Go Back   Canon Digital Photography Forums > 'Sharing Knowhow' section > Talk About Photography > Nature & Landscapes Talk
Reply
Thread Tools Display Modes
Old 11th of May 2009 (Mon)   #1
wykdfantasy
Default The Art of Panoramic Shots?
I have been practicing taking shots of horizons and using software to stitch them together, I currently have PS CS4, and Autopano Giga 2.0. They both produce pretty good pano's but not perfect ones.
My question for the experienced is:
Is it better to take many shots overlapping with good margins or is it better to try to measure them out to only overlap enough so that the software has some distinct object to measure where to seam them together?
I have noticed that with overlapping a good portion I can ghosting of some objects, and with trying to measure them so they don't overlap a lot, sometimes the software creates a hard seam where it just doesn't look smooth.
Is there a more preferred software to get rid of ghosting effects or one that allows you to manipulate the individual shots after it has pre-rendered the panoramic?
-Paul
50D Gripped | XSI Gripped
24-135mm IS USM | 18-55mm IS | 10-22mm FOR SALE | 17-40 f/4 L USM | 24-70 f2.8 L USM | 70-200mm f/4 L IS USM | 580EX II | Pelican 1520 | Lowepro Slingshot 200AW & 300AW
I think I am in Love
wykdfantasy is offline   Reply With Quote
Old 12th of May 2009 (Tue)   #2
jrader
jrader's Avatar
Default Re: The Art of Panoramic Shots?
From my experience, I don't try to overlap more than 30%. Just like you said, when you overlap with more than 60% of the previous frame, you get stitching/blending errors. But if you don't overlap enough, the computer "forces" the stitch (sometimes with terrible results).
I think the cure for this one is to manually stitch/blend the images. I know that it can be tedious at times doing the transformations, but you'll be much more satisfied with the final image. The other suggestion I was thinking is to be sure and use a tripod and take shots when there are not moving objects in the frame. Sometimes, this is not possible (like ocean panoramics, for example).
I guess it all depends on what kind of images you are shooting. If you're shooting nature scenes, wait for a lull in the wind, shoot scenes with little to no movement in them (unless it's a stream/river, that won't affect the stitch), and repeat if necessary.
By the way, Autostitch in CS3 (I assume 4 as well) will let you manipulate the panoramic afterwards. It creates the panoramic in layers post-stitching, so before you save it, you can always go into the layers tab and do whatever you need to do (like some selective cloning) before flattening and saving the final image.
Hope this helps.
John
Photography equipment: 5DII, 17-40L, Hoya Pro1 CPL, Hitech NDs & GNDs (soft/hard), Cokin Z-pro filter holder, Canon shutter controller, Manfrotto tripod, Giottos head.
www.GreatEscapePhotography.com
jrader is offline   Reply With Quote
Old 14th of May 2009 (Thu)   #3
argyle
argyle's Avatar
I usually estimate a 25% overlap and go from there. Also, I try to shoot all of my panos with the camera in the vertical position. This usually requires a few more extra shots to fill the scene, but shooting vertical allows more room afterwards for any needed cropping. For stitching, I don't bother with Photoshop...my preferred stitching software is PTGUI Pro.
argyle is offline   Reply With Quote
Old 15th of May 2009 (Fri)   #4
Scottes
Trigger Man - POTN Retired
Scottes's Avatar
25% - 30% overlap is what I aim for.
For software, try Hugin (free), PTAssembler (cheap), PTGui (not cheap)
All 3 are very, very good. Hugin is open-source, so sometimes a little technical and sometimes a little "unpolished." PTAssembler can be fairly technical but it's extremely capable. PTGui is feature-rich, very capable, and easy enough to use (but with a lot of more capabilities once you get more proficient/knowledgeable).
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info
Finally, I have a Gallery!
Follower of Fidget - Joined the cult of HAMSTTR
Scottes is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Panoramic Shots SeanDudding Canon EF and EF-S Lenses 9 22nd of February 2009 (Sun) 21:00
Panoramic shots, what MUST i do? funk1196 Nature & Landscapes Talk 15 27th of January 2009 (Tue) 21:29
Panoramic shots guitarboy Wildlife 0 4th of August 2007 (Sat) 22:48
Panoramic shots cherry246 Small Compact Digitals by Canon 4 3rd of July 2006 (Mon) 07:11
