#1 |
Hello, hope someone can help.
I'm currently using a 40D, 100-400L with a 580exII flash for humming birds. I have read that you need more than one flash to freeze hummingbird wings. I have been using the 580exII set to manual at 1/16 power mounted on the camera from about 10 feet away with a better beamer. I'm a bit too far I think. The images come out slightly under-exposed with some motion blur. Not alot but a bit. I would like to get another flash that I will set up on a tripod a few feet away from my feeder and leave the 580ex/better beamer on the camera. I would like to go with, if possible, an after market flash such as a Sun-pak or Vivatar. Could someone recommend a decent flash with any needed slaves in order to make it work with my 580ex? Tony |
| sponsored links |
#2 |
Stopping motion blur in a hummer's wings is all about timing
![]() Have you tried jacking your shutter speed up? |
#3 |
According to http://www.jedlovec.com/Hummingbird-Flight.php a flash of 1/40000th is sufficient to freeze the wings mid-flap...
According to http://www.photosbykev.com/wordpress...lash-duration/ the 580ex has a duraction of 1/35000th at 1/128th power. Close enough I've seen shots using ambient freezing wings at 1/2000th but thats when they get the wings at the peak or bottom of the stroke. (or sitting on a branch In your case if you move the flash to about 3ft* you will get a bit more light using 1/128th power. If you can't get that close we need to open the aperture or bump the iso. *fresnels kinda screw up the inverse square rule so that could be off edit :: You could add a cluster of 8x 580ex and shoot from 10ft away at 1/128th power Last edited by Lithian : 9th of May 2009 (Sat) at 16:11. |
| sponsored links |
#4 |
Check naturescapes.net. Most folks use 5-6 flash at very low power and smaller apertures. They also have printed bg
Back to basics 5dc with 35L & Sigma 85mm f1.4 |
#5 |
I was thinking about doing the same thing with my AB lights since the sun is never where I want it when the birds show up.
Kick back on the deck, pre-focus the camera, hook up the remote, and wait.
Bodies, Lenses, Lights, Stands, Transmitters, Receivers, Tripods, Meters, etc... |
#6 |
That is the method I used but not the ABs - I believe they are a bit slower than the EX flash on low power. With one 550EX I can't really get the wings to stop - close, but not stopped.
#7 | |
| Thread Tools | |
| Display Modes | |
| Second try at Hummingbirds... | Back288 | Birds | 19 | 17th of May 2008 (Sat) 22:06 |
| Hummingbirds | bigchef920 | Wildlife | 2 | 15th of September 2007 (Sat) 00:22 |
| Hummingbirds | speirs2 | Birds | 6 | 15th of May 2007 (Tue) 16:02 |
| Hummingbirds with flash | queenbee288 | Birds | 8 | 13th of August 2006 (Sun) 09:28 |
| Hummingbirds | dazzlebea | Birds | 5 | 30th of July 2006 (Sun) 15:57 |
