Go Back   Canon Digital Photography Forums > 'Equipment Talk' section > Canon EF and EF-S Lenses > Lens Sample Photo Archive
Reply
Thread Tools Display Modes
Old 30th of May 2009 (Sat)   #1
dolina
dolina's Avatar
Default Canon TS-E 17mm f/4L
This is shipping in limited quantities worldwide so post your samples here.
Mention what body you used it on and if you used LiveView.
dolina is offline   Reply With Quote
Old 1st of June 2009 (Mon)   #2
dandig
Default Re: Canon TS-E 17mm f/4L
perhaps whoever happens to be lucky enough to have the first example to post here could also check to see whether it is compatible with the 1.4 tC as the older TS-Es were.
I'm thinking if you get a 17mm and throw a 1.4 tc on there you have a 24mm too.....
www.dancarrphotography.com
dandig is offline   Reply With Quote
Old 1st of June 2009 (Mon)   #3
waynema
had a chance to play with it last Thursday. I wish I knew what I was doing with tilt shift.. shot at 1/40 F4.
It didn't look deep enough from the back to fit a TC.
*edit: and also more samples here...
http://www.smugmug.com/photos/552536106_xwn8g-X2.jpg
Last edited by rpolitsr : 30th of March 2012 (Fri) at 02:02. Reason: oversized image converted to link
waynema is offline   Reply With Quote
Old 1st of June 2009 (Mon)   #4
Telkin
Telkin's Avatar
I'm pretty sure TC's aren't compatible with wide angles.
Telkin is offline   Reply With Quote
Old 1st of June 2009 (Mon)   #5
Gabe63
Looks like you were in Palo Alto. Wait until the new to market price is worn off. I bought the 200 F2 the first week it was out, should have waited a year...
16-35IIL, 50L, 70-200 2.8 IS L, 200L F2.
Gabe63 is offline   Reply With Quote
Old 2nd of June 2009 (Tue)   #6
dandig
The TCs worked fine with the original 24mm TS-E, that's why i was asking and in fact my question was answered on another site. The photographer tested the new 17mm using a 1.4 TC and it looked pretty good! His samples of 17mm ts-e + 1.4 TC were much sharper than the original 24mm ts-e.
scroll down for TC comparison http://forums.dpreview.com/forums/re...3&changemode=1
Old 24th of June 2009 (Wed)   #7
bunyarra
A few - boring housing from a recent shoot sadly Note : virtually no distortion and so little CA that I did not bother to correct a single image.
One with a Kenko 1.4 TC attached
A 2 image shot - one shifted left , the other shifted right then merged in Photoshop.
Michael Gove
http://photosignals.smugmug.com
Google+ Profile
bunyarra is offline   Reply With Quote
Old 24th of June 2009 (Wed)   #8
thejager
this lens looks awesome... more shots please!
thejager is offline   Reply With Quote
Old 21st of July 2009 (Tue)   #9
OiPaz
OiPaz's Avatar
A few quick tests. This lens has impressive sharpness and chromatic aberrations, very very good geometric correctness and flare resistance, excellent focal length for street architectural photography. It's a real pleasure to use!
Canon EOS 5D, TS-E 17/4 @ f/11, 13 sec, ISO 100
Who needs a gear list, when you can have a Gear Graph!
OiPaz is offline   Reply With Quote
Old 21st of July 2009 (Tue)   #10
OiPaz
OiPaz's Avatar
Canon EOS 5D, TS-E 17/4 @ f/10, 13 sec, ISO 100
Old 21st of July 2009 (Tue)   #11
OiPaz
OiPaz's Avatar
Canon EOS 5D, TS-E 17/4 @ f/11, 15 sec, ISO 100
Old 25th of July 2009 (Sat)   #12
The Ghost of FM
The Ghost of FM's Avatar
Thumbs up Re: Canon TS-E 17mm f/4L
Wow!
There are some amazing shots here from this new lens!
Now, I just have to make a trip to my local lottery kiosk in order to have any chance of ever owning one too!
Cheers!
GEAR LIST l WEBSITE
The Ghost of FM is offline   Reply With Quote
Old 4th of August 2009 (Tue)   #13
OiPaz
OiPaz's Avatar
Canon EOS 5D, TS-E 17/4 @ f/11, 30 sec, ISO 100
Old 2nd of September 2009 (Wed)   #14
Meista
more shots please
http://www.noneedforlight.com
Meista is offline   Reply With Quote
Old 30th of September 2009 (Wed)   #15
dolina
dolina's Avatar
How is the colors?
http://www.flickr.com/photos/alabang/
Paolo-Dolina-Visuals - Wildlife, Travel, Street, Sports, Photojournalism, Nature, Motorsport, Landscape & Food photography in the Philippines and beyond
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Canon 10D and Tokina 10-17mm erikw46 Canon EF and EF-S Lenses 2 12th of January 2009 (Mon) 08:41
Canon 17-40L and 10-22 at 17mm blue_max Canon EF and EF-S Lenses 18 9th of June 2006 (Fri) 03:43
