Go Back   Canon Digital Photography Forums > 'Photo Sharing' section > Weddings and Other Family Events
Reply
Thread Tools Display Modes
Old 14th of April 2009 (Tue)   #1
highway0691
highway0691's Avatar
Default Slideshow Software (which one?)
Hi there
I'm wondering what other pro wedding photographers are using. I have used ProShow Gold for the last three years and have not been totally happy with it. Mainly because whilst I can get a quality Television playback, I can't get a good playback on a computer, (which is what a lot people want).
Anyhow - I am after something fairly easy to use. Typically I have a simple setup, three background tracks with photos going for three seconds each with no fancy transitions - just a fade to over 2-3 seconds. This is fine and what people like.
Quiet possibly I might have to stick with PS Gold. Would be very interested to hear what you people out there are using.
thanks
Damian
There is nothing worse than a sharp image of a fuzzy concept. Ansell Adams
highway0691 is offline   Reply With Quote
Old 14th of April 2009 (Tue)   #2
hillierluke
Default Re: Slideshow Software (which one?)
DVD Photo Slideshow Professional might be one to consider - I've used it a few times with good results for large format LCDs and computer monitors.
My Website: http://www.purefocus.com.au
My Gear: 5D Mark II - Rebel XTi - 70-200mm f/2.8L IS - 24-70mm f/2.8L - 17-40mm f/4L - 24-105mm f/4L- 28-135mm f/3.5-5.6 IS - 50mm f/1.8 - Tamron 17-50mm f/2.8 - 580EX II - 420EX
hillierluke is offline   Reply With Quote
Old 14th of April 2009 (Tue)   #3
seaside
Slapped with a ridiculous title
seaside's Avatar
I don't often shoot weddings but have produced wedding slideshows. Also, shows for other occasions and events. Photodex ProShow Producer works for me. There is a Gold version that's not as robust and somewhat less expensive too. You can download trial versions of most programs that will be suggested in response to your question and see which best fits your needs.
Chris
Creative Tools / ZENFOLIO
Someone stole all of my photography equipment and replaced it with exact duplicates.
seaside is offline   Reply With Quote
Old 14th of April 2009 (Tue)   #4
evo82nv
I use photodex pro show producer, it has flash code and html code. Pricey but well worth it!!!
http://www.photodex.com/products/producer
evo82nv is offline   Reply With Quote
Old 14th of April 2009 (Tue)   #5
Yanis
Yanis's Avatar
Originally Posted by highway0691 View Post
Hi there
Greetings Damian,
I personally use ProShow Producer. I am at work right now so I cannot check my Producer's settings but I thought there was a setting that allows you to change the resolution rendering. In a nutshell, if Gold has this setting, try matching its rendering resolution with your monitor's resolution. If this doesn't do the trick, try this site: http://www.proshowenthusiasts.com
Lots of very helpful forum members.
Peace,
Yanis
Gear:
5D MK II | 30D | 70-200mm f/2.8L USM IS | 24-70mm f/2.8L | Canon 2x II Extender | AB400 | AB800
Yanis is offline   Reply With Quote
Old 14th of April 2009 (Tue)   #6
seaside
seaside's Avatar
Another thing. Make sure you have the lastest version of PS Gold installed and I would suggest using Taiyo Yuden premium or Verbatim DVD's to burn the shows. I personally won't use any other brand of CD/DVD media.
Chris
Old 17th of April 2009 (Fri)   #7
drewandersonphoto
drewandersonphoto's Avatar
I was looking for a good software myself but needed this for MAC and came across FotoMagico I used it and it is Amazing. give it a look-see
Phoenix Arizona Wedding Photographer
drewandersonphoto is offline   Reply With Quote
Old 17th of April 2009 (Fri)   #8
evo82nv
I have used Photodex Pro Show Producer for the last year with good results. Gold seemed really limited so I went for the producer for more transitions and other tools.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Slideshow software JMW-Photo Weddings and Other Family Events 10 21st of March 2007 (Wed) 12:44
Slideshow software sito RAW, Post Processing and Printing 8 28th of September 2006 (Thu) 03:19
Slideshow software daclozer RAW, Post Processing and Printing 20 1st of February 2006 (Wed) 08:43
Slideshow Software susanweddings RAW, Post Processing and Printing 13 20th of September 2005 (Tue) 16:09
Slideshow Software luisgriveratorres General Photography Talk 2 14th of December 2004 (Tue) 13:44
