#1 |
Can anyone recommend a good external mic to use with the 5D? I get this crackling noise when I film. I am going to be using the mic to record mostly instrumental music (piano). Here is a video that I shot today. The sound isn't bad, it's just the crackling noise. It really takes away from the piece.
http://vimeo.com/4173949 Can anyone give me any advice on what to do/buy so that I will get better sound quality? thanks! |
| sponsored links |
#2 |
which lens? sounds like IS
??your on a pod so you can turn it off - hit start early and edit out where you touch the cam.... (which youve done anyways...) i hear alot of people looking at the rode video mic... shotgun mic, attaches to where the flash goes.. but havent used one myself... i would imagine youd want something separate for your audio recording in that scenario with a time stamped start and mix it in post - especially seeing as your vid is more about audio than video...
My gallery - just posted some of my top shots 1DmkIII / 5DMKII [50mm f1.4] [85mm f1.8] [100mm f2.8 MACRO] [17-40mm f/4L] [24-70mm f/2.8L USM] [24-105mm f/4L IS USM] [100-400mm f/4.5-f 5.6L IS USM] Canon 1.4xII - Speedlite 580EXII - EPSON P-5000 - Lowepro Bags - Manfrotto 682B Monopod & 055XproB Tripod - 488RC2 |
#3 |
I've got a Rode Videomic. It sounds really good, and it won't break your budget. But ditto to the above poster, if you're serious about sound, record outside camera.
http://www.bhphotovideo.com/c/produc...a_Mounted.html |
| sponsored links |
#4 |
But how would you attach a Rode on a 5d mk ii when the camera doesn't have a hot shoe?
#5 | |
Phil
Canon 1D Mk IV / Canon 24 - 70mm f2.8 L USM / Canon 85mm f1.2 L / Canon 70 - 200mm F2.8 L IS USM / Think Tank Antidote V2 / Think Tank Retrospective 30 Pinestone |
#6 |
Huh?
Gear list "Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters. Beginner's guide to printing. The PoTN film thread. |
#7 |
Mea maxima culpa. Or, as Homer Simpson would say, "Duh!" I was muddled...thinking of onboard flash.
#8 | |
Cream of the "Prop"
Pianos are usually "close mic'd" IOW, the mic is mounted IN the piano or on a side to maximize the sound quality. If nothing else, you want a very directional (aka "shotgun") microphone that will help attenuate surrounding noise. IIRC, the one mentioned above is shock mounted and fits the hotshoe mount.
"If you aren't getting extraordinary images from today's dSLRs, regardless of brand, it's not the camera!" - Bill Fortney, Nikon Corp. |
#9 | |
#10 |
Location: A recording studio somewhere in the UK or USA
Don't expect amazing sound from a budget (less than $500) shotgun mic. The Sennheiser (eg mke 300's) or Rode's will be decent but will never be excellent.
#11 |
I picked up a (Sony ECM-MS-908-C) really did not know how deep I would go into video but so far its been good but have not tryied it outside in windy conditions as yet.
http://www.bhphotovideo.com/bnh/cont...ecmms908c&ci=0
Gary 5D mkII; D-Lux 5; Lens: 24-105 f4 IS; 24-70 f/2.8; 70-200 f/2.8 IS; 85 f/1.2 II; Extender EF 1.4x II; EF 2x II; Flashs Metz 76 MZ-5; Canon 580EXII ; Leica CF-22 |
#12 | |
I thought mine may have been special Phil
#13 |
I was thinking about going down the route of a seperate digi recorder like an Edirol / Tascam and then put the video and sound together in software.
Phil
#14 |
For recording music, the place you have the camera most likely isn't the place you want to place your microphone(s)..
If you're on a budget Korg MR1, Zoom H2 or H4 would get you started.. Be sure to record in 24bit/48kHz to match your movies sample rate.. Import the files in your editing software and sync it with the sound from the camera.. (a short transient like a hand clap will make it very easy to sync) Cheers, Morgan
gear: EOS 5D mkII | EOS 40D | 85L Mk II | 24-70L | 580EX II Elinchrome Style RX 600 kit | EL Octa 190cm | EL Softlite 82 |
#15 |
I'm using the Zoom H4n as others have suggested. It's a perfect solution, with stamp for post, and a couple of XLR jacks for whatever mic you'd like to use. It comes with wind screen, carrying case, tripod mount (get a cheap tripod and you're set!) and a 1gig SD card. You can obviously upgrade your card, but I get an hour at 24bit 48k with the 1gig! Pretty decent, considering one of my cams; the 40d or 5d2 came with a 32mb SD card, LOL! It's a true 4 track recorder built in, which is great...the internal mics are also very high quality and switchable to 90/120 degree recording.
I had been using the Tascam, DR-1 which is decent but without the XLR inputs. I'd stay away from recording with the "in camera" audio. The auto gain control is a pain. The Magic Lantern F/W may be worth looking at for ya too. It gives you audio levels and a bit more control over AGC. J
Canon 1D4/5D2/7D/G10/G9/S95 Canon 24-70L*24-105L*70-200 IS/2.8LV2*16-35L*35L*50L*85L.v2*200L*400mm f4 DO/IS*100mm2.8 macro*70-300is*Sigma 10-20&50/1.4--580EX2 (x2) (Motion) Panasonic HVX200a/HPX170 and Sony EX-1***{Mac/FCP/PS/AE}
| Thread Tools | |
| Display Modes | |
| External Mic and better AGC revelation? | DeCeccoNET | Digital Video | 1 | 19th of June 2009 (Fri) 11:06 |
| External flash advice needed | Rishka78 | Small Flash and Studio Lighting | 4 | 19th of December 2008 (Fri) 18:24 |
| Zoom Mic/ 7.1 Ch. Mic, Hotshoe Mount 5dmkII | twofruitz | Accessories & Storage | 2 | 20th of October 2008 (Mon) 11:32 |
| Need external Mac HD advice | RichNY | Accessories & Storage | 3 | 30th of June 2007 (Sat) 00:06 |
| need advice on best external hard drive | inthegarden | Accessories & Storage | 22 | 17th of October 2006 (Tue) 20:07 |
