Reply
Thread Tools Display Modes
Old 25th of May 2009 (Mon)   #1
Fergie
Fergie's Avatar
Default It's a Stitch-up
My first use of the 'Stitch' facility with my G9 and I was amazed at the result so I just had to post it somewhere.
The photo was taken a couple of weeks ago at Fraserburgh harbour.
Do you guys often use the stitch feature.
I would like to see some samples of photos that have ben merged 'in camera'.
Cheers.
Fergie
Fergie is offline   Reply With Quote
Old 25th of May 2009 (Mon)   #2
Yapo
Yapo's Avatar
Default Re: It's a Stitch-up
oh wow that looks flawless! All the panorama stitches ive done with my ixus 60 have always had visible seams. I shall have to try it out on my G10 once i get it back...there was a dead pixel on the sensor so i took it back but the shop was out of stock and they were told that g10s were backordered from canon so they dont know when they'll get more stock!
m4/3: Olympus E-PL2 + Voigtlander 25 f/0.95
DSLR: Canon 5D MKII | Canon 7D | EF-S 18-55 IS | EF-S 55-250 IS | EF 50 f/1.4 | EF 85 f/1.8 | Tokina 11-16 f/2.8 | Rokinon 35 f/1.4 | 430EX II
Yapo is offline   Reply With Quote
Old 25th of May 2009 (Mon)   #3
Rare1
Was this two shots together?
Canon 60D
Canon 17-55mm f/2.8 IS
Canon Powershot G7
Rare1 is offline   Reply With Quote
Old 25th of May 2009 (Mon)   #4
Fergie
Fergie's Avatar
Yes Rare1, it was two shots.
Fergie
Old 25th of May 2009 (Mon)   #5
ryandood
ryandood's Avatar
I've never used the in-camera stitch assist but often use the software provided with the camera to stitch together panos. I must be doing something wrong because almost all of mine come out with the seems visible at least a little bit, even with the use of a tripod. The downside to the in-camera stitch assist is that it only works in landscape and I'd prefer to take panos in portrait.
So does the in-camera assist completely stitch it together for you or just make it easier once loaded onto the computer?
My G10 was good. My XS is better and here is my flickr.
ryandood is offline   Reply With Quote
Old 27th of May 2009 (Wed)   #6
SamClarkPhotography
SamClarkPhotography's Avatar
Can you highlight or point out where the seams approx. are? How about linking to a full-sized version? It looks great from here...
Gripped XSi . Canon 18-135 IS . 055XPROB Manfrotto
SamClarkPhotography is offline   Reply With Quote
Old 28th of May 2009 (Thu)   #7
denncald
The camera feature is supposed to make it easier to overlap your images for each shot. When properly overlapped they will stitch together better on your computer using the PhotoStitch software supplied with the camera.
I haven't used it much, but it does work good when you are careful about each shot alignment. I had one series I took that didn't align very well on the second shot in the seven shot, hand-held series. I tried Microsoft's ICE software with the same series, and it came out much better, but still not perfect due to that one shot.
The link for MS ICE is;
http://research.microsoft.com/en-us/...roups/ivm/ICE/
Dennis
denncald is online now   Reply With Quote
Old 2nd of June 2009 (Tue)   #8
Fergie
Fergie's Avatar
Sam..I imagine the merge would be somewhere 'midship'. As I had no hand in it, it's hard to say.
I was at Carlisle Castle a couple of days ago and tried a 'Stitch' shot with three images and another 'Stitch' shot using just two images. Five photos in total.
...................................... As can be seen the three shot stitch was a shambles.
I then tried for the two shot stitch and got this...
It was much better than the three shot one.
Below are the two shots that were used.
Cheers.
Fergie
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Panorama Stitch JERM Nature & Landscapes 11 16th of February 2009 (Mon) 18:12
First Stitch SOT Still Life, B/W & Experimental 1 16th of October 2007 (Tue) 01:45
How do you all stitch photos? OdiN1701 RAW, Post Processing and Printing 20 30th of May 2007 (Wed) 09:49
first stitch snowboarderx Critique Corner 4 26th of January 2006 (Thu) 13:05
