Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Accessories & Storage
Reply
Thread Tools Display Modes
Old 23rd of April 2005 (Sat)   #1
Drk Orange
Default Polarising filters - filters aint filters?
B&H have Canon polarising filters for $125 but also have a generic brand for only $54. Why the price difference? Is it just the brand, or are the canon more than twice as good?
Drk Orange is offline   Reply With Quote
Old 23rd of April 2005 (Sat)   #2
robertwgross
robertwgross's Avatar
Default Re: Polarising filters - filters aint filters?
At the last time that I checked it, Canon does not manufacture their own polarizing filters. So, the Canon filter is probably made in the same factory as the cheaper one. I can't imagine that many of the Canon filters are sold if there is that much price difference.
With some types of filters, like UV, the anti-reflective coatings on the glass make a difference. However, with a circular polarizer, you are not going to be shooting mostly at the sun angle, so I don't think the coatings are all that big of a deal.
Hoya and Tiffen sell lots of polarizers.
---Bob Gross---
robertwgross is offline   Reply With Quote
Old 23rd of April 2005 (Sat)   #3
willg
willg's Avatar
yeah i bought a polarizer for $30 and it was fine....is there any real difference?
willg is offline   Reply With Quote
Old 23rd of April 2005 (Sat)   #4
Drk Orange
The only negative I have had with a polarising filter is one (I believe it was a known brand) that fell off the lens when I was adjusting it - note to self, always adjust in an anti-clockwise direction - bounced down a cliff-face and landed in the ocean. I was able to retrieve it and a few weeks later there was some separation between the two glass layers.
I am guessing that level of abuse will affect any filter no matter the brand.
Old 24th of April 2005 (Sun)   #5
weemannie
I believe that Canon do produce Polarisers.
Basically the difference is in the quality of the optics. Whether or not its twice as good is a personal opinion
Regards, Trevor
5D MkIII, 60D, Zuiko 24mm, Zeiss ZE 21mm and 50mm 1.4, 70-300L, 10-22
http://www.scotlandimagery.com
weemannie is offline   Reply With Quote
Old 24th of April 2005 (Sun)   #6
Bodryn
Bodryn's Avatar
There is a difference between circular polarizers and simple polarizers. Apparently some digital cameras are not compatible with the simple polarizers so for best image quality you have to go to circular polarizers which cost a lot more. This topic was covered in detail some time ago on this website, nicely explained by somebody who knew the topic - maybe you can do a search or something and get the details. Sorry I can't remember more than that.
Bodryn ========
Canon A540; A720 IS; S5 IS; SX20 IS; Pentax *istDS + lots of lenses; Jasc PSP v.9;
"Where are we going? And why are we in this handbasket?
Bodryn is offline   Reply With Quote
Old 24th of April 2005 (Sun)   #7
Hellashot
User is banned from forums
AF cameras require circular polarizers where MF cameras can use either linear or circular. A linear polarizer can be used on an AF camera if using MF only.
Hellashot is offline   Reply With Quote
Old 24th of April 2005 (Sun)   #8
Drk Orange
Both filters mentioned are circular polarised.
Old 25th of April 2005 (Mon)   #9
I Simonius
Weather Sealed Photographer
I Simonius's Avatar
Location: On a Small Blue Planet with Small Blue People With Small Blue Eyes
This is Xactly the thread I was going to post so glad it's already up and running:
Assuming we know the difference twixt linear and circ pols, UV and skylights, I also would like to know if anyone has any experience re cheapo version of filters versus Xpensieve ones
I got some cheapo shop Branded ones, (Jessops)and whilst I think they're OKish I think they could be better
e.g. the circ pols don't seem to darken the sky that much _ I remember before when I used HOYA filters that I got a much darker sky ( If I pointed it at 90% to the sun)
I also wonder whether the coatings you might not get on more Xpensieve filters(UV , skylight1 A+B) are worth the Xtra cost
Opinions - thoughts- experiences- Fire away!
I Simonius is offline   Reply With Quote
Old 25th of April 2005 (Mon)   #10
DocFrankenstein
DocFrankenstein's Avatar
I guess the difference between the cheap and expensive is the quality... Some may flare, some may soften the image... I've heard that some ones peel off after time... never happened with mine.
In the end you're better off comparing the two, and deciding which ones are better suited for your requirements.
For example, I wouldn't even think of putting an expensive polarizer on the kit lens... But on 50/1.8 I would probably put a B+W or a Hoya Pro1
I have typed this from Ubuntu.
Vent: One lens, two lenses. Advice=what you seek; advise=what we do. Then="at that time" or "subsequently"; than="compared to". Aperture, not aperature. Their="owned by them"; there="at that place"; they're="they are". Its="owned by it"; it's="it is". Your="owned by you"; you're="you are"; ur="primitive".
DocFrankenstein is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Shedding light on wide angle polarizing/polarising filters keenasmustard Canon EF and EF-S Lenses 27 15th of October 2008 (Wed) 06:44
Rotating front of circular polarising filters DanAus1983 Accessories & Storage 4 19th of December 2006 (Tue) 06:26
Circular Polarising Filters Jono A Weddings and Other Family Events 4 13th of November 2006 (Mon) 08:23
Sigma Circular Polarising Filters... should I get another one? Raymate Canon EF and EF-S Lenses 9 2nd of January 2006 (Mon) 15:38
