#1 |
Hi Everyone,
I'm hoping to get some ideas from some of the experienced motorsports shooters on here. I'm using a 450D w/a 100-400IS and am getting a very poor ratio of sharp shots at 400mm at the track. Looking for pointers or ideas about how to increase my sharpness at 400mm...especially for far away shots. I'm pretty sure my 100-400 is good b/c I get sharp shots when I shoot something still or something close at 400... and occasionally when I shoot something moving that's far away. I'll post a couple of examples and would appreciate any feedback. These images were selected purely to show softness at 400mm so pls ignore composition, angle etc. They're 100% crops of the center section of the image, no other pp. Is my issue a depth of field problem? Lens calibration issue? Panning technique? Or do I just need to be closer to get sharp shots? Help! Exif data should be intact but shots were taken at 370mm f8 1/400th and 400mm f8 1/320th, both with center point focus. Can't remember if IS was mode 1 or 2 on these particular shots but I believe 2. Thanks for any help! -Noah |
| sponsored links |
#2 |
"wetter than an otter's pocket"
How much have you cropped these?...I'd like to see the originals with just a re-size to 1024...If you're cropping heavily then it will affect quality.
Also, it looks like a reasonably hot day so you'll start to fall foul of heat haze. Your other shots from the Red Bull Air Race look fine so i doubt it's a lens issue.
Geoff www.bhppix.co.uk ___________________ I enjoy taking photos. I don't claim to be any good at it |
#3 |
They're cropped heavily... 1000 pixels taken out of the center of the 12mp shot. Here are the originals just sized down to 1024 as requested. I guess I was hoping to get it more crisp when the image is viewed at 100%.
| sponsored links |
#4 |
#5 |
OK so it's simply that these shots are from too far away then? Anything I can do to make shots at this range come out sharper?
#6 | |
Other than shooting with a longer lens?... Not really. Get closer, learn what turns will work with the lenses you have. BTW is this Button Willow? It also looks a little like Willow Springs, but I don't recognize the bleachers.
2 7D's & Grips & 1 dead 40D, 24-104mm f/4 L, 100mm f/2.8 Macro, 50mm f/1.8, 580EXII www.ryantorresphotography.com "Ducky in the City" Fun for the ducky loving community. Photography Facebook Fan Page |
#7 |
Thanks GSH and Ryant... I appreciate the comments. I was trying to get the most shots from one spot as possible. Man of the the others, where I was closer to the bike came out very sharp.
These were shot at Street of Willow 5/22/09. Bleachers in the background is turn 2 shot from the closest you can get to it in pit lane. I think that's horse thief mile's bleachers in the bg. The other shot is turn 11, that fun little left after the chicane! |
#8 |
"I'm the original idiot"
You have hit the big problem with motorsport. 400mm is not long enough and at least in my case, my pockets are not long enough for the kit I really should buy.
I add a Kenko 1.4x PRO 300 to my 100-400L which does improve it a little, but you still need to get a lot closer. The British SuperBikes are at my local track this coming weekend, and at my favorite spot, I'm probably about 40 feet from the riders. I try very hard to compose in camera and crop very little. I've only got 8.1 mp with my 30D to start with and quality drains away very rapidly as I crop. Forgot to mention: Everything I shoot at the track is done with a monopod. never handheld. Last edited by Lowner : 28th of May 2009 (Thu) at 14:22. |
#9 |
I used to shoot for the track photographer at WIllow Springs shoots some of the turns with a 500mm f/4 & 2XTC. We got different angles than everybody else. Coming out of turn 1 and into turn 2 on the big track, shot from the access road to the south is great for showing a pack, but you need 1000mm and a steady hand.
#10 | |
![]() For reference, this is a motorcycle image at 300mm from a XTi, which has a similar sensor size. The motorcycle is around 150 feet away, and it's framed tighter than in the full-sized images above. You can get closer to the motorcycles, get a 2x teleconverter, or a longer lens - a 600mm f/4 IS is US $7,800 and a 800mm f/5.6 IS is US $11,000. And those long-lens approaches won't eliminate the heat haze. Last edited by DC Fan : 2nd of February 2010 (Tue) at 16:36. Reason: link |
#11 |
Go Suzuki!!!!
#12 |
suzuki!
#13 |
If you haven't it might be worth looking at this thread as well http://photography-on-the.net/forum/...d.php?t=703204
I too use a 100 - 400, after suggestions received on here I now use it with the image stablisation turned off and more often than not with monopod. I am much more pleased with the results I get. Though to be honest, with your sample pictures and the distance you are away from the subject I suspect it will not be as crisp and you want. Robert |
#14 |
Thanks for the comments Robert. I spent a good deal of time reading the threads on here about the 100-400 and did see the one you posted. I was in Las Vegas shooting Supermoto last weekend and got much better results. I didn't have a monopod but IS off makes a big difference, as does knowing the distance limits of the lens.
These are last weeks supermoto shots: http://photography-on-the.net/forum/...moto+las+vegas -Noah |
| Thread Tools | |
| Display Modes | |
| 100-400mm- So sharp and Vibrant!! | wizard13 | Birds | 5 | 20th of April 2009 (Mon) 16:19 |
| what's your opiion on the 100-400mm or 400mm for inflight shots? | wayne_eddy | Canon EF and EF-S Lenses | 29 | 22nd of August 2007 (Wed) 18:25 |
| Need a sharp lens around 400mm | Simon Spiers | Canon EF and EF-S Lenses | 41 | 26th of May 2005 (Thu) 13:19 |
