Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Sports Talk
Reply
Thread Tools Display Modes
Old 18th of April 2009 (Sat)   #1
mp2997
Default Aperture ? - 70-200 f4 non-is
Why would I shoot at any other aperature than F4 when shooting baseball or sports in general. I don't need a wider dof. The reason I ask is that I have read comments about some lenses being soft wide open but I don't understand this. Would it not be sharper wide open? What am I missing?
New to XSI and 70-200 F4 and enjoying them both. Great forum. I have really learned a lot lurking. Thx!
mp2997 is offline   Reply With Quote
Old 18th of April 2009 (Sat)   #2
dmwierz
dmwierz's Avatar
Default Re: Aperture ? - 70-200 f4 non-is
This is a fairly complicated topic, but I'll tell you what I know and since that's not much, it's gonna be pretty basic.
All lenses are sharper when stopped down a little from wide open. This is a result of the Physics involved in making a lens. At large apertures, something called spherical aberration reduces sharpness and at smaller apertures diffraction reduces image quality. You want to find the "sweet spot" where aberration and diffraction are more or less balanced out in their impact on image quality and this is normally somewhere between f/4.0 and f/11.
This sweet spot generally is a number of stops above a lens' largest aperture which is one the many reasons why large aperture fast prime lenses are desirable - their sweet spot occurs at a larger aperture thereby allowing you to shoot in lower light and gain the benefits of smaller depths of field while still being at optimal image quality.
I'm sure people on this board who are better versed in this topic than I am will weight in (or you can go to another forum on POTN and do a search).
Hope this helps.
http://www.denniswierzbicki.com
http://www.sportsshooter.com/dmwierz
Dennis "
Yeah, well, sometimes nothin' can be a real cool hand."
dmwierz is offline   Reply With Quote
Old 18th of April 2009 (Sat)   #3
davethejnz
davethejnz's Avatar
Dennis you are too humble. I trawl this sight often, looking for your words of wisdom and and advice.
Thanks for all you give
Novice - So novice that I can learn from anyone even beginners
David
davethejnz is offline   Reply With Quote
Old 18th of April 2009 (Sat)   #4
Roy Mathers
I am Spartacus!
Roy Mathers's Avatar
Dennis, I agree with what you say, but does it apply as much to high quality lenses like the 70-200 f/4 IS? What I mean is that I believe the difference between full aperture on this lens and, say, f/5.6, is nowhere near as marked as it is on cheaper lenses.
Roy Mathers is offline   Reply With Quote
Old 18th of April 2009 (Sat)   #5
dmwierz
dmwierz's Avatar
Roy,
As I understand it, high quality glass often has a wider sweet spot, one that starts at a larger aperture and extends more f-stops (than a lesser quality lens) until IQ diminishes.
Dennis "
Old 18th of April 2009 (Sat)   #6
Roy Mathers
I am Spartacus!
That's really what I meant Dennis, expressed in a different way.
Old 18th of April 2009 (Sat)   #7
mp2997
Thanks for the replies. I am pleased with the IQ I get at F4...just trying to understand the comments I have read on other threads and make sure I am not missing an opportunity to get sharper images. I will experiment a little at 5.6 in good light and see what happens. Thanks again.
Old 20th of April 2009 (Mon)   #8
Bkolowski111
In my own experience, and from drawing on the experience of others, it is often your best bet to shoot your lens wide open when shooting sports. I often shoot my 80-200 at 2.8 even on sunny days. That helps me to get the fastest shutter speed possible and to get subject isolation. Occasionally I will stop down as low as f/4. My lens is pretty sharp at 2.8, but becomes razor sharp at f/4.
You will have to experiment with your lens to find out where its sweetspot is. You will probably have to shoot at f/4 in most sport shooting situations in order to get a fast enough shutter speed.
