Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Nature & Landscapes Talk
Reply
Thread Tools Display Modes
Old 26th of April 2009 (Sun)   #1
Scooby-Bullet
Scooby-Bullet's Avatar
Question 400D - keeps using flash in broad daylight?
Hi - any advice gratefully accepted. 400D in auto mode, taking a general view across gardens at a wedding venue in bright conditions - the flash came on and the end result is a really dark picture - values are 1/500, av = 13.0, iso 400, 28.0 focal length and auto white balance. Seems to be happening quite a lot now. Is it something I'm doing, camera settings gone wrong, lens or what?
Is there a default setting for the camera that I need to reset or something?
Thanks in advance.
Scooby-Bullet is offline   Reply With Quote
Old 26th of April 2009 (Sun)   #2
silvrr
silvrr's Avatar
Default Re: 400D - keeps using flash in broad daylight?
Take it out of Auto!
l 60D l 24-105 F4L IS l 100L Macro l 430EX l 430EX II l Sigma 50mm 1.4 l Kenko Extension Tubes l
Flickr Feedback
silvrr is online now   Reply With Quote
Old 27th of April 2009 (Mon)   #3
blackcap
Sounds broken to me!
blackcap is offline   Reply With Quote
Old 27th of April 2009 (Mon)   #4
Mike
ugly when I'm sober
Mike's Avatar
Thanks in advance.
I agree that taking it out of Auto is your best chance of getting better shots. With the Auto exposure modes the camera is doing all the thinking, even down to whether to use flash or not. And because the camera has chosen to flash, it will try and get the foreground subjects exposed at the expense of under-exposing the background.
Try instead to use the P,A,S,M modes. P is very similar to the "Green Box" auto mode but with extra menu options. A or Av mode gives you control of your aperture while the camera sets your shutter speed. T or Tv stands for Time Value and means you control your shutter speed, while the camera sets your aperture for you. M or Manual gives you complete control and is, in fact, easier than it sounds.
The other thing with the P,A,S,M modes is that the flash will not pop up and fire unless you press the button to pop the flash up yourself.
So for your sunny view across gardens, I guess you want to get everything in focus? in M, set your aperture between f/8 - f/16 and bring your iso down to 100. You are at 28mm so hand-holding the camera you need a shutter speed of at least 1/50sec to eliminate camera shake blur. Use the exposure needle in the view finder as a guide and adjust your shutter speed up until it middles. Take a shot and "chimp" - does it look right or too bright or too dark? If it is too bright make your shutter speed a bit quicker or aperture smaller. Too dark? Open up the aperture a bit or decrease the shutter speed.
Sounds harder than it is so don't be put off! Go out and have a practise and you'll soon forget all about the auto modes!
Oh, and shoot in RAW as you will have a better chance of correcting minor exposure problems than if you shoot in JPEG.
www.mikegreenphotography.co.uk
Gear
UK South Easterners
flickr Blog 5∞px
Quis custodiet ipsos custodes? ::: A closed mouth gathers no foot.
Mike is offline   Reply With Quote
Old 27th of April 2009 (Mon)   #5
Scooby-Bullet
Mike - thanks for the helpful advice, much appreciated! I'll spend some time practicing...
Cheers.
Old 9th of May 2009 (Sat)   #6
iamaelephant
iamaelephant's Avatar
Remove the lens cap before shooting.
(I kid, I kid)
-- Martin
Canon 30D | Tamron 17-50mm f/2.8 | EF 50mm f/1.8 II
Flickr
iamaelephant is offline   Reply With Quote
Old 9th of May 2009 (Sat)   #7
Highlight_Photography
Highlight_Photography's Avatar
(I kid, I kid)
Someone could of told me earlier!
Regards,
Cameron
Website - Gear List -
Facebook - Flickr
Highlight_Photography is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Daylight + Flash Portrait Mark-B People 5 2nd of January 2009 (Fri) 18:23
Broad daylight? scd People 16 19th of May 2008 (Mon) 12:18
force the flas to flash in daylight johnstownwildfire Canon EOS Digital Cameras 7 12th of November 2007 (Mon) 01:10
Flash in Daylight grandadraymond Small Flash and Studio Lighting 9 22nd of September 2007 (Sat) 22:07
Flash in daylight cruiser56 Canon EOS Digital Cameras 1 19th of August 2005 (Fri) 12:04
