Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Small Flash and Studio Lighting
Reply
Thread Tools Display Modes
Old 26th of April 2009 (Sun)   #1
Nick Pro
Nick Pro's Avatar
Default Quantum Turbo Help
Shooting a Sweet 16 recently, my Turbo would only work for about 20 min at a time. I would then have to shut it off, and restart it. (The High voltage indicator would turn off, and the flash would stop receiving power) I replaced the battery very recently, and I have no idea what could be causing this. Anyone have an idea?
Thanks!
Nick Pro is offline   Reply With Quote
Old 26th of April 2009 (Sun)   #2
tetrode
I am a walking repository of thoroughly useless information
tetrode's Avatar
Default Re: Quantum Turbo Help
Thanks!
You're describing the exact symptoms my Turbo was exhibiting about two months ago. Quantum told me it was a battery problem. Installing a new Powersonic did indeed fix my problem. Are you sure the battery you installed was good?
Dave F.
tetrode is offline   Reply With Quote
Old 27th of April 2009 (Mon)   #3
Nick Pro
Nick Pro's Avatar
Dave F.
I bought it new from Batteries Plus, so I would imagine it's good. It was the same brand as the OEM battery too... When I was reinstalling it, could I have not put a cable on correctly?
Old 27th of April 2009 (Mon)   #4
tetrode
tetrode's Avatar
The battery they sent you is an original Sonnenschein? I couldn't find any Sonnenschein batteries on the Batteries Plus website. If you didn't purchase your Turbo new, perhaps the previous owner had already swapped out the Sonnenschein that Quantum installs in new Turbo packs.
Oh, and no, had you reversed the terminal connections, the Turbo would have been totally inert.
Dave F.
Old 27th of April 2009 (Mon)   #5
Wilt
Wilt's Avatar
I presume you used a Powersonic PS-832? Batteries Plus, for some odd reason, carries that battery but does not list the Quantum Turbo in the models of Quantum products for which it sells batteries. The Sonnenshiem A200 is the actual original Quantum-included battery used in the Turbo, now replaced by the A400.
Keep POTN alive and well with member support http://photography-on-the.net/forum/donate.php
Wilt is offline   Reply With Quote
Old 27th of April 2009 (Mon)   #6
tetrode
tetrode's Avatar
I put a PS-832 in my Turbo, Wilt. Works fantastically well. Greater capacity than the Sonnenschein and 1/3 the price.
Old 27th of April 2009 (Mon)   #7
Wilt
Wilt's Avatar
Yes, I put the same battery into my Turbo, only a few months ago (after over a decade of use of the original battery). I only paid $25 shipped, compared to the Batteries Plus price of $33 shipped.
Old 27th of April 2009 (Mon)   #8
Nick Pro
Nick Pro's Avatar
Your right, I did use that battery. I guess the previous owner replaced the OEM pack as well.
Old 27th of April 2009 (Mon)   #9
Wilt
Wilt's Avatar
In that case, I would take the Turbo back apart (as if replacing the battery) and see if something might be causing an inadvertant short, and reassemble carefully to see if the problem persists. It might need a trip to Quantum to sort out failing control electronics
Old 14th of June 2010 (Mon)   #10
mrcanon4life
mrcanon4life's Avatar
Hi, I am new to this forum and would like to know does the Powersonic PS-832 replace the dryfit a200 by Sonnenchein and is it fully operational in the Quantum Turbo ?
I have to replace mine after 8 years of good use...purchased it in 95 and last used in 2003.
mrcanon4life is offline   Reply With Quote
Old 14th of June 2010 (Mon)   #11
Wilt
Wilt's Avatar
It works very well. Read this thread...http://photography-on-the.net/forum/...52#post7370852
Old 17th of June 2010 (Thu)   #12
mrcanon4life
Q: with the Powersonic PS-832, will i be able to use the original charging cord that came with my quantum battery? I would hate to order one and can't charge it...
Old 17th of June 2010 (Thu)   #13
mrcanon4life
First, allow me totthank all who contribute to the forums. Although I have been shooting for almost 30 years - I do not profess to know everything...so, I turn to those that know what I need to learn. I purchased my Quantum Turbo in 1995 and it lasted up until 2008 (not 2003 as previously mentioned). I invested (at teh time) $10k in bodies, lenses and studio equipment whcih includes a Mamiya RB 67 w/3 backs, waist level and eye view finders and two lenses - thats when I made the Quantum "leap" and don't trust any other brand.
Thank you
Thank you
Old 17th of June 2010 (Thu)   #14
Wilt
Wilt's Avatar
The charging cord plugs into the Turbo electronics which has the battery plugged into it...so the charging cord will always be physically compatible. You may need additional time to charge the higher capacity battery, since the current flow remains the same from the charging circuit into the battery. But I have no idea how much time before the recommended 16hr. charge time is spent merely 'topping up' the last few percentage of full charge. As I have never fully depleted the battery, 16hrs. (recommended by Quantum no matter what) seems to always get the battery fully charged.
Old 27th of June 2010 (Sun)   #15
mrcanon4life
I got the 29.00 version of the battery and it works great. Thanks to this forum, I saved time and money. Thanks to you all
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Quantum Turbo Help elysium Small Flash and Studio Lighting 12 15th of February 2009 (Sun) 09:05
Used Quantum Turbo or New CP-E4? ies photos Small Flash and Studio Lighting 25 14th of February 2009 (Sat) 17:45
quantum turbo help begovics Small Flash and Studio Lighting 2 16th of July 2007 (Mon) 10:54