BRAD
Nikon D300 w/ MBD-10
17-55 f2.8 | 80-200 f2.8D | 50 f1.8 |
Bkolowski111 is offline   Reply With Quote
Old 20th of April 2009 (Mon)   #9
dmwierz
dmwierz's Avatar
Brad,
I don't think that's what the OP was asking, plus I don't necessarily agree sports should be always shot wide open. Yes, when you need to pull the subject off a background or in amongst a lot of other things, a large aperture is critical. However, when you have a lot of air behind the subject, like is seen when shooting down the length of a football field or soccer pitch, or across a Major League baseball diamond or even down a basketball court or hockey rink, you can frequently stop down a little, get the benefit of sharper images, a slightly increased depth of field (important for sports like basketball and hockey where players are grouped together with many of them involved in the peak action of the play) and get plenty of subject isolation.
Dennis "
Old 20th of April 2009 (Mon)   #10
jptsr1
of the lenses i have my 70-200 4l shows the least benefit from being stopped down. Only when i am pixel peeping and in the most extreme situations is there a discernable difference (to me). if your getting good shots shooting wide open most of the time and dof is not an issue for you then i see no reason to change your habits.
J.
Et Facta Est Lux
Flickr
For Sale: Sigma 30mm f1.4
jptsr1 is offline   Reply With Quote
Old 21st of April 2009 (Tue)   #11
Bkolowski111
Brad,
Notice I didn't say it is ALWAYS best to shoot wide open. In my experience I usually don't find it necessary to stop down (when shooting sports). Sometimes I do, but it is not essential. so basically the OP was asking if it is a good idea to stop down, and I am saying it is not essential IMO. If there is plenty of light then its probably a good idea to stop down a bit, but if there is not enough light then its not a big deal if you shoot wide open. Your pictures may be a little less sharp, but you will usually only notice if you are pixel peeping.
Hope that better explains what I was trying to say.
Brad
BRAD
Old 21st of April 2009 (Tue)   #12
[Hyuni]
[Hyuni]'s Avatar
I'll attempt to make it a little easier to understand
If you look at a magnifying glass, we tend to look at the center of the glass to see the image, correct? The reason we do that is because the center is the least distorted part of the lens. Once you venture away from the center, the images get more distorted the farther you go away from the center.
Also, adjusting the lens by 'stopping down' or making the hole smaller makes the image sharper. Imagine that you're reading small print. You noticed that you start squinting your eyes to read better. That's exactly what you're doing by adjusting your aperture.
Did that make a bit more sense?
5D Mark II juliet II
Tamron 17-35 l EF 35 ƒ1.4L l EF 135 ƒ2.0L l EF 70-200 ƒ4L l YN460 l 580EX II l Flick'd
[Hyuni] is offline   Reply With Quote
Old 21st of April 2009 (Tue)   #13
matonanjin
You've received great answers on this I am sure they have helped. I do 97.3% of my outdoor shooting with the 70-200 F/4. One of the advantages to this lens is that it is so incredibly sharp wide open.
As you said you don't want a wider DOF and generally want the background blurred to isolate the subject. However, I will occasionally stop down just a hair to get just a slightly deeper DOF. The reason for this is to provide a little bit of latitude on AF errors. This lens is also very fast focusing. But with really fast moving subjects I may just give myself that margin of error. I'm not talking F11 or 16. I'm talking 5.6 at most. And this is only if I have plenty of light and don't have to sacrifice any shutter speed.
matonanjin is offline   Reply With Quote
Old 24th of April 2009 (Fri)   #14
mp2997
Thanks to all. Last weekend was not ideal (weather wise) so I had to stay nearly wide open to keep my SS 1000+. It is going to be a great day to take pictures tomorrow so I plan to experiment some. I do like the idea of having a little more room for error in focusing with a slightly larger dof.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Aperture: Direct managed RAW > PS/ACR > Aperture Library possible? gr8bob RAW, Post Processing and Printing 0 11th of January 2009 (Sun) 13:11
Aperture-> PS -> Aperture = sharper image? Starbucker RAW, Post Processing and Printing 2 10th of December 2008 (Wed) 18:24
Sort EXIF in Aperture 2 - Aperture guru question... rrrize RAW, Post Processing and Printing 1 29th of April 2008 (Tue) 13:01
70-200 f/2.8L IS - Aperture selection thoreau Canon EF and EF-S Lenses 6 6th of March 2008 (Thu) 00:36
Fixed aperture and variable aperture rcfury Canon EF and EF-S Lenses 9 8th of February 2008 (Fri) 00:16
