito is offline   Reply With Quote
Old 5th of August 2001 (Sun)   #2
mpkirby
Default Re: Pekka or ? Setting White Point
I can't answer the part about what pekka does, but if you use zoombrowser, you can ctrl-click the pictures you want to convert. THe first picture selected will be used to pick the white-point from. After you select convert to raw with user options (or whatever the name of the menu item is), it brings up the thumbnail of the first picture. You pick the white point, and it will convert the remaining images using the whitepoint of the first image.
A couple of points when using raw.
1) Remember the best way to get vibrant colors in your picture is to have good lighting with a good exposure. If the right light doesn't make it to the CCD, nothing in the Raw conversion is going to fix it.
2) You can select anything that is supposed to be neutral. Grey All the way from "white", to "black".
3) Selecting the white point is most useful when you have multiple types of light coming into a scene. For example, room lighting, window lighting, and flash. Here you may be forced to make a compromise. If you select a white point for the flash, the background looks like crap. If you select for the background, the people look green. Selecting the whitepoint by hand lets you pick something in the room that is a mix of lights.
4) You can carry around a grey card, and shoot a picture of it if you are going to be taking a whole series. Just make this the first thing you pick in zoombrowser when you convert raw to tif.
Mike
mpkirby is offline   Reply With Quote
Old 8th of August 2001 (Wed)   #3
Pekka
El General Moderator
Pekka's Avatar
mpkirby had good points there.
Something I do often when seeking white point: see where the strongest light is coming from, follow the path of the light and see where it hits something on the picture that shoud be neutral (shade of gray). As mpkirby said you should try to avoid having many different light sources, as it makes overall balance uneven.
And don't try to seek for "real" colors, try to get out colors which look good. Often reality is unimpressive - consider RAW export your darkroom where you try to get the best out of the shot.
This signature signifies my significance significantly
Photo Gallery
Pekka is offline   Reply With Quote
Old 25th of August 2001 (Sat)   #4
sjguenard
Default Re: Setting White Point
Quick and dirty: point lens at most prominent light source (not the sun!) and follow directions in manual p. 64. Works under sodium, tungsten, flurescent.
I always carry a folded piece of white paper in pocket to "read" hard to get light by reflection. Say "shooting" little critters in pet store cages etc.
sjguenard is offline   Reply With Quote
Old 21st of November 2001 (Wed)   #5
transco
For some reason I am unable to control which picture is used for setting the whitepoint when doing a batch convert by holding down the control key and selecting multiple CRW files. Someone wrote that it will use the first picture selected, but it doesn't work for me. I've tried resorting, renaming, renumbering, but Canon seems to have its own criteria for which CRW file it opens first. I'm using W2K.
transco is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Depth of Field after setting focus point Flipper_ General Photography Talk 9 2nd of March 2007 (Fri) 14:27
Should the gray/white card fill the frame when setting White Balance? TMR Design Small Flash and Studio Lighting 3 3rd of November 2006 (Fri) 13:52
Setting White Balance pacific General Photography Talk 6 9th of January 2006 (Mon) 21:27
Choice of AF point setting kram Canon EOS Digital Cameras 14 18th of June 2005 (Sat) 14:38
Setting Focal Point - 300d Mr.B Canon EOS Digital Cameras 2 26th of June 2004 (Sat) 15:11
